01-14-2017, 07:36 PM | #4851 |
Old member
Re: What did you do to your truck today? Chapter II
Another day another score! Picked up a bench seat and electric washer out of a Chevy truck for $100.00.
The seat has the arm rest in it and the one in my 71 was nice so I hope this one will seat good to. The seat will need to be cleaned good and the old took out. I need a couple of days to do it and the next few weeks are going to be full. So that's on hold for awhile. Got the jug mounted & wired but need the water hoses to complete. For the guy's who want to do this mod a little info on wiring. The pump is hot all the time. Run the red wire from pump to 12 volts. I placed a 20 amp fuse inline with it also. Run the ground to the dash switch and plug it to the inside wire on the switch. When you push the wiper button in the pump is activated. The switch has 3 wires connected to it with a plastic holder. 2 wires are side by side the inside one is the one you want.
01-14-2017, 07:52 PM | #4852 |
01-14-2017, 07:57 PM | #4853 | |
70+ ( Old Skool Club )
The seat color even matches your truck !!
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-14-2017, 08:15 PM | #4854 |
Old member
Yea well you all know I like red so it was a match in heaven for the Ramp Rat!
01-14-2017, 08:17 PM | #4855 |
Sprayed on some primer
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
01-14-2017, 08:21 PM | #4856 |
Old member
01-14-2017, 08:36 PM | #4857 |
Great score on the seat. Way back when I looked for that kind of seat for my truck, with no luck. I ended up scoring the Blazer Buckets that I have now though. Do you know what model truck that washer pump and reservoir came out of? I really seen the Blazer type but the one you show looks like it fits better
01-14-2017, 08:46 PM | #4858 | |
Old member
I know it's 89 are above because that's all he has.
01-14-2017, 09:47 PM | #4859 |
Having a senior moment...see next post
01-14-2017, 09:51 PM | #4860 |
The all velour with the stripes (that's how I've always refered to them) like these first came out in 1990 & lasted through 1994 when the new dash & seats showed up in '95. I'm entertaining the same seat in my '72....just need to find some of the elusive green stuff to make it happen.
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
01-14-2017, 10:50 PM | #4861 |
Went on a road trip to pick up a cab & fender for my 71. By some miracle i actually found a very solid cab on the east coast!
01-17-2017, 01:13 PM | #4862 |
Took Friday off and spent the 4 day weekend on the truck. Here's the short list of what I did...
Removed grill (replacement waiting in garage for sanding and paint) Removed, sanded, primered and re-attached both fenders and hood. Removed and replaced driver door. Sanded and primered passenger door (no need to remove, hinges are good enough for now). All new weatherstripping in both doors. Cut, scraped and wire-brushed off the old cab2door seal, replaced with push-on seals from 1st gen Dakota (works like a charm). Cut access holes into both side footwell vents and removed a few decades of debris (Jeez, wtf was GM thinking, making that debris trap with no easy access). Mounted new mirrors (year correct DG4 mounts with new elbows/heads) No pics yet, it was dark by the time I finished.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
01-18-2017, 10:04 PM | #4863 |
Got the son in laws cab back on the frame today. It's been a slow go but it's progress!!!
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
01-19-2017, 09:41 AM | #4864 |
I started a shortbed conversion several months ago, and today was the first time I've had the bed and wheels on the truck since shortening the frame. Much to my satisfaction (and surprise), everything fit perfectly!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
01-19-2017, 10:09 AM | #4865 |
Ordered my personalized tags
01-19-2017, 12:14 PM | #4866 |
RAT1968 '68 Cab/'71 Parts
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
01-19-2017, 10:54 PM | #4867 |
01-20-2017, 07:16 PM | #4868 |
Swapped out my leaky 18x10 wheels and tires for some 16x8 steel wheels with a set of 265x70/R16 tires! Also installed a cigarette lighter in the engine bay so I can finally use my rechargeable shop light since the wall charger crapped out.
01-20-2017, 07:38 PM | #4869 |
Nothing major for me but finally had a muffler shop make a fix for my slow to fill gas tank fill tube.
01-21-2017, 09:43 AM | #4870 |
01-21-2017, 10:16 AM | #4871 |
01-21-2017, 10:35 AM | #4872 |
I put the new flex plate and starter on. Went with the 98 delco truck starter.
I adjusted my head lights and and went for a cruise. |
01-22-2017, 09:21 PM | #4873 |
It works.
01-22-2017, 11:52 PM | #4874 |
My wife swept out all the leaves in the bed. She loves that truck as much as I do.
01-24-2017, 12:10 PM | #4875 |
I welded the right front spring shackle on my 67 K10 back together and ordered a new set. Finally my 45-50 mph shimmy is gone.
