Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-07-2022, 10:37 AM   #426
jjzepplin
jjzepplin's Avatar
Re: Buried to Bagged 1972 2wd
What do you do about the oil fill tube?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-21-2022, 12:07 AM   #427
Slick67
Sofa King Crazy!!
Slick67's Avatar
Originally Posted by 77chris03 View Post
your wood wheels might come up missing....
I know you jealous!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 01-21-2022, 12:08 AM   #428
Slick67
Sofa King Crazy!!
Slick67's Avatar
I can use the oil fill tube with the valve covers, although I am still looking at better alternatives. These factory tubes just do not look that great.
Old 01-21-2022, 12:18 AM   #429
Slick67
Sofa King Crazy!!
Slick67's Avatar
I've actually been busy on the Blazer the past few days and made some progress!! Hoping to have her in sealer before the end of February so I can take her to Lonestar Throwdown 2022! Geezus, I need to clean this thing out.....
Old 03-16-2022, 02:01 AM   #430
Slick67
Sofa King Crazy!!
Slick67's Avatar
Made some progress again!!!
Attachment 2177464
Attachment 2177465
Attachment 2177466
Attachment 2177467
Attachment 2177468
Old 03-16-2022, 08:14 AM   #431
kev2809
low n' slo
kev2809's Avatar
Originally Posted by Slick67 View Post
david the pics didn't work. are you doing your own body work?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-17-2022, 05:54 PM   #432
my71gmc
my71gmc's Avatar
Hey David, I had some time today and ended up reading through your entire build thread. IT IS AWESOME!!! The work you are doing is so cool - and I can't wait to see the end result. It almost makes me want to get a project going now that I am retired. Just wanted to let you know.... Keith
my71gmc is offline   Reply With Quote
Old 06-03-2022, 12:19 PM   #433
Slick67
Sofa King Crazy!!
Slick67's Avatar
Dangit! I'll upload again. I am doing the smaller stuff and having a friend check it for me and do some of the larger areas.
Old 06-03-2022, 12:22 PM   #434
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hey Keith!! I appreciate you taking the time to go through the thread, and thank you for the kind words! Definitely a labor of love that takes time. Now that you are retired you have plenty of time to do one how ya want!!
Old 06-03-2022, 01:11 PM   #435
kev2809
low n' slo
kev2809's Avatar
David where's the updates??
-_--_--_ _________
Old 06-03-2022, 01:54 PM   #436
Slick67
Sofa King Crazy!!
Slick67's Avatar
I had to revisit a couple of things that needed attention. Moving forward is moving forward!! I had to pull the quarter out to eliminate alot of the filler that was needed.
I cleaned up the door handle delete and pulled out some of it as well.
I wanted to smooth the door to body area a little after doing a little custom overhang after cutting the tops of the doors off.
She is surely an ugly duckling at this point!!
Old 06-03-2022, 02:05 PM   #437
Slick67
Sofa King Crazy!!
Slick67's Avatar
I cut some 1 1/4 in pipe in two and capped the inside of the door to make the 55 dash wing flow better.
After reworking the firewall a little and cleaning it up I started some of the bodywork and cut my hole for the steering column for mockup.
I figured why not mock up my hood hinges while I am working on the firewall!!
Old 06-03-2022, 02:10 PM   #438
Slick67
Sofa King Crazy!!
Slick67's Avatar
Finally got around to finishing the install of the 55 Bel Air dash!!! It actually wasn't as bad as I thought it would be and looked factory after it was welded in.
Old 06-03-2022, 02:17 PM   #439
Slick67
Sofa King Crazy!!
Slick67's Avatar
This is where the build started getting interesting. I had a crazy idea of making the interior look a little like an old Corvette so I mocked it up in cardboard awhile back and now I started making it out of metal and attaching it to the hinged cover I was building.
Old 06-03-2022, 02:25 PM   #440
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here is the hinged cover tacked in and getting adjusted to fit the sides and to align with the custom console and sides. I went ahead and put the hinges on for the rear cover as well.
Old 06-03-2022, 02:31 PM   #441
Slick67
Sofa King Crazy!!
Slick67's Avatar
After getting the cover aligned, I went ahead and decided to cover it and make it start looking like what I had envisioned. There were a hundred steps involved in the process but here is a breakdown of what happened.
Old 06-03-2022, 02:40 PM   #442
Slick67
Sofa King Crazy!!
Slick67's Avatar
After getting the cover wrapped in metal and welded up it was on to the console. I mocked it up a few times and had to make sure it aligned with the cover. The console will eventually be integrated into the dash in a tasteful way. I have not yet finished the area where the console and cover match up, but I'll get to it!! They do line up nicely and when I am done with the console I will add some stainless cup holders and a nice fat hole for a radio or tablet.
Old 06-03-2022, 02:48 PM   #443
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here are some filler pics just to show a little of the progress in full pictures. It is turning out to look amazingly close to what I had dreamed up and did in cardboard!!I know some of you may not like it but that is what custom is all about....being different!!!
Old 06-03-2022, 02:49 PM   #444
Slick67
Sofa King Crazy!!
Slick67's Avatar
This enough???
Old 06-03-2022, 03:31 PM   #445
Slick67
Sofa King Crazy!!
Slick67's Avatar
I needed to get the metal covered so I put down some polyester filler. Definitely it look much better! The Blazer took on a new life with it's new color.
Old 06-03-2022, 03:42 PM   #446
Slick67
Sofa King Crazy!!
Slick67's Avatar
Being that I was in a major rush to get this thing together for a show, I wanted to get some colored epoxy on it. I have decided to paint it blue so I got some tinted epoxy so I could see what it would look like.
Old 06-03-2022, 03:58 PM   #447
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here are the pics after getting it together in one night and taking it to Lone Star Throwdown 2022. It was cold and a tad rainy but I made it there with just a sprinkle or two. Had a blast just showing off the work and then back home to some much needed heat!! I will be back on it soon and hopefully have some more updates to share!
Old 06-03-2022, 08:21 PM   #448
kev2809
low n' slo
kev2809's Avatar
damn that is nice!! loving the build..
-_--_--_ _________
Old 06-04-2022, 06:00 AM   #449
Slick67
Sofa King Crazy!!
Slick67's Avatar
Download overload!!!!
Old 06-04-2022, 09:29 AM   #450
FamilyTruckster65
Great Work!
Where did you source the hinges for your decks?
FamilyTruckster65 is offline   Reply With Quote
