03-14-2006, 11:55 AM | #26 |
Re: Finally started my x member chop
Looking good, but I noticed one thing about the rack. You need to have the arms of the rack parallel to the lower control arm as much as possible. If they aren't your going to get bad bump steer. If you hit a big bump in the road you better hold on for the ride.
Later Jr
Please become a site supporting vendor to advertise a business in your signature. you can do so here |
03-14-2006, 10:32 PM | #27 |
Hollister Road Co.
At ride level they are actually pretty close to parallel. I had an issue with the lower control arm hitting the anchor bolt of the rack. If I get to much bump steer I will have to modify the lower arm and move the rack down more.
03-15-2006, 12:28 PM | #28 |
www.73-87chevytrucks.com
That looks very familiar. There is a way to cut one where there isn't large gaps to fill though... Looks good anyway.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
04-01-2006, 09:38 AM | #29 |
PROJECT 7DEUCE
Chris what tips do you have for me on cutting a 2nd one with out all the gaps as they are a very time consueming to fill I may have this one sold to a guy at work and I have another crossmember that needs to replace this one... Need to get a few pics from friday loaded up,just have to make it all look pretty and should be good to go..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-01-2006, 10:21 AM | #30 |
PROJECT 7DEUCE
04-02-2006, 08:33 PM | #31 |
Hollister Road Co.
That came out good. You can see the directions for doing it like chris did on his site.
http://www.captkaoscustoms.com/suicidal.html |
04-02-2006, 10:07 PM | #32 | |
Seņor Member
04-02-2006, 11:27 PM | #33 |
PROJECT 7DEUCE
1 1/4 cut..
06-17-2006, 02:13 AM | #34 |
PROJECT 7DEUCE
Great news after 2 months of being on the back burner its finally done and I just bought the por-15 for it should have it done saturday maybe I ll do it beofre I rewire the truck..
06-17-2006, 07:56 AM | #35 | |
Seņor Member
06-18-2006, 01:01 AM | #36 |
PROJECT 7DEUCE
Heres the pics of the finished crossmember just have to por -15 it sunday right after I finish rewireing the 63
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 06-18-2006 at 01:03 AM. |
06-18-2006, 11:48 AM | #37 |
About time!
Kevin LFD Inc. I still need to start mine |
06-21-2006, 11:33 AM | #38 |
PROJECT 7DEUCE
Done finally nice and shiny!!!!!!
06-21-2006, 03:41 PM | #39 |
Crossmenber looks good, i like that, dont know if Ill do mine. Still thinking about it.
06-21-2006, 06:00 PM | #40 |
Did you test fit everything together before final smoothing & color?
06-21-2006, 06:23 PM | #41 |
PROJECT 7DEUCE
Yep I test fitted it on another frame that I have .......
06-21-2006, 07:39 PM | #42 |
Hollister Road Co.
good job
06-21-2006, 08:21 PM | #43 | |
I'm curious what parts combos allow the more aggressive amount of drop. It looks like you didn't have to trim the front lip of the c-member. Could you list what parts combo your using? Mine is: 68 frame 68 man steer gear box 68 man steer pitman & idler 73-up outer tie-rods 71-72 inner tie-rods 72 drag link 75 c.member w/the larger dia. u-bolts/holes 73-up drop spindles ART arms
06-21-2006, 08:42 PM | #44 |
PROJECT 7DEUCE
SCOTI Sorry to confuse you all I have done was to bolt it to the spare frame I had to make sure it was still wide enough and that the bottom bolt holes lined up.. Has anyone else had the problems that scoti is talking about???
06-21-2006, 08:46 PM | #45 |
PROJECT 7DEUCE
Hey scoti did you section the crossemember like I did or did you cut away just where the frame goes?????
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 06-21-2006 at 08:50 PM. |
06-21-2006, 10:14 PM | #46 | |
06-21-2006, 10:35 PM | #47 |
Sold! 2 days after finished
I did mine 1.125 and I had a ton of grinding to make everything clear and its still close.
06-21-2006, 10:40 PM | #48 |
just wondering, its only if i want to body drop my truck that i would have to section the cross member
06-21-2006, 11:36 PM | #49 |
PROJECT 7DEUCE
Seems like its always something one problem leeds to another...
06-21-2006, 11:59 PM | #50 | |
I don't plan to go any lower, I just wanted the additional road clearance the notch offers.
