Old 03-29-2007, 02:32 PM   #26
Sonny
Active Member
Re: Calling all LS1 converted trucks.
Jkade, got any pointers as to where you get your killer deals? I am looking for an LS1 or LS2 (basically 2002 or newer) with a 4L60E or 4L80E tranny. I need the whole package, wiring harness computer and all if possible.
Sonny
New Project: 67 Small window SWB
2006 Crew Cab Silverado LT
Sonny is offline   Reply With Quote
Old 03-29-2007, 04:04 PM   #27
jimmydean
jimmydean's Avatar
There was a complete C4 Corvette on Craigs List a while back with rear end damage for $5000. I think I will end up going that route and get all my suspension/brakes/steering/engine/trans in one fat package.
I figure if I make a couple bucks off what's left after I pull everything I need off, then it's a bonus.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-29-2007, 07:40 PM   #28
68 short step
c4= LT1 not LS1.
i totalled up my build so far (not including paint, and other smaller things)
and i have a little under 15,000$$ in it... and i think shiftys right, i dont even really take cost into consideration when i want/need a part....so i/you could do another swap (not a frame off) for around 5-10 grand....
heres some pics
http://67-72chevytrucks.com/vboard/s...d.php?t=195643
68 short step is offline   Reply With Quote
Old 03-29-2007, 09:08 PM   #29
jkade
jkade's Avatar
Originally Posted by shifty View Post
Like I said, if you want to do piecemeal, you can get a great deal. Me, personally, I don't want to futz with all that extra crap, I want something pre-assembled that requires little to no effort at all.
As a point of note, I bought an LS1 out of a TransAm WS6, aluminum block weighs much less than the LQ9 (LQ9 is beefier, steel, better for boosted setups).
LQ9 stock is rated at something like 345HP/380TQ, pretty sure the WS6 is 380HP/400TQ stock. I've seen at least one shop in TN that pulled just a nudge over 400 RWHP and 400 RWTQ out of a stock WS6 with no power add-ons at all...at the flywheel, those numbers would probably be closer to 430/430 or something.
Like I said, it's all in what you want. I'm not boosting, and I don't want to screw around with anything more than exhaust, a Z6 cam and springs to get into the 425HP/425TQ range and smoke the tires off most anything out there. You can screw around with your LQ9 and boost it later to catch up to me
Bottom line: I paid more for an assembled unit with more power and lighter weight that doesn't need any add-ons. You paid less for something you need to assemble with less power and more weight and can handle lots more add-ons.
Like I said, it's all in what you want. No single setup is perfect for everyone. You need to knowledgably sit down and decide what you want before you get it. I don't think it's wise for anybody who never deals with the GenIII setups to just go to the local junkyard and plop down $2k on something only to realize there was a much better option for their specific needs at nearly the same price.
Old man had lq9 with 243 heads, cam, ls6 intake, tune, t56 and 3:73 gears in his 69 camaro. My brother has a 01 ls1 with the same set up and 4:11 gears in his 69 camaro. The lq9 would smoke my brother's ls1 and the ls1 is bad as hell. Now a days everyone is going to lq9's becasue you can just flat out make more power with them, I have seen it in person. Me my self and I am sure there are others on here cant afford to buy a pull out ls1 and trans for 3 or 4 grand when you can piece one togther for half that. My brother also just put a lq9 and a t56 in his 99 rcsb silverado and it will blow your mind at the way it runs. You may be right and so may I. When I get mine going and you get yours I am sure we will run across each other somewhere and we will see since we only live a hour and a half apart and I go to a lot of shows in GA.
jkade is offline   Reply With Quote
Old 03-29-2007, 09:13 PM   #30
jkade
jkade's Avatar
Try car-part.com find one call them and haggle with them. A lq4 will in the end probably make only 20 to 40 hp less than a lq9. Buy one put a cam in it, ls6 or ls1 intake (ls6 is good for about 20hp more than ls1), get a quality tune, headders, and have a hella motor. I guess it's really not that simple but my old man has always been a big block man and says he will never fool with them again and he has built some wicked bbc's.
I know where there is a 4l60 for $500 if interrested.
Old 03-29-2007, 09:17 PM   #31
jkade
jkade's Avatar
Originally Posted by 68 short step View Post
c4= LT1 not LS1.
heres some pics
You are doing some nice work on yours and I can't wait to see it done.
