Old 10-29-2014, 07:23 PM   #26
riceranch
Re: Disk Swap on an Eaton HO52
Thank you so much for posting this, I'm in the midst of sorting out the rear brakes on my newly acquired K20 3/4 ton suburban and am coming to the conclusion that I'll be doing this prior to finding a decent set of rear drums for the HO52 that's in the rear.
riceranch is offline   Reply With Quote
Old 10-29-2014, 10:52 PM   #27
whitedog76
A rotor from a 2003 and newer van/2000 and newer truck will slide over the hub of early HO52s with the front mount drums. Not for sure on the rear mount drum hubs.
I've been working on a disc kit with components from an 03 van. The only real obstacle I've encountered is finding a machine shop that will cut some flanges for me. I'm almost to the point of buying some plate steel and a bunch of hole saws and doing it myself.
All the components are also availible from GM and are priced reasonably. BTW-the truck brakes are priced better than the van.
Here's what it looks like.
http://s1074.photobucket.com/user/wh...tml?sort=6&o=1
whitedog76 is offline   Reply With Quote
Old 06-18-2016, 02:20 PM   #28
ChrisWhewell
ChrisWhewell's Avatar
Awesome, so GM has a retrofit kit ? I'd like to know more. My 67 k20 needs rear brakes. I notice Eckler's sells drums and all the other stuff, but is it better maybe to go with a GM kit and switch over to discs on the rear ? Or should I just keep them drums on the rear ? I do use the truck to tow if that matters
'67 K-20 longbed 4X4,
350, SM-420, Vortec heads,
flat top 4-brow pistons,
Eaton 4.55's, Qjet,
MSD 8365, Comp XE250H,
Dynomax duals
ChrisWhewell is offline   Reply With Quote
Old 06-19-2016, 09:55 AM   #29
Tdrcreyn4
Tdrcreyn4's Avatar
Great post!! Thanks!!
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 06-05-2019, 02:58 PM   #30
USAF
Originally Posted by budbeater View Post
Step Fourteen: Attaching the Hoses, Bending new Brake lines
Coming soon...
Budbeater, how did you connect/run your brake lines?
1972 K20
2004 Chevy Aveo
2011 BMW X5 Diesel
2018 Chevy Silverado Diesel
U.S. Air Force Retired - 1983-2017
USAF is offline   Reply With Quote
