Old 03-31-2009, 10:10 AM   #26
RckyMntnKng
RckyMntnKng's Avatar
Re: My Build Thread (year+) on 71 Jimmy 4x4
Well, I tend to like body lifts as part of an overall lift.
They dont raise the center of gravity as mush as a equal size suspension lift.
They dont change steering geometry or driveline angles.
The truck needed new polys anyway, and the body lift kit w/bolts is cheaper to buy than trying to just find the right size bolts alone for the poly.
Im having tube bumpers made and this way they wouldnt need moved up later if I decided to someday do a body lift.
The 36's are temporary as rollers while I work, I just ended up with them when I bought the rims, so I figured I needed more than just the 6" suspension lift.
Is there something wrong with BL's?
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler
RckyMntnKng is offline   Reply With Quote
Old 03-31-2009, 10:30 AM   #27
Jtrux
I'm a poor spectator
Jtrux's Avatar
Are you running a D60 or D44? In this thread you say D60 but in your other thread you have a rebuilt D44 from a 71 K20. What are you going with??
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 03-31-2009, 10:38 AM   #28
Burt4x4
Burt4x4's Avatar
A BLift that is installed properly will work fine.
There is a buzzz out there in the off-road community that sends negative vibes out to the body lift gods...not sure why?
Center of gravety issue? Mee think No, I have been in many 'pucker factor' angles on the trail and survived from tippin over..
All I know is I have been wheeling with a BLift on my K5 for hmmmmm 16yrs now. I have never ever not even one time had an issue with them
More
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-31-2009, 11:29 AM   #29
RckyMntnKng
Center of Gravity stays lower with a body lift.....
Rather than moving the whole truck, motor, tranny etc up with a spring, you are only moving the body up....which has to be like 1/3 the weight or less.
The real downside is you dont gain any ground clearance on the running gear other than the tire size change you can now clear will gain you a couple inches on the ground.
My axle story is convoluted I know...I have access to several sets that Ive decided on one way and changed my mind the next.
Im really tempted to drop that dana 44 into it from the 71 k20 due to the myriad of other things like ease of steering and cost...but I keep thinking I'll kick myself later if I dont just do the D60 front. Im not sure I will wheel it hard enough to break things on the 44 if I build it right and mostly use it as a daily driver and camping rig. My max tire size will be 37 x pretty wide.
Old 03-31-2009, 05:04 PM   #30
vtblazer
vtblazer's Avatar
Some like em, some don't.
Was just curious about all that uneeded lift to run 36's but you explained that, so now I understand more better...
vtblazer is offline   Reply With Quote
Old 03-31-2009, 05:30 PM   #31
RckyMntnKng
No prob!
In your experience VT, how much lift could flex out 36x14.50's without trimming?
Right now I think im at 5", because it looks like the PO has a 2" suspension lift under it, unless rear blocks are stock.
If you know anyone who wants to trade me a set of 4" springs for a new set of four TC 6" springs Ive got, let me know :-)
-RMK
Old 04-01-2009, 06:10 AM   #32
vtblazer
vtblazer's Avatar
No prob!
The general consensus is, if you wheel with 35/36 inch tires you'll need and be fine with a 6" lift.
Our year trucks have their demons though, that 'fang' on the front fender can really get in the way.
Are you going to move your front axle forward?
Another point of contact is the rear of the front fender while turning/flexing.
Only thing now is...will those 36's look lost with 9"s of lift?
Old 04-01-2009, 10:26 AM   #33
RckyMntnKng
Thanks VT...
Yes they will look lost on 9", you bet. My original plan (when I was ordering parts) was to go much bigger on the tires, but now I just don't want to take away the daily driving fun i could have with a smaller set-up...similar in idea to your orange one Ive been seeing you build. Realistically (95% of time) im just going to be having family fun in the hills camping, mudding etc.
Option 1:
I think If I could find someone to trade me a set of 4" springs for my new 6" springs, Id be happy at the 7" lift mark (3 body 4 susp).
Option 2:
Ive contemplated a set of those Rough Country add-a-leafs, that you can add front and back for about 2"...Would give me a total of 7" in conjuction with my 2" rear block
Option3:
Is it possible to remove a leaf or 2 from a new 6" spring pack and get a 4" lift thats pretty soft and flexy?
