Old 08-12-2013, 10:51 AM   #426
naphtali5725
naphtali5725's Avatar
Re: My new project 86 Silverado
updated updates...
all new parking brake cables from rock auto
all new brake spring kit, and adjuster kits, wheel cylinders, shoes, and drums
tightened and applied cotter pins to all front steering/suspension items, ball joints, tie rod ends etc.
all suspension and shocks are installed.
bed is on with new bushings, bolts are stainless steel...
more to come soon...
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 08-12-2013, 11:09 AM   #427
77ChevySharkBite
77ChevySharkBite's Avatar
Looking sharp man!!!! Keep it up, I need to work on mine I've been slacking!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 08-12-2013, 12:03 PM   #428
naphtali5725
thnks man!
go get busy
My build thread...
Disabled Veteran
Old 08-15-2013, 12:20 AM   #429
chevybuilder18
chevybuilder18's Avatar
Damn! looks great man. whats next on your agenda, or is it a surprise?
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 08-16-2013, 05:55 PM   #430
naphtali5725
Epoxy primed the inner fenders, and underside of hood today...
fuel tank mounts/straps and radiator core support, radiator cover, and cowl piece will be primed tomorrow weather permitting....
My build thread...
Disabled Veteran
Old 08-17-2013, 05:15 PM   #431
naphtali5725
rained all day here... delays...
My build thread...
Disabled Veteran
Old 08-18-2013, 09:38 AM   #432
naphtali5725
Got a performance rebuild on my Quadrajet... built by Lars Grimsrud
Here are his notes on my carb...
"The carb checked out really well after a few setup modifications and after all the plugged fuel and air passages were chased down... I ran it through all modes of operation from cold-start, hot re-start, idle, and no-load cruise. I also tested for secondary operations and WOT transition. Idle is glass smooth, off-idle response is crisp, and mixtures are right where they should be - see photos attached of your carb running on the test engine with actual air/fuel ratio and idle rpm. I have the A/F set at 14.2:1, which is perfect for today's pump gas, and rpm is at 850 so it will idle with your cam. I have removed the rear pulloff (these are no longer available, and they were not used on the performance application carbs), and I have installed and tested the electric choke per your request - the choke operates perfectly, and was tested on the engine (note the choke wire hooked up in the photo)."
Here's a few pics...
My build thread...
Disabled Veteran
Old 08-23-2013, 08:59 PM   #433
naphtali5725
block sanded the epoxy primer on the cab with 180, getting it ready for the 2K primer... will finish up the roof tomorrow and post some pics... I hope to get a good first coat of primer on the cab...
My build thread...
Disabled Veteran
Old 08-24-2013, 03:10 AM   #434
chevybuilder18
its looking great... i cant wait till you show a vid of that engine running.. looks like aluminum heads and alot more goodys put into it and im glad im not the only guy who likes qaudrajets..
Old 08-24-2013, 09:01 AM   #435
naphtali5725
yeah, that Chevy engine is a test engine used for tuning the carb... it's not the engine going in my truck...
My motor will be a 461 Pontiac built from a 400 block by Jim Lehart...
My build thread...
Disabled Veteran
Old 09-06-2013, 02:10 PM   #436
naphtali5725
besides me getting into a car wreck, my Dad is here for another 7 days... i'll pick back up on the truck when he goes home....
hope all is well with everyone
My build thread...
Disabled Veteran
Old 09-06-2013, 02:16 PM   #437
77ChevySharkBite
Originally Posted by naphtali5725 View Post
besides getting into a car wreck, my Dad is here for another 7 days... i'll pick back up on the truck when he goes home....
always good times to be had with your Dad! Glad your doing okay from the car wreck..
it's raining here so no updates, and mosquitos are killer so makes wanting to work on the truck a bit of a pain. Maybe I'll go pick up some paint and paint my bezel this weekend!
Korwin
Old 09-06-2013, 04:01 PM   #438
chevybuilder18
hope you and your dads doing well.. your doing good, and about the 461 pontiac motor, THAT is so sweet!!! cant wait till you show us what that engine does
Old 09-06-2013, 05:55 PM   #439
rs74
rs74's Avatar
Did you get into another accident or just the one a while back? Hope all is well.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 09-06-2013, 08:40 PM   #440
naphtali5725
just the one a while back... all ok so far
My build thread...
Disabled Veteran
Old 09-17-2013, 07:31 AM   #441
naphtali5725
sorry for the lack of updates the last month or two...
took my Dad back to Florida this weekend...
will now be able to get back to work on my truck, stay tuned
My build thread...
Disabled Veteran
Old 09-25-2013, 04:48 PM   #442
chevybuilder18
cant wait!
Old 10-15-2013, 07:35 PM   #443
Sodell
Sodell's Avatar
Whats up?
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 10-16-2013, 04:45 AM   #444
naphtali5725
we'll, since i'm a disabled vet, i may not get paid on the 1st of Nov.
if i don't my truck project may be put on hold, or even sold if necessary...
here's hoping...
My build thread...
Disabled Veteran
Old 10-16-2013, 08:22 AM   #445
Low Elco
How much does that carb rebuild cost? Sounds like he knows his stuff!
Low Elco is offline   Reply With Quote
Old 10-16-2013, 03:59 PM   #446
naphtali5725
for all the parts and build about 300
My build thread...
Disabled Veteran
Old 12-05-2013, 01:14 PM   #447
naphtali5725
sorry for lack of updates....
just paid the 2nd half of my new dash from diy4x, it should be here in a few days... updates soon i hope...
My build thread...
Disabled Veteran
Old 12-05-2013, 01:45 PM   #448
77ChevySharkBite
Sweet bro!!! How's the engines coming along?
Korwin
Old 12-05-2013, 02:25 PM   #449
rs74
rs74's Avatar
Hey, you are alive! I have been wondering about you lately.
Roy
1987 R10 shortie
Old 01-10-2014, 10:38 PM   #450
rs74
rs74's Avatar
Hey man, are you still hanging in there?
Roy
1987 R10 shortie
