04-02-2019, 10:12 PM | #451 |
Active Member
I found some newer metal with diamond pattern to fix my window gap issue I had. Stripped the other panels to raw aluminum and will polish later. Now time for the top metal.
Posted via Mobile Device |
04-04-2019, 09:46 PM | #452 |
Re: What did you do to your truck today.The 3rd chapter
Picked up some parts, installed some parts, including the LH manifold. "Can't" do the RH manifold, decided to strip the powder coat off the A/C bracket to exhaust manifold in favor of ceramic. Coating guy says that one is free, so what the heck. Not taking any chances it melts all over the "new" manifold. Slow moving, but will get there eventually.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
04-05-2019, 11:11 AM | #453 |
I put new LED tailights in the 67 GMC yesterday. Also installed the new led compatible flasher. Boy does that make a difference! I got new amber LED bulbs for the front that I'll put in this weekend.
04-07-2019, 02:58 PM | #454 |
Got the transmission back. But there is a problem with the converter. It will not fully seat. Has me stumped never had this problem . So I'm bringing to the shop to let them figure it out. I got the converter from them as part of the rebuild. But I did manage to get the trans crossmember out. What a *****. Ended up grinding and drilling out the rivets that hold the wings on. Really see no reason for them but I'll just bolt them back in place. The crossmember was in remarkably good shape.
04-07-2019, 09:14 PM | #455 |
what I did with it, today this truck sits in my garage all winter used it today to take advantage of the Home Depot sale on mulch....spring has sprung
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-07-2019, 09:25 PM | #456 |
Got the inside of the cab cleaned up. Wiped all the dust and spills from painting and it sitting in the garage for a year during work. Then laid the carpet.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE Last edited by rjs53; 04-07-2019 at 09:36 PM. |
04-07-2019, 09:27 PM | #457 | |
Great deal! Got my truck out for the first time this year too. Spring has sprung indeed !!!!!! |
04-07-2019, 09:43 PM | #458 |
laying low
This reminds me. My sister told me be careful of handling bags of mulch and potting soil. Someone she knows found a snake and eggs in a bag that had either a hole in it or had been previously opened.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-07-2019, 09:46 PM | #459 |
thats good advice ....getts nice and warm in them bags....
04-07-2019, 09:52 PM | #460 |
Had to buy a new tool. Astro 1442 Riv-Nut tool. This thing will come in handy! Installed my high hump.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
04-07-2019, 10:06 PM | #461 |
Active Member
Went to get knobs but left with manual column and the whole dash. Pumped on cluster with no cracks and throttle knob. Also, put two windows in the camper shell. Need to finish before car show next weekend.
04-07-2019, 10:10 PM | #462 |
that topper has really turned out nice.....real craftsmanship there..
04-07-2019, 10:51 PM | #463 |
Active Member
04-08-2019, 02:08 AM | #464 |
Topper Turned out real nice.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
04-08-2019, 06:32 AM | #465 |
Wow, great job on that!
04-08-2019, 05:48 PM | #466 |
New shifter for the 5 speed. Looks more 1967. I'm thinking it needs more character, maybe some sweeping bends.
Do it, Do it right, Do it right the first time |
04-08-2019, 06:04 PM | #467 |
After seeing your post, I ordered one of these too. I told my wife it was your fault.
04-08-2019, 07:31 PM | #468 |
New master cylinder on the 68 and adjusted the brakes. New motor mounts on the 72. Transmission guy called the trans is all ready to go. He had to change the front bearing again now the converter slides right in .
04-11-2019, 12:08 PM | #469 |
Dash installation is complete on the 71 K10 Cheyenne. New Saddle dash pad, new cluster housing, new heater ducting, new steering wheel. Factory tilt column cleaned up nicely. Doors are next, then carpet and I'll finally get the Truck World Super Saddle seat in it. Can't wait
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
04-11-2019, 12:19 PM | #470 | |
04-11-2019, 03:56 PM | #471 |
Drink holder doesn't hold my milk or my Vernors in a cold sleeve and needed a place for the phone.
04-12-2019, 06:25 PM | #472 |
Got my short block back from Schmidt Automotive today. I've been chasing a vibration in the GM crate engine every since I've had it. So I had them bore it .030, new domed pistons and new rods and bearings. Had the whole assembly balanced to boot. Old Red ought to run a lot better and have more oomph too boot. Raised compression from 8.5 to 9.4 with the domed pistons.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
04-12-2019, 11:39 PM | #473 |
I need more sound up front so I swapped out the old dead speaker for two 4". Then the old dead radio was in the way so, customized. Still need some brackets but it all fits. added another amp just cause.
04-13-2019, 08:54 AM | #474 |
Keep us up to date on this. What are you using for a head unit?
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
04-13-2019, 11:38 AM | #475 |
I added kick panels with speakers. Stereo is next.
