Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 04-01-2015, 12:56 AM   #451
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
Thanks for the compliment and the purchase
Originally Posted by superflysteiny View Post
I love my new brackets took me about 10 minutes to put on and they fit perfect. Thank you
Old 04-08-2015, 10:46 PM   #452
BigRed76
BigRed76's Avatar
Can I get a set of brackets powdercoated in black? I'm also interested in a set of levers, brackets, and springs for the '76-'78 Eldorado rear calipers if you're still making those.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 04-09-2015, 12:53 AM   #453
Captainfab
60-66 Nut
The powder coating will take up to a week to have done.
Yes I still make the levers, cable brackets and springs for the Eldorado calipers.
I'll send you a PM.
Old 04-20-2015, 11:11 PM   #454
BigRed76
BigRed76's Avatar
I got my brackets and caliper hardware today. Excellent quality, I can't wait to get them on the truck! Thanks again
Zach
Old 04-23-2015, 11:07 PM   #455
BigRed76
BigRed76's Avatar
I just want to clarify on a few things before I dive into this rear disc brake conversion.
1st- I want to make sure that on the Eldorado calipers, the nub needs to be ground off, referring to the one in the picture with the arrow.
2nd- I noticed that the lever that bolts to the caliper is not a perfect fit on the hex part that locates the lever on the caliper, but I'm assuming that if I tighten the nut enough it will hold the lever tight?
3rd- Any recommendations on a quality caliper paint?
Thanks, Zach
Zach
Old 04-24-2015, 12:43 AM   #456
Captainfab
60-66 Nut
No, do not cut that 'nub' stop off. Some calipers have two of those close to each other. You can see on your caliper where that would be just to the left in the picture.
So the hex in the lever is a little bigger than the hex on the shaft in the caliper? The ones I checked, the lever was a fairly tight fit. if it is a little loose, just rotate it in the direction of travel and tighten the nut. It should be fine.
Eastwood sells some pretty good caliper paint.
Old 04-27-2015, 04:08 PM   #457
PLYONS11
I have read the entire thread and have seen the later Eldorado 79-85 mentioned a few times, but I did not see anything that mentioned if they work with captains bracket. Did I miss it? The reason I ask is because I have found a set of the D154 calipers with ebrake, brake lines, ebrake lines and hardware, drilled 5 lug rotors and basically everything else I need for 399. Seems like a decent price.
I would really prefer to use the Wilwood D52's as I will be using them up front, but I need a parking brake.
PLYONS11 is offline   Reply With Quote
Old 04-27-2015, 11:34 PM   #458
Captainfab
60-66 Nut
The '79-'85 calipers will not work. They are much different from the D52 calipers. If you need an e-brake caliper you can use the '76-'78 Eldorado, Toronado and Riviera calipers as shown in the pic above. Those are interchangeable with the D52 calipers.
A rear disc bracket set that uses the Metric style D154 caliper will be coming. I just do not know just when as there are several other projects ahead of that.
Old 04-30-2015, 11:11 AM   #459
RRR18
RRR18's Avatar
Finally got calipers.
Once again, big thanks to CaptainFab for a great quality product.
Those wanting to run 15" rallys....mine fit.
Perfect fit.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 04-30-2015, 11:13 AM   #460
RRR18
RRR18's Avatar
My rotors are still taped up from painting.
'67 BAD IDEA
Ryan
Old 04-30-2015, 11:14 AM   #461
RRR18
RRR18's Avatar
'67 BAD IDEA
Ryan
Old 04-30-2015, 11:55 PM   #462
Captainfab
60-66 Nut
Looks good Ryan
Tell us more about those axles. I don't believe I have heard of that brand before.
Old 05-01-2015, 12:37 AM   #463
RRR18
RRR18's Avatar
Ten Factory by Motive Gear. Factory replacement axles as my originals were pitted up kinda bad at bearing.
'67 BAD IDEA
Ryan
Old 06-08-2015, 08:17 PM   #464
Dobok
Hey Captain; I finally got my 12 bolt rear diff. and found out it is a 1966 12 bolt with 6 lugs !!! I will be changing the axles to a 5 lug and was wondering if you have a rear disc conversion for my setup !! It is going on my 1994 GMC xten cab. Could you please let me know all the parts if you have something for me !!! Btw keep up the good work !!!! Dave
Dobok is offline   Reply With Quote
Old 06-09-2015, 12:23 AM   #465
Captainfab
60-66 Nut
With a 12 bolt you can use any of the three 5 x 5 rear disc brackets that I make including the D52's. Would you like them in bare steel or satin black powder coat?
Old 06-25-2015, 03:19 PM   #466
BigRed76
BigRed76's Avatar
Hey captain, have you had any feedback from guys using the 76-78 eldo calipers as far as what to do about e-brake cables? I have found very little info on completed conversions detailing what was used for e-brake cables. I thought I remembered reading about some guys cutting and re-crimping the existing cables but I can't find that info now. Thanks
Zach
Old 06-25-2015, 11:22 PM   #467
Captainfab
60-66 Nut
I have not had any feedback from anyone on what e-brake cables they are using.
I have purchased a set of these cables, but the ones specified for the '67-'72 and sent them to a customer in the UK. I have not heard back on their fitment.
http://www.ebay.com/itm/380213787534...%3AMEBIDX%3AIT
I can get you the length of those tomorrow, if that would help.
Old 06-25-2015, 11:43 PM   #468
BigRed76
BigRed76's Avatar
I would appreciate it if you could get a length on those.
Zach
Old 06-28-2015, 12:37 AM   #469
Captainfab
60-66 Nut
Sorry for the delay.
The overall length of the cable itself is 43-5/8". The length of the housing where the clips go is 33-1/2"
Old 06-30-2015, 11:03 PM   #470
ol_skool_chevy
ol_skool_chevy's Avatar
I don't do pay pal...how can i send a money order?
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 06-30-2015, 11:13 PM   #471
Captainfab
60-66 Nut
I replied to your PM regarding this
Old 06-30-2015, 11:41 PM   #472
Captainfab
60-66 Nut
ol_skool_chevy, your PM box is now full. I can not reply to your PM's any longer.
Old 07-09-2015, 12:05 AM   #473
Captainfab
60-66 Nut
I currently have a set of these brackets in satin black powder coat in stock ready to ship
Old 08-01-2015, 11:46 AM   #474
BigRed76
BigRed76's Avatar
I got mine mocked up last night with the eldorado calipers. My question is does this look correct? The lever seems to be very close to the bracket because of that nub that limits how far back it can go.
Zach
Old 08-01-2015, 11:39 PM   #475
Captainfab
60-66 Nut
Zach, is that the same caliper you posted a pic of in post #455 above? If so, my apologies. That nub will need to be cut off or ground down to clear the lever. I guess I wasn't looking at that previous pic correctly.
