07-03-2006, 11:55 PM | #26 | |
Re: Back-half, Corvette C4 in 69
I have not measured the max width tire/wheel combo we can fit back there yet. The new bed-sides and bed pieces will be here next week. I do know that I am running a 295 40R 20 on the blue 55 with a 20x10 and 7" backspacing. At full dump the tire is 1/16" (and that's a generous spec!) away from the stock upper link mounting bolt (the tires toe-in hard at full dump). We will be building our own links on this truck to make clearances a little more acceptable! Advantages to an IRS are all performance. It's true that a strait-axle can handle exceptionally well if set-up properly, but the function of an independently suspended rear is obvious. Advantages are gained in cornering, each wheel is allowed to react independently. As for bed floor clearance, the top of the framerail (2x4) sets 4" above the stock bed floor, and the frame lays on the groud with a 29" tall tire (to achieve this, new tie-rod links are made that relocate to the bottom side of the spindle, or rear hub, whatever you want to call it. If you want to keep stock tie-rod linkage, notch the frame a little, or move the whole thing up an inch). One main advantage to those of us who are afraid of heights and like to minimize the space between our frame-rails and the pavement is that the rear wheels camber in during bump (compression). This allows more clearance at the fender lip, minimizing bed hacking, and maximizing tire width! Besides, how cool is it when all four wheels are cambered in at full dump!!!! |
07-04-2006, 12:01 AM | #27 | |
The rear-end is not narrowed. These suspensions do not lend themselves to being narrowed. It causes some major changes in the suspension geometry. The rear frame-rails do need to be narrowed. As for track width, I have those measurements at the shop. All the specs you will find on-line are from tire center to tire center, I have the hub to hub measurement at the shop, and will post it up on Wednesday. (I should know it by heart, but with so many measurements to remember, I just memorize where to find them, not what they are!) |
07-05-2006, 11:12 PM | #28 |
The C4 rear end measures 63.5" from hub face to hub face (this is with the rotors in place).
07-06-2006, 07:03 AM | #29 |
Where are the new pic's I am starting to get the shake's and need a fix
Will a C4 front set up allow you to go as low as your drop member? Are their any advantages to it over the drop member other than all alum and much better brakes. I would think having matching brakes would make things alittle better for master cyclinder set up. Kevin LFD Inc. |
07-06-2006, 11:14 AM | #30 | |
Meet me in the alley behind the liquor store on 3rd and Oak... I will be wearing a red baseball hat and white Reeboks. I just unloaded all the new sheetmetal for the truck yesterday afternoon, and will be working on it again next week (late in the week). I have too many irons in the fire right now and am trying to keep everybody happy! As far as C4 up front there are some performance advantages to it. The design produces more camber gain and has a lower roll center than the truck front ends (dropmember included). Brakes are also a little better. Unsprung weight is greatly diminished due to the aluminum construction. As for allowing for the same drop, I am pretty sure it can lay frame and still have a 4.5" ride height, that's how I set em up on the 55-59 trucks. The only draw back is the difficulty in retro-fitting a C4 suspension to these trucks (63-87), not the price of components. A complete front end for the 88-96 Corvette can be found in wrecking yards for $800-$1100 in fairly good shape (you can then sell off the parts you don't use to re-coup a little cash). Tube arms, drop spindles, and new brakes will set you back beyond that price. True, it is by no means "cheap or inexpensive" and there may be some wear parts that need replaced, but it still probably isn't as expensive as most people might assume. I am working on a C4 bolt-in front end similar to the dropmember for 63-87 trucks... maybe it will make it a possibility for more people?????? Last edited by PBFAB.COM; 07-06-2006 at 11:16 AM. |
07-06-2006, 01:35 PM | #31 |
I love your work!
Please become a site supporting vendor to advertise a business in your signature. you can do so here |
07-06-2006, 03:09 PM | #32 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
07-06-2006, 05:14 PM | #33 | |
:mp: Last edited by onehot69stepside; 07-06-2006 at 05:14 PM. |
07-06-2006, 06:55 PM | #34 |
soon to be bagged64sub
I am very impressed. Its about time we see someone doing bad ass work and still putting the frame on the ground.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
07-06-2006, 08:12 PM | #35 | |
I do appreciate all the interest and compliments on the work, I take pride in what I do, and it's good to hear when people acknowledge it. Just don't get too carried away, I wouldn't want my head to get too big! |
07-06-2006, 09:49 PM | #36 | |
07-09-2006, 01:42 AM | #37 | |
I don't know why I didn't think of this earlier, but one huge advantage of using an IRS like this C4 is the fact that the driveshaft stays stationary as the suspension goes through its travel. One huge obstacle when putting any vehicle on the ground (when they are equipped with a straight axle) is having to clearance everything for the driveshaft. And Kevin, the step in the framerails are LESS with the C4 than a straight axle (by at least 4"), minimizing the amount the floor will have to be raised. You were right the whole time ! |
07-09-2006, 04:24 AM | #38 |
Your fab work is incredible and this is from a guy that is EXTREMELY picky. You do incredible work. Keep us all inspired please as you build your customer's trucks.
07-10-2006, 11:56 PM | #39 |
Did some more welding on the frame today, should have it all back together tomorrow.
07-10-2006, 11:57 PM | #40 |
a couple more.
07-11-2006, 12:48 PM | #41 |
Does anyone know how much a junk yard C4 rearend runs. I am thinkin about trying it myself if I can find one for fairly cheap.
07-11-2006, 07:37 PM | #42 |
Show off!
Kevin LFD Inc. |
07-12-2006, 01:40 AM | #43 | |
07-15-2006, 10:51 PM | #44 |
PROJECT 7DEUCE
Nathan congrats on the truck feature in classic trucks... Very nice work..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-15-2006, 11:19 PM | #45 |
Drillin oil on American Soil!
i think that looks awesome. being someone who works in a fab/weld shop, i know quality when i see it, i also love the look of those welds, i didnt see one bad one.
Travis 70 Chevy c20 2wd 75 Chevy k10 4x4 parts truck 92 GMC Sierra c1500 2wd DD 99 Chevy Reg Cab Sht Box 1500 2wd 05 GMC Sierra Denali white |
07-16-2006, 01:51 AM | #46 | |
07-20-2006, 07:21 AM | #47 |
67-72 Addict!
Can't wait to see the finished truck!. I just saw a cool 68' truck today on Craigslist that used a C4 rear under a modified 88' bed.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 07-20-2006 at 07:21 AM. |
07-20-2006, 10:42 AM | #48 |
awesome work!
a little hijack...would there be any advantage to going IRS on a mostly stock truck, daily driver, never intended on bagging (or really any substantial lowering?) the cool factor would be way on up there, but anything else gained? cornering, ride, clearance, etc? also, would a lot of load (weight) capacity be lost?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
07-20-2006, 03:19 PM | #49 | |
The cool factor would definitely be raised up a notch! As far as performance gains... there would be some, but to achieve the greatest gain, the truck would need to be lowered significantly. If you intended to leave the truck at a stock height, or slightly lower than stock, you would notice little gain in performance The load capacity would be diminished, but using a coil-over instead of the monoleaf would help. |
07-20-2006, 04:22 PM | #50 |
The LuvShack Garage
Not to sound gay or anything, but will you marry me, I need your help
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
