#4701 |
Re: What did you do to your truck today? Chapter II
Very nice!!!
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#4702 |
![]() Join Date: Jul 2015
#4703 | |
Are you using the factory A/C from the 6.0 or is that Vintage Air? How does all of that tie into the cab? It looks like the factory fan box isn't there, can't really tell from the angles of the pics. What hydroboost brake system is that - did it come from Wilwood? |
#4704 |
colgad, nice looking set up.
#4705 | |
The hydroboost is out of an Astro with a Willwood master. Stock 71-72 front disks and Caddy rear disks. I have two Spal two speed fans on an ebay aluminum radiator. I have the computer control Fan1 and Fan2 on low speed and a seperate sensor controls the high speed on Fan1 and Fan2 I used LT1swap.com instructions to modify the old harness and sent him the cpu to flash. Thanks for the nice comments.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#4706 |
Thanks, I credit the ebay aluminum intake, it sure beats the stock black plastic one for looks.
#4707 |
#4708 |
This is why I love this thread, it has so many good ideas and great information - especially while planning the resto-mod!
#4709 | |
#4710 |
I know, there is nothing else like it. I got so many great idea's when I was building my C50's.
#4711 | |
#4712 |
You do have a nice stepside but the Chevelle WOW! That blue is really something.
#4713 | |
![]() I took a round file to remove the barbs that remained from the bit. It was a really tight fit so it doesn't move around inside the hole, I just got it in there, I started to hook up the wires, but when I started looking at the wiring, it was quite obvious that whoever installed the radio (non factory, i don't think a dealer did it either), there was a nest of wires, a lot of them were cut and hanging loose, so I need to chase them out and see what goes where and remove wires that are not necessary. Nothing can ever be easy! You may be able to use a small grinding wheel on a Dremel tool to make the hole larger, mark the hole needed then cut, this would also allow you to leave the sides flat so the power adapter is "keyed" into the hole. Thanks guys! Last edited by matthamby; 12-08-2016 at 09:37 AM. |
#4714 |
#4715 |
Looking good there ! .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#4716 |
#4717 |
RE: Bed Wood :
Is that some sort of one piece bed ? . My '69 has the usual planks and metal strips . This looks like the basis for a beautiful custom (non work) bed floor .
#4718 |
That's awesome. I love it.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
#4719 |
I went out and spun mine over. Hasnt ran for awhile since the brakes went out. Decided it needed to run for a little bit and shake the mice out of it. Fired right up in the cold weather and let her get up to temp before shutting it down again.
#4720 |
#4721 | |
Yes it lays over the top of my metal floor, if I need to haul something I can remove the wood floor in less than 5min... thinking I may have some pinstriping done on it before we lay the epoxy over it again |
#4722 |
the heat from welding the nuts on is whats helping break the others loose. find something to fit kind of tight into the hole of the drilled stud, heat it with a torch to transfer the heat throughout the bolt, remove the ( something), and try the easy-out while its hot...
#4723 | |
#4724 | |
I dug up some I've had for quite a while. You can tell by the price. lol ![]() Did get bushings pressed in and arms painted. ![]() Bracket and power steering pump painted ![]() |
#4725 |
