Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-08-2006, 04:47 AM   #26
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: stereo speakers...where to put them?
Just sourced a used second amp yesterday to run the fronts, its a mac attack 4075, a good quality german made amp quite popular at the lower end of the market here in the UK. Its a four channel amp but I'll probably run it bridged to give 2 x 230W. Just keeping an eye out for a decent used set of component speakers for the front now!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 03-08-2006, 10:17 AM   #27
Dennisthemenace
Dennisthemenace's Avatar
Look at this guy's set up
Please excuse me for my bad English writing I'm Dutch
The land of $6.65 for a gallon of gas
Dennisthemenace is offline   Reply With Quote
Old 03-08-2006, 10:22 AM   #28
HotRod71
Short, Fleet, Slammed, V8 Club
That is a awesome looking setup. Nice fab behind the seats also.
71 Chevy SWB Fleetside (WIP)
www.4x4grace.com
HotRod71 is offline   Reply With Quote
Old 03-08-2006, 10:43 AM   #29
roughedup72
roughedup72's Avatar
Hey Tim,
Go with the boxes under the seat, Your truck is to nice to cut up the doors, The tweeters on the dash make it sound great because you get your high notes and they reflect off your windsheild,best of all you can get the little surface mount tweeters and place them just about anywhere. I woud also check out custom audio in lexington to see if they could come up with anything. What kind of head unit did you get. Call me, Troy.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 03-08-2006, 04:08 PM   #30
Edmond
Edmond's Avatar
Dennis,
Is that your truck?
Anyway, It looks awesome!!
Cya,
Edmond
Dutch Longhorn
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
Capelle a/d IJssel,
The Netherlands
Edmond is offline   Reply With Quote
Old 03-08-2006, 04:32 PM   #31
Dennisthemenace
no i wish it was. It's from another member from this forum called jerald jeffers.
Old 03-16-2006, 02:08 PM   #32
RED71CHEVY
RED71CHEVY's Avatar
how many tweeters should i run.......one above each side air vent and two at the rear view mirror (total-4)........and how about speakers......i have been looking at POLK MOMO 5x7 in boxes under seat for bass,,,, and 5.25" components at the kick panel with their tweeter at/above the side a/c vents then two additional tweeters at the rear view mirror????.........help
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
Old 03-16-2006, 02:23 PM   #33
matthufham
is your cab painted? i welded the rear cab corners shut with sheet metal and cut a hole for a 5"X7". i don't think a 6"X9" will fit. later i'll carpet them over.
matthufham is offline   Reply With Quote
Old 03-16-2006, 03:08 PM   #34
cstanley
cstanley's Avatar
has anyone done a nice install (tweets, maybe) flush-mounted into that steel panel that runs across the back below the window? i could imagine that would be nice.
cstanley is offline   Reply With Quote
Old 03-16-2006, 08:30 PM   #35
76bonanza
76bonanza's Avatar
Anyone have any idea how much depth there is behind the kick panels that the vendors sell(Max depth for speaker mounting?)
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-17-2006, 01:54 AM   #36
randomhero472
randomhero472's Avatar
i got mine from kenny's trucks in oklahoma, had 2" top mount depth, i just put a set of polk db 6.5" speakers, they sound great.. i'll get a pic up here in the morning... the panels were 65 bux w/o speakers
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 03-17-2006, 08:54 AM   #37
76bonanza
76bonanza's Avatar
can you still operate your high beams?
1968 c10
lowered 3" 4"
Old 03-17-2006, 09:15 AM   #38
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Does any one no where I can get a speaker to fit my cover it is a 4X10 for the original radio.
Gary 70 Jimmy is offline   Reply With Quote
Old 03-17-2006, 12:50 PM   #39
randomhero472
yea, the panel's are about 1/2" thick black plastic, high beams can be reached just fine.. i'll get a pic in about 1 hour
Old 03-17-2006, 12:51 PM   #40
randomhero472
try crutchfield.com, if not im sure you could use a 4x6 and fab up a plastic mounting plate
Old 03-17-2006, 03:08 PM   #41
randomhero472
nothing fancy but these polks sound great, perfect depth
http://i28.photobucket.com/albums/c2...Picture013.jpg
http://i28.photobucket.com/albums/c2...Picture012.jpg
Old 03-17-2006, 03:20 PM   #42
cstanley
cstanley's Avatar
i think pioneer actually makes a pair that are made to fit our dash. several others are made as well. pretty much all of the suppliers who carry the custom autosound stuff have 'em. also, you can get a stock 4x10 from wal-mart for a few $
many manufacturers still make 4x10s. it'd prolly be better to get the pair designed for our bracketry, though. i haven't heard them, but it's the route i'll eventually go.
Old 03-17-2006, 05:34 PM   #43
Gary 70 Jimmy
The speaker has to be 10 OHM or it will burn up the original radio. I did a search with google and I found some one that would rebuild mine for $45.00.
Old 03-17-2006, 07:41 PM   #44
KFreddy
Active Member
KFreddy's Avatar
GM 10 ohm speaker here on Ebay. If you only need one I'll take the other one.
http://search.ebay.com/search/search...ohm&category0=
-Fred
KFreddy is offline   Reply With Quote
Old 03-18-2006, 11:52 AM   #45
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I made a set of boxes with 8" subs and amp to put under my bench seat, which thumps your butt pretty good. And built a custom center console to mount the cd player and some 2 sets of 2 way mids and tweets. It sounds good, all for about $500. Click on the link in my sig and check out my 72 GMC truck pics.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-24-2006, 02:05 PM   #46
Lippyp
English Chevy Owner
Lippyp's Avatar
I still say, in an area as small as a truck cab you just need a sub, amp and decent set of components up front to get a fantastic sound. I'll let you know what mine sounds like when it goes in. I'd keep the tweeters and fronts as far up front as possible. The way someone explained it to me is you don't go and sit with your back to the band at a concert, so why do you need rear speakers? If the front soundstage is setup properly you'll not need them.
Phil
'67 C10 long fleet.
Old 03-25-2006, 09:34 AM   #47
Gary 70 Jimmy
-Fred
I wish I could have seen those before I sent mine out to get rebuilt
Old 03-25-2006, 01:02 PM   #48
Brad
Out of the carpool lane.
Brad's Avatar
It appears this person is in Oregon. I've got an email to him now and if he's somewhat close by to me, I'll pick up a few for board members.
EDIT: He's clear across the state from me so I can't do it.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-25-2006, 10:29 PM   #49
aitch
aitch's Avatar
Anyone know where Jerald Jeffers (the truck that Dennisthemenace posted) got those kick panels with the tweeters?
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
aitch is offline   Reply With Quote
Old 03-26-2006, 12:26 AM   #50
subtle71
Granddad's Ol' Truck
subtle71's Avatar
Originally Posted by randomhero472
Go Team!! Just a recommendation... If you put sound deadening material, like Dynamat, on the back of those ABS plastic panels and the metal area that the panels mount to, you will get an ever better sound out of your speakers.
1971 Chevrolet Custom 10 short step-side
2005 GMC Sierra SLT 2500HD crew cab 2wd
[I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side
subtle71 is offline   Reply With Quote
