#26 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: 3.8 volts brown wire at alternator ???
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 01-06-2020 at 12:51 PM. |
#27 |
Thanks. The person who did my harness said do not mess with the wires from the alternator to the PCM and strongly recommended to not use the old wiring system. He said he has done a few C10 trucks with the LS terminal block at the alternator and had no problems at all, except for the "ammeter" not working and said to get rid of it as it's a fire hazard and replace it with a volt meter. I might go this route to get it running as I don't want to mess with the PCM on my own and keep researching...
#28 |
Msgt USAF Ret
Well you are certainly within your right to use whatever choice you want to make to wire up the charging system. I did not say that using the PCM was wrong in fact if the alternator is a newer model it relies on the PCM to regulate the output voltage. If the alternator is older then it might not work because the regulator is inside the alternator and it would need to have the S pin wired so that the regulator could sense the system voltage and adjust the field strength as needed.
I still think the ammeter would work if the system is wired properly. I strongly disagree with the statement that it is a fire hazard. The older model trucks Pre 1963 used an amp meter which had all the system amperage ran through it and I believe your wiring guy is referring to that style. The 63 and later models were changed by the factory to avoid the fire hazard, and that style was replaced by the one you have. It only uses a small amperage and voltage to work and it is fused. It is sometimes confusing when it comes to mix and matching new and old, and different systems some things work great and others may not. Good luck to you and let us know how it works out.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#29 |
I know, and I appreciate that... I'm just nervous about messing up the new system since it's more automated than the old. It is a 2001 LQ4, so from your previous post would not need the S wire as the PCM would monitor that I think anyway. Just need to ensure I have power to the firewall and figure out how to make the ammeter work with the new system.
#30 |
Here's how I ended up wiring everything and all gauges work, including ammeter... Thank you VetteVet for going back and forth with me to figure this out.
