Old 12-12-2010, 11:50 PM   #451
mcbassin
Still Learning
mcbassin's Avatar
Re: It’s Just A Pickup
Awesome pictures, progress and as always detailed description. Thanks!
mcbassin is offline   Reply With Quote
Old 12-13-2010, 01:43 AM   #452
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
great build!
subscribed
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 12-14-2010, 10:56 AM   #453
62 short step
62 short step's Avatar
Very nice!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 12-14-2010, 11:13 AM   #454
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nice work Bruce.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-15-2010, 06:52 PM   #455
Bruce88
Bruce88's Avatar
A tool that’s hard to do without
But rarely needed or used
The ignition switch bezel on the 68 – 72 trucks can be hard to remove or install without damaging it without a special tool. You can look around the web and find a tool to buy or you can make your own.
I made a tool to do the job and maybe you would like to make one to. It’s not that hard, just takes a little time and attention to accuracy in locating the pin holes.
I made mine out of ½ inch thick aluminum stock that I had around the shop and 3/32 DIA roll pins plus a 3/8 x 1-1/4 long bolt & nuts. It could also be made out of some ¼ inch thick stock. Ideally a peace of aluminum 2-1/4 inch in DIA and ¼ inch thick would be the best to start with and save the time in cutting it into a circle.
You will need a drill press to drill the holes straight. A 3/32 (.094) drill bit and a 3/8 (.375) drill bit. A center punch to locate the hole locations accurately (preventing the drill bit from wandering during drilling).
Locating the three holes accurately on the 1-3/4 (1.75) DIA circle shown in the picture below is a must. If there not, the roll pins may not go into the bezel notches correctly and the tool will not work.
The picture below (template) is made at actual size and can be used to locate the pin holes accurately, just print the template and tape it to your stock. One problem you might have with printing the template is to make sure that your printer is set to print actual size/100%, some printers will expand or shrink to fit the paper size. One way to check that it printed correctly is to measure across the red circle on the template and if it measures 2-1/4 (2.25) inches it printed correctly.
I also put some roll pins in the tool to remove/install the dash knob bezels. Might as well get multiple uses out of a specialty tool (smile). Note there are two types of dash knob bezels used and the pins only will work on the small bezels with the holes.
Body and paint update
Found a good day to get the truck back down to the body and paint shop with out it getting soaked. Minimizing the painting delay.
A small gift of a how to and knowledge to you, enjoy the holidays and don’t forget to enjoy your build (smile).
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 12-15-2010, 07:19 PM   #456
VA72C10
VA72C10
VA72C10's Avatar
nice writeup on the tool and the truck is looking good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-15-2010, 08:04 PM   #457
swamp rat
swamp rat's Avatar
Nice custom tool! Sure beats how i removed mine!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-16-2010, 05:01 PM   #458
Stubbs67
Stubbs67's Avatar
bruce it is friggen awesome I CANNOT WAIT to see her painted and trimmed in all her glory!!!
67 Short Step Project -My other wife, ya know... (she takes all my time and money and I don't even realize it)
88 Subaru wagon 4wd -Daily driver and workhorse
98 Subaru Forester S - Wife and baby wheels
My Build Thread!
http://67-72chevytrucks.com/vboard/s...d.php?t=433751
Need step tail gate and bed front, driver door, both front fenders (both are bondo'd nightmares). can trade fleetside bed parts real straight (except sides) or pay some cash (i am pretty broke)
Stubbs67 is offline   Reply With Quote
Old 12-16-2010, 11:10 PM   #459
Hubscrub
Cruzin
Hubscrub's Avatar
i love how you detail everything you do i'm gonna do the ground wire thing to my lights like you did because i have one loseing ground alot. Very nice build you have going
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-17-2010, 12:31 PM   #460
raider65
raider65's Avatar
This build has just soo much detail it's incredible!
It's not rust...It's character!
raider65 is offline   Reply With Quote
Old 12-19-2010, 09:00 PM   #461
RCbowtie69
RCbowtie69's Avatar
nice build!! keep up the hard work, like to see the finish product, keep on truckin''
RCbowtie69 is offline   Reply With Quote
Old 12-30-2010, 12:49 PM   #462
Seventy Two
Bruce, your work and detailed descriptions are outstanding! I'm looking foreward to your next update.
Seventy Two is offline   Reply With Quote
Old 01-01-2011, 04:39 AM   #463
Bruce88
Bruce88's Avatar
Filling the hole
It works today but will it work tomorrow
At some time when working on your truck you will find the need to add or modify wiring. The use of insulated terminals/splices would be the most common connectors that you would be working with. Yes there are plenty of other connectors out there like Weather pack, Packard 56, not insulated, and so on, all requiring their own and separate crimping tools and step to put them together.
