Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-05-2015, 06:31 PM   #451
First c10
First c10's Avatar
Re: Project Reno - 72 cheyenne rebuild
The starter cover you have looks like the one that came with my 4.8/4L60. do you have the one that came with your motor?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-05-2015, 06:34 PM   #452
cmabolt
cmabolt's Avatar
Motor came with no trans. I only have the stock plates that came with both bell housings I had for the 350.
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
Old 06-05-2015, 06:40 PM   #453
First c10
First c10's Avatar
Actually both one templates you have look real close to the originals I can take a picture when I go to my shop if you want. get a part number maybe?
GO GO!!!
Old 06-05-2015, 06:45 PM   #454
cmabolt
cmabolt's Avatar
Well that would be great. Save me some time definitely.
Old 06-07-2015, 11:55 PM   #455
DWilbur
That explains it all LS and SM465
DWilbur is offline   Reply With Quote
Old 06-07-2015, 11:57 PM   #456
First c10
First c10's Avatar
Sorry man but I had to work both days this weekend so I didn't get to the shop. I will try tomorrow.
GO GO!!!
Old 06-08-2015, 08:31 AM   #457
cmabolt
cmabolt's Avatar
No worries. I am slammed with work as well so won't be fabricating anything for a couple weeks.
I appreciate the favor.
Chris
Old 06-08-2015, 08:45 AM   #458
cmabolt
cmabolt's Avatar
Yup...SM465. A proven performer and with the short throw top cover, should be fun for a while. I really did want to put in a NV4500, but funds and all the chit chat about 5th gear eventually being a problem kinda helped me stick with what I have. I will in the near future upgrade the cam in the motor and will probably do the trans at the same time. I plan to go with whatever the best 5th gear remedy
is out there on the inter web as well so will either buy a new one or rebuild with high end parts.
The main issue is I will have to do the driveshafts again and deal with a host of other mods that you're all to familiar with.
For now though, this setup is pretty nice and will work.
Chris
Old 06-08-2015, 02:00 PM   #459
DWilbur
Ya it's hard to beat SM465 they have done a great job designing it and it's proven it's self over and aver again. I still have mine and 205.
Old 06-15-2015, 01:58 PM   #460
cmabolt
cmabolt's Avatar
Howdy all. Well in my quest to find someone that could do REAL wood dash pieces, I found this guy in Texas. Very nice, semi-retired and based on conversation with him he seems like a good guy to deal with. For those of you that might want to go the real wood route on your cheyenne's, here is a link to the product he is making. Every dash is custom made to your specifications. The company name is Wabbit's wood works and here's a link:
http://www.hotrodhotline.com/pr/2009/09wabbitsmay2/
I have not decided if I am going to go this route based on the types of wood he uses, but will update this if I indeed use him. Hope this helps someone... out there... searching...
and searching....and searching...
Old 06-15-2015, 03:36 PM   #461
DWilbur
Nice look'n wood work. I bet they cost a few bucks
Old 06-18-2015, 07:56 AM   #462
cmabolt
cmabolt's Avatar
Well, considering the craftsmanship, I didn't think it was bad at all at $175.00 Unfortunately, due to the wood I wanted to use, I am gonna have to do this myself. After searching for a bit I sourced a nice piece of wood to do the glove box and ashtray covers. I would also like to do something with the center console, but that may require re-molding the hinged top piece so the wood can inlay somehow. That will be phase 2 I guess.
This is heavily figured curly maple. It looks almost pearl. I am going with an amber stain to match interior accents. Gonna plane it down to about a 1/4 inch and the rest will be by hand. I will do this step by step and take my time. Will be nice to do something that isn't metal for a change. If all goes well, the finished piece should be coated with glossy UV resistant crystal clear bar top epoxy resin and adhered with 3m trim tape.
On another front, my last round of jobs is almost wrapped up so will be able to get the truck finished up in July. I insured her yesterday so no turning back now.
Cheers
Old 06-18-2015, 03:46 PM   #463
DWilbur
If the material is 3/4" thick re-saw it so you end up with 2 pieces 3/8" thick and plane them down to 1/4" double you material. if you don't have a band saw to re-saw you can have a lumber yard do it for you. I made a water ski that way back in high school skied on it for almost 15 years.
