#4576 |
Re: Restoring Rusty
Welcome back to the world of funny fickle old pick-it-ups. Lol
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#4577 |
Post Whore
![]() Join Date: Aug 2014
Re: Restoring Rusty
#4578 |
Re: Restoring Rusty
#4579 |
Post Whore
Re: Restoring Rusty
Last camping trip of the year and the twisties were just fine with the manual steering box I think I was doing about 40 MPH with one hand on the wheel and the other on the stick
Did I mention truck camping is the best!!! Git on outder! |
#4580 |
Re: Restoring Rusty
Manual steering is fine until it's a 3/4 ton with big tires sitting on concrete.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
#4581 |
Re: Restoring Rusty
So awesome.
#4582 |
Post Whore
Re: Restoring Rusty
Out with the New and in with the (slightly) Used
so I got tired of the head pounding drone of my Flowmaster Series 40s and decided to weld up the Magnaflows here's how they compare, the Magnaflows are longer Last edited by Gregski; 09-07-2016 at 01:43 AM. |
#4583 |
Post Whore
Re: Restoring Rusty
see how they came with the hanger rod, I try to do a good job a clean job so I cut it off and grinder that area smooth
#4584 |
Post Whore
Re: Restoring Rusty
and so the passenger side is done, this is what it looks like it will go slightly down and out the side (not exactly how it lays in the picture but you git the idear)
#4585 |
Post Whore
Re: Restoring Rusty
and here is the driver side same but opposite (hey is that like yes and no or same difference, ha ha) by they way I can't stand both of those responses, ha ha
took me about 3 hours from the time I got home to take the old exhaust off cut it up, moc up the new exhaust, and weld 'er up - for those of you keeping track of our billables, hee hee FACT: The best exhaust clamp is a WELDER!!! Last edited by Gregski; 09-07-2016 at 01:45 AM. |
#4586 |
Post Whore
Re: Restoring Rusty
alright enuff of your bugger welds how do it sound?
well honestly it's too soon to tell I did drive it around the neighborhood a bit (late at night) cause that's where the drone was the worst below 1000 RPM and I also took it on a highway in One Word I would say it seems - RASPIE...ER but ever since I topped off my transmission fluid now my New Process 833 overdrive transmission likes to make a Chewbacca choking on a hairy dog noise in second gear making it difficult to hear the exhaust note, and a bit of a whinning noise in 4th gear, old trucks gotta love 'em fix one thing and TWO others break also, it seemed like I left it idling a bit high at 850 RPM the last time I made carb adjustments so I toned it down to 700 RPM (that put some low end rumble back in it) and will drive it to work tomorrow and report back my findings when I have more data Last edited by Gregski; 09-07-2016 at 01:47 AM. |
#4587 |
Re: Restoring Rusty
So the drone was still that bad after you added the turn outs?
Posted via Mobile Device |
#4588 | |
Post Whore
Re: Restoring Rusty
I figure I could have played the H pipe or the X pipe game but I wanted better flowing mufflers anyway so went with the straight through design of the MagnaFlows |
#4589 |
Post Whore
Re: Restoring Rusty
So lowered the RPMs to 700 and drove the truck in to work, it's not as loud as the Flowmasters and it is a bit raspier, I want more of a low tone rumble though so I may remove the 9 inch resonators that are currently in front of the mufflers and see what it sounds like without them
#4590 |
Post Whore
Re: Restoring Rusty
~ Parts ~
time to do something different and away from the engine got this Roll Pan from Summit for $99 bucks looks like a nice piece |
#4591 |
Re: Restoring Rusty
Cool pan.
#4592 |
Re: Restoring Rusty
That roll pan looks like a nice piece. It even comes with the plate light. I assume it's weld in?
#4593 |
Post Whore
Re: Restoring Rusty
#4594 |
Post Whore
Re: Restoring Rusty
so lets fit this thing
OK our roll pan is 67 and 2/16ths (that's right I said 2/16ths take that my 6th grade match teacher) And our opening is [wait for it] 67 and 1/16ths - Surprise Surprise so out comes the Power Spreader 3000 so Moses parted the Sea out to 67 1/2 inches so that after the spreader was removed the opening now was 67 1/4 inches, see how that works |
#4595 |
Post Whore
Re: Restoring Rusty
alright so now it fits width wise but why won't this darn thing slide up another inch? what is it hitting on?
so we clampatize it and take a peak underneath (finally git to use my cheap Harbor Freight clampy clam, and oh boy does it suck) |
#4596 |
Re: Restoring Rusty
A math lesson, product introduction and tool review all in the same thread? C'mon now...it doesn't get any better than that! Wait...maybe it does...
![]() Keep up the good work.
Romans 10:9 - The Truth |
#4597 |
Re: Restoring Rusty
Are sure the license plate isn't in the way? Lol.
#4598 |
Post Whore
Re: Restoring Rusty
#4599 |
Post Whore
Re: Restoring Rusty
good guess, the license plate is dangling by two white zip ties, a tribute to the boyz of Roadkill
but you are in the right area, The Greg just had to get the roll pan with the license plate recess so sure enuff it hits the 2x4 at the back of the bed, so out comes the blue tape and the Wheel of Death it was roughly 27" from the side to the indent on the pan, so I went 26 1/2 to make the cut just to have a bit of wiggle room, then I just bent the metal back instead of cutting it all out, you know if and when the time comes to put this NUMBERS MATCHING barn find to spec in time for 2038 SEMA Last edited by Gregski; 09-10-2016 at 11:00 AM. |
#4600 |
Post Whore
Re: Restoring Rusty
I was too lazy to take the tailgate off before drilling the holes, and only after I scratched it up drilling the outside two holes (one on either side) did I put the blue tape on for "protection" to make you guys think I was that careful, but guess what even with the blue tape I mucked it up, ha ha - hey IT'S A TRUCK!
it was dark it was late, and I was sweating profusely = beer time I took as many pics as I could (without getting off my butt) to show you how it looks all moched up, I will remove it and make it GREEN soon also the phillips head screws they give you to hold this thing on are COMPLETELY and utterly useless, you need a hex head on a self tapping screw, just sayin' |
