05-25-2018, 06:52 AM | #426 |
Re: What did you do yo your truck today??
Got it back with new ATK 315hp crate engine installed.
06-16-2018, 09:40 PM | #427 |
Had the stripes put on the hood!
Still one or two things yet to do. #worktruck |
06-17-2018, 07:37 AM | #428 |
Looks good!
06-17-2018, 08:17 AM | #429 |
One day.....
Stripes look cool! Truck condition looks great. Any more pics?
DZL1. Bertha build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=733306 '72 C10 short bed. Bessie (traded) '93 C3500 CC Dually. Bertha (traded) ‘96 C1500 ECSB. Black Beauty '89 C1500 RCSB LS swap. Black Bean '06 Silverado CCSB Ghost (Wifes Truck) '12 GMC Terrain V6. Titanium Bling (Wife’s Daily) ‘14 Chevrolet Cruze. Raspberry (Daughters Ride) '99 Jeep Wrangler. Road Hog (Sons Ride) |
06-23-2018, 12:32 AM | #430 |
06-23-2018, 08:55 AM | #431 |
One day.....
Looks like it just came out of factory!! Awesome job keeping it that way
06-24-2018, 03:18 PM | #432 |
07-16-2018, 10:02 AM | #433 |
Can't believe the distributor cap died on my truck just sitting home in the driveway but thanks to Canadian Tire being open on Sunday and a drive there from a family member we were mobile again within an hour. After the swap to a new cap and rotor I tested the old cap and found ZERO continuity between the coil wire post and the button inside that sits on the rotor. Never saw anything like that before....
http://www.maritimedragracing.com Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information. |
07-16-2018, 01:24 PM | #434 |
Got to do the good old loose tilt column repair. Did it when I first got the truck 9 years ago. Doesn't look like I put lock tite on it last time
08-24-2018, 01:34 AM | #435 |
I finally had time to get the thing running. Did a TBI to Carb swap. Been crazy busy so today was the day . Drove it around the block so I’m happy haha.
Posted via Mobile Device |
08-24-2018, 05:51 AM | #436 |
08-24-2018, 07:33 AM | #437 |
I painted the grille. Paint was fading off and needed freshening up. I got new lights and lenses since those were all dulled out and lights far from clear. I used the same charcoal color I put on the wheels. I wanted the grille to still look factory while matching the wheels. I was originally trying to match wheels to grille but came out darker. I like the grille a touch darker, kinda like the W/T grille but lighter. Last fall I put a new third brake light and tail lamps in to freshen up the rear.
Before. Can't tell how bad the paint is faded off, but dull and aged looking for sure: Freshened up. A minor thing, but all lenses on truck now are clear and fresh: Just keeping 'er alive with a touch of pride
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-26-2018 at 07:38 AM. |
12-05-2018, 10:09 PM | #438 |
Picked up a set of used firestone tires from my friend's garage and installed them on my truck. Got an alignment also.
01-07-2019, 02:56 AM | #439 |
Pre fitted the roll pan before paint.
Life is too short to drive a boring vehicle. |
01-15-2019, 02:20 PM | #440 |
Roll pan installed and body moulding removed.
04-15-2019, 09:05 AM | #441 |
Questionable
Phase 1 of front-end work done this weekend. Grilled pulled apart, buffed/polished/waxed, lights replaced with 'Eagle Eye' OEM style replacements off Amazon. Might be able to see again while driving after dark now.
Picked up a brand front and rear bumper off Craigslist for $150 total last week also, looked up model numbers on Summit and Amazon - normally $750-$850 for same bumpers there. Now waiting on replacement rub strip for front bumper and hoping to score a pre-painted green grille and filler piece that sits between grille and bumper before going there. Some before/after action:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-25-2019, 09:06 PM | #442 |
Replaced the rear shocks and installed the Firestone Destination AT's that I got from 4wheelonline.
11-30-2019, 10:18 PM | #443 |
Installed new carpet.
01-11-2021, 11:54 PM | #444 | |
Changed the brakes and one rotor the other day and noticed the upper control arm bushings are worn out on the drivers side. Then I noticed the control arm is also rusted by one bushing and needs to be replaced entirely. Then I noticed one of the bolts is missing the offset washer which is causing it to move around even more. Picked some up at the junkyard.
01-12-2021, 07:53 AM | #445 |
upgraded my 97 Sierra to the nbs truck brake master cylinder. No more soft pedal going to the floor. Now I have a good brake pedal & shorter stops
1997 GMC Sierra Ext 1965 Mustang |
01-13-2021, 02:20 AM | #446 |
Put Rear Air Bags Air Compressor 5 Gallon Tank For Later Train Horns And Some Rear Ridge 20” Light bar
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
01-16-2021, 12:16 AM | #447 | |
Re: What did you do to your truck today??
I picked up the new control arm to go with the bolts:
01-17-2021, 12:03 AM | #448 |
Got air Bags Air Compressor and air Tank next up Train Horns mounted Everything Were Spare Went Fab all Brackets
01-17-2021, 12:29 AM | #449 | |
You replacing the springs with bags or doing helper bags?
01-17-2021, 12:39 AM | #450 | |
Changed the control arm. The bushings weren't even that bad. The movement from the missing washer distorted the control arm. As usual found another bad part while working on it. The pitman arm is loose on the shaft and the nut is all the way tight. I think it's the shaft not the arm.