Old 06-19-2015, 12:55 PM   #464
cmabolt
cmabolt's Avatar
That's a good idea, I will inquire about that. Would save time as well.
Today I was able to get the dust shield for the bell housing done and installed. Turned out pretty good I guess. They'll stop dust anyway.
The drivers side also serves as a spring point for the second clutch fork spring
Passengers side was a little more work and had to weld tangs on the upper right to keep it from pushing into the flywheel.
Old 06-20-2015, 11:43 PM   #465
Reno81K20
Reno81K20's Avatar
Can you tell me more about the "Push to Start" button? I'd love that.
Reno81K20 is offline   Reply With Quote
Old 06-21-2015, 01:08 PM   #466
cmabolt
cmabolt's Avatar
I sourced my system from Advanced keys. They are a company in Canada. Unfortunately,
It was an afterthought and had I known the required hole in the dash was much smaller then
what exists in that location for stock ignition, I could have welded the hole up. They were eager to help and had a larger button, but it too was too small for the hole. I returned the system and was bummed not to be able to use it.
Instead I used the neutral safety switch wired into a toggle switch under the dash somewhere to shut off the ignition in an effort to add a theft deterrent feature. I have also heard of people that hide a push button switch into and behind the lighter. Pretty cool.
Anyway, check out the website if interested. The whole advanced keys system is slick. It enables the ignition as you approach the car. Has the ability to unlock doors, start the car etc.
http://www.advancedkeys.com/Prod_AK104B.html
Old 06-21-2015, 05:36 PM   #467
Reno81K20
Reno81K20's Avatar
Thank you,. This might just make it into my 85 C-20 .
Old 07-09-2015, 07:44 PM   #468
cmabolt
cmabolt's Avatar
Wood work
Well, had a day to get some of the trim work done. A friend of a friend planed the wood down to 3/16" and that gave me a good base to fine tune the wood. I was able to template the glove box and ashtray and transfer that to the curly maple. Today I cut, shaped and sanded the wood to a thickness I liked. A few woodworkers I know recommended Watco Danish oil as the finish.
I did some tests and determined that a combo of two oils in several coats got me the look I wanted.
This is the initial coat with just golden oak. As I had hoped, the grain popped right out with some color.
I next added a few coats of the light walnut. This deepened the grain and richened the color. It will match the interior accents and be slightly lighter than the truck's paint.
In three days I will coat with bar top epoxy to give it a smooth glassy hard finish.
Old 07-09-2015, 08:07 PM   #469
swamp rat
swamp rat's Avatar
Looks like a good stain combination..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-09-2015, 10:22 PM   #470
rgunlock
rgunlock's Avatar
Me Likey!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 07-09-2015, 10:51 PM   #471
DWilbur
Very cool can't wait to see the wood installed
Old 07-10-2015, 10:01 AM   #472
cmabolt
cmabolt's Avatar
Originally Posted by rgunlock View Post
Me Likey!
Thanks guys. I can't wait to epoxy this stuff and add some depth/gloss. Next week should be a productive week. I hope to get the exhaust finished and wood trim installed.
Old 07-12-2015, 10:39 PM   #473
mjensen
mjensen's Avatar
I got a quick question for you. As you had suggested, I ended up with the American Autowire harness. My question is how did you mount your fuse panel? Just using the two studs punching through the firewall? I really like how clean yours turned out! I found the picture, but couldn't quite tell.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 07-12-2015, 10:45 PM   #474
cmabolt
cmabolt's Avatar
I used 2 stainless alen head or button head bolts that were inserted from the firewall side through the fuse panel and used nylon stainless lock nuts with a touch of anti seize. I drilled my firewall using the template provided in the kit. The kit comes with 2 long screws for the fuse panel which I did not use.
Glad you went with AAW. Let me know if you have any other questions.
Old 07-12-2015, 10:53 PM   #475
mjensen
mjensen's Avatar
Awesome! Thank you! I just went through everything, and I don't see a template. I'll have to see if I can get it online. Mine also didn't come with any screws, but I'm going the same route you did anyway. Thanks again!
Mike