I was helping a friend the other day figuring out why the tail lights on the old trailer he bought where not working right. I think we ran into a lot of the common mistakes that people make from twisting wires together & taping it up with electrical tape, putting the bear wire under a screw for a ground, the quick wire taps used, and so on. They all worked the day it was put together but with time, vibration and weather they failed in the end. If they would have taken the time to do the wiring terminals/splices correctly the problems that we ran into would not have happened.
One process of terminals/ splices that little information is commonly known is how to figure multiple wire termination and chousing the right size terminal/splice to use. When splicing two wires the same size together it’s easy just pick the splice color for that wire size. But when your putting more than one wire in a terminal or one end of a splice you need to figure out what size is needed, to small and all the wires will not fit and to large and the crimp will be loose and not be a good connection.
There are two way of calculating wire area (kcmil) thousand circular mils or (mm2) square millimeter, both are just a way to figure how much area a wire will take up. In the chart and calculation below I’m using (mm2) area for the process.
In the two pictures below I think you can find enough information on how to figure out the right size terminal/splice to use in your wiring projects. There’s no way to give you the answer for every situation and different wire sizes, you need to calculate each multiple wire termination. But the examples should give you a starting point. May all your terminations be good and not cause problems down the road.
Just a picture of some of the terminals/ splices that I had laying around the shop and wiring I’ve been doing for the instrument cluster going under the dash. You find the quick tap splices everywhere (in the box below) I personally would not use them, they can cut the wire strand when being installed and corrosion is a problem if in a wet environment.
Heat shrink tubing is a nice finishing touch to add to terminals/splices giving added insulation/protection and help preventing water from getting into the splice causing possible corrosion. I’ve used a lighter to shrink the tubing but you always run into the problem of melting/burning the tubing. There’s some handy butane torches out there that do a good job of concentrating the heat and not burning the tubing. If you get one just look for one with the shield and tube to concentrate the heat and prevent burning.
Just passing on some information and tips that might help you out with a wiring project.
Not a lot done since the last update just some block sanding, the color and clear coat should be laid down next week. Where somewhat behind anticipated schedule but with the weather delays and the holiday season it isn’t too bad.
Happy New Year
Old 01-01-2011, 10:17 AM   #464
glimmertwin01
glimmertwin01's Avatar
learned alot of this through trial and error... :_ the butt connectors that are heat shrinkable are nice too... i prefer to make western union type connections then solder and shrink tube.... it takes a while... but they never fail....
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 01-06-2011, 09:31 PM   #465
Bruce88
Bruce88's Avatar
Some are in and some are out
Not all can fit in at the same time, it’s just too much
All the bed panels are painted and out of the paint booth. The cab is in and should have its paint today. By next week everything should be back in my shop and the reassembly of all the parts will start.
Enjoy your build
Old 01-06-2011, 10:39 PM   #466
my67chevytruck
Under Construction
looks outstanding. nice progess...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-06-2011, 10:48 PM   #467
mcbassin
Still Learning
mcbassin's Avatar
The paint looks great, nice progress Bruce! What type of paint are you using?
Old 01-06-2011, 11:06 PM   #468
swamp rat
swamp rat's Avatar
Nice!!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-06-2011, 11:24 PM   #469
Bruce88
Bruce88's Avatar
The paint the paint shop uses is by BASF Glasurit 90-Line Waterborne basecoat system. The color is the match for GM 505 green
Old 01-06-2011, 11:40 PM   #470
srea76
srea76's Avatar
amazing build
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 01-06-2011, 11:54 PM   #471
mcbassin
Still Learning
mcbassin's Avatar
Thanks, I was wondering if you were using BC/CC it looks great and should hold up great too....after all it's just a pickup right?.
Old 01-07-2011, 12:45 AM   #472
VA72C10
VA72C10
VA72C10's Avatar
very nice!!!
Old 01-07-2011, 01:26 AM   #473
frog trucker
frog trucker's Avatar
Location: Smack-dab in the middle of "The land of fruits and nuts", Sacramento, CA
WOW! Lookin' great Bruce!
And I too want to thank you for sharing all the great info!
frog trucker is offline   Reply With Quote
Old 01-07-2011, 01:56 AM   #474
Stubbs67
Stubbs67's Avatar
simply amazing... im speechless... and jealous
My Build Thread!
Old 01-07-2011, 07:34 PM   #475
Bruce88
Bruce88's Avatar
The pictures don’t do it justice
The painter laid down a very nice finish
I was down at the shop picking up some of the small parts that I can transport in my small car and that don’t need any further work. The cab is out of the paint booth and the finish the painter has laid down is as good as what could have been seen at the dealership when the truck was new (probably better). Very minor color sanding will be required, just some polishing and it will be done. The painter has definitely showed his very good abilities and quality work.
I know that this is a quick update (short time) since the last. I was just so impressed with the outcome at this stage that I wanted to share it with you (smile).
Enjoy your build
