09-24-2021, 04:59 PM | #26 |
BlahBlahBlah
Re: 1967-72 Chevy GMC Truck Door Handle Lock Gasket Set 68 69 70 71 OEM USA Material
I received mine today in the mail. There is no comparison to the other aftermarket ones Ive seen. These gaskets are great, no way I would pay the going rate for NOS when these are much better.
09-24-2021, 06:41 PM | #27 |
Junior Member
Much appreciated!
Seth |
10-06-2021, 10:57 AM | #28 |
I just have a simple question for Seth. How do you use these? I went to install handles today and thought that I would stick the gaskets to the handles first. But then the makers logos show up. So I am guessing you stick these to the door first? I can see how it would be easy to do with the big piece because you can slide it on to the handle and then put the handle on the door. But the little piece would require some accurate placement? I apologize if this seems like a dumb question. --George
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
10-07-2021, 08:40 AM | #29 |
Junior Member
You peel the thing that has the lettering on it off and they stick to the door or the handle either way but then I would stick it on the door and put the handle in it.
The makers Mark showing that's the sticker or the cover for the sticker that should be peeled off and then you stick the gasket on. Seth |
02-04-2022, 07:05 PM | #30 |
I will take 2 sets for 32 please
02-12-2022, 02:17 AM | #31 |
I would like two sets and I can pick them up, thank you.
Casey |
01-30-2024, 11:02 AM | #32 |
do you have the gaskets in stock?
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
Tags |
door handle, door handles, gaskets |