Regards and much appreciated-RMK
Old 04-06-2009, 03:34 PM   #34
RckyMntnKng
Weekend Progress
Pulled the PO's 2.5" Rancho lift and got the 6" TC springs in.
Awaiting the new perches and u-bolts for the 14 bolt to go in the rear.
Old 04-06-2009, 03:39 PM   #35
RckyMntnKng
So far Ive got an extra 12 bolt rear and 2.5" Rancho lift thats not very old (maybe 2 years and literally no miles).
See the 14 bolt close up pic....PO cut the rubber brake line hose. How do I fix that? All new brake kit?
Old 04-06-2009, 04:36 PM   #36
Jtrux
Jtrux's Avatar
New brake line is in order. Aftermarket has all kinds of stuff available like stainless steel lines and what not.
Old 04-10-2009, 10:07 AM   #37
RckyMntnKng
On the 14bff...installed Perches and shock mounts.
Old 04-10-2009, 10:10 AM   #38
RckyMntnKng
A truck lift would be worth alot to me at this point....using some axle jacks and a hydraulic floor jack and shop crane, installed the 14bbff....whew my measurments were correct!
Here is the 36x14.50x16.5 SS truxsus rollers installed, on the rear w/ 9" lift
Old 04-10-2009, 10:15 AM   #39
RckyMntnKng
My good digi camera got smushed in the airplane overhead on my last trip....hence the 2mp cell pics, sorry. Hurts me more than you.
Old 04-10-2009, 07:46 PM   #40
jamie72
jamie72's Avatar
looking good!!
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 04-27-2009, 10:22 AM   #41
RckyMntnKng
First coat of the rattle can Spruce Green over Black.
D60 is getting prepped for front install this weekend.
Tube Bumpers are in Fab stage.
Drivelines are nearly ready to be lengthened and 1-ton'd
the 36x14.50's rollers look tiny under there. (but not as bad as the 31's up front haha)
Old 04-27-2009, 11:27 AM   #42
RckyMntnKng
Old 05-01-2009, 10:35 PM   #43
RckyMntnKng
Officially 1 tonned
Old 05-01-2009, 10:36 PM   #44
RckyMntnKng
pic
Old 05-02-2009, 06:19 PM   #45
swyfor5
swyfor5's Avatar
Dude, your progress looks awesome! Keep the pic's coming!
swyfor5 is offline   Reply With Quote
Old 05-10-2009, 12:21 AM   #46
RckyMntnKng
Weekend work.....
Drained both pumpkins and sanded down the covers, primer'd, and coated with the spruce body color.
Filled the 60 with 80w90 and the 14b with the same plus friction additive for the eaton.
My set of Bilstein 5100 series came in, so they went on too.
Old 05-10-2009, 12:26 AM   #47
RckyMntnKng
Dont know how the previous owner maintained the d60...I can tell it had been off-road'd. The pumpkin cover was dented and a hi-lift block was already installed. Im going hi-steer crossover here in the next few weeks.
I went ahead and replaced the bearings and races, and now waiting on some new warn lock hubs.
Also had a set of new brake lines made. New all the way to the master cylinder. Hard lines and rubber. You can see them hanging on the rotor in the pic
Old 05-10-2009, 12:29 AM   #48
RckyMntnKng
Here is a little comparison shot to help me feel better about progress....seems so freaking slow but its getting there.
These are a couple months apart.
Second pic is one of my buddys and my son wishing they could drive it.
Old 05-10-2009, 12:49 AM   #49
RckyMntnKng
Would look pretty mean with some 38x15.50's........
Old 05-10-2009, 08:30 AM   #50
jaros44sr
jaros44sr's Avatar
[QUOTE=RckyMntnKng;3302201
Also had a set of new brake lines made. New all the way to the master cylinder. Hard lines and rubber. You can see them hanging on the rotor in the pic[/QUOTE]
Can you tell me where you had them made, I don't want braided SS, and the original look alot better. My PO mounted them on an angle bracket for the 4" lift and I think it looks like crap...
Trucks looking good, even a little progress is good. Wheels and tires, plus the lift make it really look nice
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
