05-14-2014, 09:55 AM | #1 |
Boosted Member
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Here is something you might find helpful as well.
http://www.hawksthirdgenparts.com/pr...N-Fitting.html
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
05-14-2014, 10:07 AM | #2 |
Thanks, yeah, that might work.right now im leaning towards a small mesh wire basket for the baffle in the v/c, any thoughts?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
05-14-2014, 03:04 PM | #3 | |
Boosted Member
05-14-2014, 06:14 PM | #4 |
Dang, oh well, back to the drawing board, as they say....i so had my hopes up as far as that can being the answer
Thanks for trying
05-15-2014, 09:48 AM | #5 | |
Boosted Member
http://www.summitracing.com/parts/ae...FYtAMgodXWUAIw http://www.summitracing.com/parts/sum-220062/overview/
05-15-2014, 11:07 AM | #6 | |
Saw the can at peterson fluid website while i was sourcing dry sump systems... Thanks for your help
05-14-2014, 10:52 AM | #7 |
Boosted Member
i used a solid piece of aluminum to keep liquid oil from splashing into the breather fitting. It's open on the sides to allow air movement, but no direct oil ingestion.
05-14-2014, 01:01 PM | #8 |
OK, let me think about that, might be a better solution than what i had in mind. Further thought on the adapter/fitting you posted may very well work, just have to cut a hole that it will screw into, dont know yet what that hole will have to look like. Maybe just buy the fitting and go from there
Thanks for your time and help, this PCV has got me fustrated
05-14-2014, 03:00 PM | #9 |
Boosted Member
That PCV is meant to take the place of the oil filler cap, lol.
If you wanted, you could probably run two passenger side valve covers with these fittings, and you'd have two -10 crankcase vent ports ready to go.
06-02-2014, 09:40 AM | #10 |
Boosted Member
Got the top finally pulled off on Friday evening.
Bunch of local guys got together and had a dyno day on Saturday. I didn't put up any hero numbers, but I'm happy with the result on a rough street tune with soft timing, and the lowest boost I could run (9 psi). Gonna get the boost controller plumbed up and start to sneak up on it. Should be fun, as this turbo really STARTS to come alive and becomes efficient around 18 psi. Will probably bump the rev limiter up a bit too, since it was still climbing pretty good when I shut it down around 6300. Video:
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by Wasted Income; 06-02-2014 at 01:35 PM. |
06-02-2014, 11:12 AM | #11 |
nice work Jeff!! the giggle factor is pretty high
70 Chevelle SS (clone), 454, 350 auto 71 K5 350, 350 auto, 3" body lift, 35's -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |____|__|___] *.*..*.*.._@_ _ _ _ @ |
07-05-2014, 01:34 AM | #12 |
Awesome work!! Very nice!!
07-07-2014, 02:13 PM | #13 |
Good #'s for low boost!
What are you running for a muffler? It sounds nice!
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
07-10-2014, 12:21 AM | #14 |
This is one bad a$$ blazer - damn!!
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
07-15-2014, 08:59 AM | #15 | |
Boosted Member
Thanks guys
I built a 4" aluminum down pipe and used a Vibrant 4" aluminum muffler with it. It also has the wastegate dumped to atmosphere.
07-27-2014, 08:55 PM | #16 |
Read thewhole thread right now nice build I had seen videos of it before on YouTube and saw the build thread right now and had to read it hope to do a similar setup on my 69 c10 how you like that holley intake and that dominator I've seen a lot of the fast trucks back at home going to that holley dominator setup
07-28-2014, 08:55 AM | #17 |
Boosted Member
Thanks man. The intake looks badass, no doubt. Can't really say if it hurt, helped, or didn't change the low end response, since I swapped cams the same time I changed intakes.
The dominator is awesome. It's VERY similar to the megasquirt in terms of capability and tuning methodology, but it's just so much more refined and user friendly. Blows the stock ECU junk out of the water. I like it so much in fact, that I just bought another one for a project car I'm working on
07-28-2014, 09:44 AM | #18 |
2WD Jimmy
[QUOTE=
I like it so much in fact, that I just bought another one for a project car I'm working on [/QUOTE] C'mon... what is it? |
07-28-2014, 10:34 AM | #19 |
Boosted Member
64 Buick Skylark. I've already got the LS6 from a CTS-V built for it, and the 4L80E ready to go. It's getting turbocharged as well Much more longer term project. It's getting taken down to bare metal to repair a couple rust spots, and a fresh paint job.
07-29-2014, 09:25 AM | #20 |
2WD Jimmy
Love the old Buicks. That will be sweet.
07-29-2014, 09:32 AM | #21 |
Buick looks straight and solid...
Goodies to be had for the 64-72 A-body should/could make this thing nasty! pro-touring?/OEM outside-nasty inside?/drag? whats the project outcome and scope on this one? [too many questions too soon?]
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
07-29-2014, 02:48 PM | #22 |
Boosted Member
Not really sure what direction this one will go. Probably a bit pro-touring with some suspension and brake upgrades, with a bone stock interior, and some stickey tires for impromptu stoplight action.
Kind of a well rounded street car/cruiser/bruiser.
08-13-2014, 04:43 PM | #23 |
Boosted Member
Guess I haven't updated this in awhile...the ol' Family Truckster is living up to it's name. My wife and I welcomed our son to the world about 3 months ago. He's already been out cruising topless with us a few times As you can tell, horsepower puts my daughter to sleep. lol
08-13-2014, 05:11 PM | #24 |
Congrats on the addition!
08-14-2014, 11:21 AM | #25 |
Certified BFH Operator
Congratulations on the kiddo!!
- 1969 swb C/10 fleetside -LSx swap and Resto in progress LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay... -1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle |
