Old 10-20-2014, 02:25 PM   #26
UkMark
Re: Heater Hoses Mess..cry for help from the Uk
Quick thought ...the heat sender unit in the block is a single button one, is this correct for idiot lights or a gauge ( again it's not the original engine) I an reading on the board there are two types ...
UkMark is offline   Reply With Quote
Old 10-20-2014, 04:18 PM   #27
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Single button sender would be right but might not be the right resistance one. Have you actually put a thermometer on it to see if it's hot? That would be a good first step. You may be trying to trace a problem that isn't there while the sending unit is a problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-20-2014, 05:58 PM   #28
UkMark
I know right , waiting for a thermometer to arrive in the post , still over flows water though ....
Old 10-20-2014, 07:16 PM   #29
davepl
davepl's Avatar
I'm not sure if anyone was actually implying it, but just to be safe, the lack of thermostat or restrictor plate cannot and will not cause an engine to run hotter. That's an old wive's tale based on something about "coolant moving too fast to cool down" nonsense.
The thermostat is of course still needed, but as you likely know it's to bring the temp up to operating (whatever the set point of the tstat is) temp quicker.
On that old design with the bypass hose going to the radiator it'd seem to me that you're always going to be cycling some coolant through the rad, even when cold and the tstat is closed, so that design must take longer to warm up. Later designs still cycled it through the heater core, but not the radiator itself.
Anyone know why they did this? It clearly wasn't necessary as they later abandoned it. Unlike big blocks the small blocks already have an internal bypass that serves the purpose of the BBC bypass hose. I guess it'd help clear trapped air but at quite a cost, IMHO.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-20-2014, 07:33 PM   #30
Savidio44
Savidio44's Avatar
I think the heater bypass is causing the problem. Why is it bypassed? Does it leak? If not, why not hook it up to see if your situation improves. If not, it appears to me the heater is bypassed incorrectly. Run the hose currently running from the top of the intake to the top of the water pump. Pull the plug out of the top of the waterpump and install the correct size fitting to match the size of the hose. Block off the radiator port.
Savidio44 is offline   Reply With Quote
Old 10-20-2014, 07:56 PM   #31
68C15
blood type; Retumbo
68C15's Avatar
Thermostat upside down WILL make it act like a blown head gasket. The end with brass cylinder goes on bottom.
With no overflow reservoir you need the radiator to be filled 2" below cap when cold.
Fan blades should be half in shroud and half out
Cluster with light takes a different sender (actually a switch) than one with gauge. A gauge sender will turn light on with varying brightness (faint, but still varying) when used with light cluster
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-21-2014, 01:40 AM   #32
adricar1
if its not fitted, fit an expansion bottle. otherwise as previously stated the wate level should be left 3 inch down from the top of the radiator for expansion on the water. My rad cap i use is a 16lb cap, and expansion bottle, no problems with water coming out the rad. when it was not connected that was a different matter.
GMC K1500 1971 350 cu in th350 4wd
Bondo Bob c 10 1971 stepside th 350
c10 1970 350 cu in manual air con stepside.
adricar1 is offline   Reply With Quote
Old 10-21-2014, 03:48 PM   #33
davepl
davepl's Avatar
I've thought more about my blanket "missing thermostat can't cause overheating", and while it's an edge case, I should point it out because I missed it.
As we all know the lower rad hose is bigger than the top. This is avoid creating "suction" on the intake side of the water pump. Drop the pressure enough and the coolant would boil even at room temp, which is called cavitation (your boat prop can do the same).
The height (weight) of the water positively pressurizes the engine by a small amount. The water pump operating against a restriction (restrictor plate or thermostat) can create additional pressure. If you were right up against a cooling problem where the coolant was starting to boil in the heads, the extra pressure of the water pump working against a restriction might be enough to stave off that boiling for a few more degrees.
What the pressure amounts are and how much it increases the boiling point and whether any of it actually matters I don't really know. But I figured I'd point out my own error. Still, though, there's no such thing (within reason) as water going through the cooling system "too fast".
Ideally as you stress the cooling system you want the coolest fluid possible in the block. The coolest fluid can be found at the bottom of the rad, so the sooner you can pull that in, the better. The sooner you can get the hot fluid back into the radiator out the top to make room for cooler stuff to enter, the better. You still always have coolant in the motor at all times either way, and its speed doesn't affect its ability to pick up heat, so the only variable is how cool the coolant is. Slowing it down only means hotter water in the block. Extrapolate that as far as you can towards infinite flow with no viscosity or cavitation (which happens with hydrogen or helium near absolute zero, but not relevant here) would be ideal. Stopping coolant flow altogether would be the worst case.
Old 10-21-2014, 04:36 PM   #34
UkMark
Heater core was leaking and a new one is finally in route to me , gonna hook this up lower the water level an inch , replace the rad cap to 7 bar , flush it out and fingers crossed .
Old 10-21-2014, 04:37 PM   #35
davepl
davepl's Avatar
7 bar? That's 101.5psi. You'll need some serious hoses, that's for sure.
Old 10-21-2014, 08:33 PM   #36
mechanicalman
Had a car come in, complaint was "heater stops working on highway, but works well around town".
Electric fans.
Replaced MISSING thermostat, problems solved. Fans were regulating engine temp around town, too much airflow on the highway. No overheating, just "underheating".
When I break in a rebuilt engine, I use an old thermostat with the guts torn out to make a restriction so that it does not form air bubbles or heat up rapidly. I do this because I like tight piston to wall clearance and figure if I'm going to bite a piston it will likely be during break-in. After the cam is broke in I'll put a thermostat in it and break in the valve springs. Won't lean on it till after the first oil change.
Mom said I'm a little "windy"?
mechanicalman is offline   Reply With Quote
Old 10-22-2014, 09:53 AM   #37
Lippyp
English Chevy Owner
Lippyp's Avatar
Originally Posted by UkMark View Post
"Airspeed" there are a handfull of stores but most are aimed at tuning not "oe" , can be hard work to get what you need ...
Theres a good few specialists that keep all the normal service parts in stock in the UK, people like US Automotive, WASP etc. Failing that Rockauto will ship to the UK but beware of shipping costs mounting up as they will ship items from multiple warehhouses. There are even places in the UK that you can get OEM AC DElco stuff from, people like Bauer Millets in Manchester and a couple of others but be prepared to pay a premium. If you want specialist parts Wes at Classic Heartbeat has always been great to deal with over the years for me.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 11-15-2014, 12:56 PM   #38
UkMark
just got back from a buying trip in Europe, quick fiddle with my new temp gun and the bloody thing is not overheating at all.
The button sender/switch on the block is for a gauge i i think, and its wired to an idiot light since the engine swap which is clearly showing hot when its not.
dont really want to add gauges inside, so guess i need to swap the switch/sender out on the block to a two prong version to switch the idot light properly..is that correct?
the only headache is the only wire remaining in the green one, the other red wire needed for the sender is cut back.
Old 11-15-2014, 05:01 PM   #39
TheSeeker
I think my heater hoses are backwards. Top to top and bottom to bottom. The heater gets hot but what is the adverse effects of having it hooked up this way?
TheSeeker is offline   Reply With Quote