Old 03-29-2007, 10:53 PM   #32
speed-racer
speed-racer's Avatar
In response to the radiator hose question........I used a radiator from a 95 chevy truck with a 4.3 v6 and the factory 5.3 liter hoses fit. The bottom hose had to be cut a few inches shorter. I do not have a/c right now, but I am adding it, so I swapped the v6 radiator for a copper radiator that fits the truck with smaller hose inlets. I will post the part number soon as well as some pictures of my swap.
speed-racer is offline   Reply With Quote
Old 03-29-2007, 11:02 PM   #33
shifty
Questionable
shifty's Avatar
I think I already stated that the LQ9 would outperform the LS1 built up! Stock for stock, out the box, the LS1 out of a WS6 is going to win over the LQ9, though
Like I said, if you're going to build up, the LQ9 is the way to go. I want balls right out of the box, and don't plan on doing more than a cam+springs from a Z06 in mine.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-30-2007, 08:27 AM   #34
jkade
jkade's Avatar
I guess I missed that.
I guess opinions are like a** holes everone has one. I see your point but I can't afford to agree with you
Thanks, Kade
Old 03-30-2007, 08:29 AM   #35
jkade
jkade's Avatar
Everyone that has done the swap please post pics!!!!!!!!! This is something everyone wants to see.
Old 03-30-2007, 11:00 AM   #36
jkade
jkade's Avatar
few pics I found on the site, I hope the owner doesn't mind.Name:  engine.jpg
Old 04-02-2007, 02:44 PM   #37
jkade
jkade's Avatar
bump....
Old 04-02-2007, 03:38 PM   #38
jkaylor68gmc
jkaylor68gmc's Avatar
I want one bad!
jkaylor68gmc is offline   Reply With Quote
Old 04-03-2007, 12:35 PM   #39
gringoloco
A guy with a truck
gringoloco's Avatar
Mine. "In progress", still collecting parts. There's a 6.0 under there somewhere, I promise...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-03-2007, 12:49 PM   #40
Mt Man Chad
Mt Man Chad's Avatar
Looks like some Prego Spaghetti Sauce would fix that right up with those many noodles, WOW thats allot of wires....
Are you sure there's is a 6.0 liter under all that???? LOL
WhewwwwwWeeee - looks like it will be fun project!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 04-03-2007, 03:13 PM   #41
Rascal_one2001
Rascal_one2001's Avatar
me and my brothers were gonna put a 6.0 in my brother skylark but after we got a regular truck one my brother said he wanted an aluminum so we grabbed him an aluminum one and then he turns around a buys a 455 for it and now my older brother and I are sittin on a couple 6 liters and not sure what to put them in since we put 5.7 vortec engines in our hot rods but mabe ill put one in my next truck but I hate all the wiring. good luck to everyone who is putting one in now and great job to everyone who already has one hooked up.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 04-04-2007, 09:31 AM   #42
jkade
jkade's Avatar
Are any of the 6 liters for sale????
Old 04-04-2007, 01:28 PM   #43
SchreinerM
Regardless of whether you have a LQ or LS engine, can the work be done the same? Meaning can the same people create a wiring harness, reprogram the ECU, etc?
Shifty, I'd like to go the same route as you with the T56. Time and money will tell.
SchreinerM is offline   Reply With Quote
Old 04-04-2007, 01:44 PM   #44
Frizzle Fry
Frizzle Fry's Avatar
Yes
Frizzle Fry is offline   Reply With Quote
Old 04-04-2007, 09:20 PM   #45
jkade
jkade's Avatar
This is what my motor is going to look like. I wish I could just take this one but my old man would beat me like a red headded step child Name:  Copy of kade 085.jpg
Name:  Copy of kade 086.jpg
Old 04-04-2007, 09:35 PM   #46
68 short step
why is the intake on backwards?
Old 04-04-2007, 09:45 PM   #47
jkade
jkade's Avatar
He likes to do things a little different. I like it myself.
Old 04-04-2007, 10:40 PM   #48
gringoloco
A guy with a truck
gringoloco's Avatar
I really like those valve covers. Do you have any pics of his coil mounting solution?
-Chris
-Chris
Old 04-04-2007, 10:44 PM   #49
jkade
jkade's Avatar
-Chris
Not really, he just made some brackets and mounted them on back of the heads and block.
Old 04-04-2007, 11:19 PM   #50
Frizzle Fry
Where did he get those valve covers? You can see in my pics that I have relocated my coil packs too. But I really like the CHEVROLET
