02-08-2007, 11:32 AM | #26 |
polishing a turd
Re: Hydroboost on a 58 -59 3100
do you have any measurements on the bolt spacing of the mc and booster mounts for the silverado hydroboost unit?
thanks
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
02-08-2007, 03:21 PM | #27 |
Hollister Road Co.
do you mean spacing where it bolts to the firewall or the master to the boost unit or both?
02-09-2007, 12:52 AM | #28 |
polishing a turd
both, if you don't mind
02-09-2007, 10:19 PM | #29 |
Hollister Road Co.
I'll measure it and let you know.
02-10-2007, 12:26 AM | #30 |
Hollister Road Co.
I don't know who did this picture but it does have the measurements on it.
I'll get the other as soon as I can |
02-12-2007, 10:41 AM | #31 |
polishing a turd
thanks
02-11-2012, 11:25 PM | #32 |
dwcsr,
I know this is an old thread , but info is good. Will that master and cap(Raybestos # MC390542) fit under the cab or will it rub the floor? I cant look under the truck right know. |
02-11-2012, 11:55 PM | #33 |
Hollister Road Co.
Its tall so I would think it may hit the floor. There are shorter reservoirs you may have to do a little junkyard crawling to find out what vehicle will work best
02-12-2012, 01:45 PM | #34 |
nice write up dwcsr
shawdow: look in my build thread to see how i did an under floor hydroboost with remote reservoir.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-10-2024, 03:48 PM | #35 | |
Junior Member
04-10-2024, 06:23 PM | #36 |
go get one off of or for a panel van or 3/4 that has disc in front and drums in rear. it will handle it correctly then. Make sure you put in residual valves unless the master you bought has them built in. 10lb for drums 2lb disc up front if you your are frame mounted..
I did this setup in my 56 |
04-10-2024, 08:08 PM | #37 |
Junior Member
I have a setup from a 2001 Silverado, same part numbers as dwcsr in his write up. He also mentions in his write up something about master cylinders having different metering valves. I found a YouTube video speaking to this at 1:50 mark. Like I said, I have a disc/disc setup, so was wondering about this proportional valve on the side of the master cylinder. Not the metering one, but the one on the hydroboost setup as the video eludes to.
04-10-2024, 08:48 PM | #38 |
Metering and residual valves are the same thing that’s your 2 pound and 10 pound valves to keep pressure on the brakes when the master is on the frame.
A proportioning valve is just that it does not have a different name Some master cylinders have the residual valves built-in. You should see it just inside the port. Some modern proportioning valves off of GM trucks and cars have a combination valve where it’s both are proportional, and a residual all built in together |
04-10-2024, 08:52 PM | #39 |
So if you have a combination valve that came with your set up and it’s a disk disk, and the residual pressures will be too light for the drum on the rear
04-10-2024, 09:01 PM | #40 |
Junior Member
I was watching a video on proportioning valves, now I'm in the know! They are really not proportional at all but a relief valve. Drum brakes are extremely efficient at applying stopping power on little pressure where as disc brake requires much more pressure to apply stopping power to its disc. The relief valve in a drum setup is used to release pressure at a set point as to not "lockup" the wheel by the person applying the pressure and potentially losing control of the vehicle. The disc setup requires more pressure, like 10 x the amount a drum requires for the same stopping power, so there is not really a requirement for a relief valve on disc setups. This is as I now understand it. Please correct me if I'm wrong. Thanks
I'm just adding to my post so its clear, the idea of the metering of pressure is so the rear brakes have pressure when stopping, if they don't and all the pressure is applied at the front, then there could be some ass passing ground looping happening. Last edited by SARBlade; 04-10-2024 at 09:12 PM. |
04-10-2024, 09:23 PM | #41 |
for some a metering valve in this definition just holds pressure to keep the fluid from flowing back to master when no brake pressure is applied. It does not “meter” or change pressure to the brakes when applying pressure. You don’t need them as much when mounted on fire wall as this is above the brakes and fluid flows down. This keeps air from entering system when brakes are not applied. They are also call residual valves for residual pressure.
Proportions valves do what you posted keeps different pressures Proportioning valves are frequently used in cars and other road vehicles to reduce the brake fluid pressure to the rear brakes. Due to weight distribution during heavy braking, more pressure is needed for front brakes. A proportioning valve reduces the pressure in the hydraulic lines to the rear brakes relative to that supplied to the front brakes during this heavy braking. A combination valve does both and what most modern cars have that need them and it looks like a funny shaped brass hunk of metal. The problem is most YouTube. Guys call the combination valve a proportioning valve. When it may be doing both and not one function. They make modern ones that just do the proportions. And most don’t know that metering and residual are one and the same. Last edited by Hcb3200; 04-10-2024 at 09:32 PM. |
04-10-2024, 09:30 PM | #42 |
I will say metering is used to describe what the proportioning valve does as well. But so many have mixed and match metering combination proportioning and residual that finding a clear and concise answer is frustrating. But the three functions needed for brake systems are definitely needed not mater what you call them. I had same issue when i did my truck just making sure my combo valve as just that a true multi function valve. .
04-11-2024, 01:28 PM | #43 |
Junior Member
Thanks Hcb3200, you're right, a name by any other name is still a name, function matters. In my case, If I keep all components the same from the same donor, all should work. If I was piecemealing things, then I would need components that compensate for each other. The more I go down the rabbit hole the more I understand. A confusing time is through the 70's when brake components all went some kind of change, from brass blocks to separate portioning valves, to ABS, etc. Now everything is pretty much right at the master cylinder.
