#26 |
Re: 56 Cameo build
Always been a fan of the Cameo's. I'll be watching for progress pics!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
#27 |
Re: 56 Cameo build
I haven't seen any inside rear corner panels shown anywhere. Am I missing something? Help me out if you know of any.
#28 |
Re: 56 Cameo build
maybe im wrong onwhere you mean,try to post a pics of the area. this is what im talking about look at pics, 1st 2 are of the inner cab corners 3rd pic of one in place on my cab
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
#29 |
Re: 56 Cameo build
Thats definitely what I need. Where did you get yours?
#30 |
Re: 56 Cameo build
i ordered mine from Jon at tri-pro automotive in NJ, he is a member on the board here and a good guy in my book www.tri-proautomotive.com
#31 |
Re: 56 Cameo build
I put them in my truck. If I was to do over I would not put these in and make a piece that went from the floor to the cab, and a support to the bottom of the outer cab corner. Reason is this is a perfect place for rust to start... holds a lot of stuff between the inner and outer corners.
'56 truck (the never ending project) '06 Z/71 loaded (daily driver) '07 Mercedes-Benz C-Class (wife's driver) Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod, |
#32 |
![]() Join Date: Oct 2007
Re: 56 Cameo build
any updates.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
#33 |
Hey, thanks for the interest. I have been working right along on the 56. I sold the 40 I had done before so I would have more time and incentive to have something to drive. The body work on the cab is 99% complete and I got the fiberglass sides blasted so we can start on them. A friend comes to my house 1 night a week and helps. I should say I help him with the body work. The rest of my time I spend trying to keep ahead of him. I have my single window kit and really appreciate the guys doing the videos on youtube. thats going to be a huge help. I changed the rear end to a 69 chevelle 62" 10 bolt so I don,t have to tub the bed or run wide spacers. I also got a LS engine and transmission from a 2007 GMC. I talked to Jesse at WaitForMe Performance and am sending the harness to him. We are putting the motor in this week. Then it goes to my other friends who will install the steering column and brakes. We can work on the bed at my place while its' gone.
I have to say thanks to all of the people on this site who have helped me in many ways and I deserve 20 lashes for NOT POSTING PICTURES! Again, thanks for the interest and I will get some pictures posted. |
#34 |
Re: 56 Cameo build
if you have any problems on the window install shoot me a pm
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
#35 |
Yellow truck club
Re: 56 Cameo build
Time for some picture updates I believe....
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 01-05-2010 at 05:29 PM. |
#36 |
Re: 56 Cameo build
Looks really Good man....!
#37 |
Re: 56 Cameo build
Here are a couple of pictures I promised. The new latches and handles and the LS in place.
#38 |
A320 Pilot/USAF Retired
Re: 56 Cameo build
I'd love to get a Cameo bed for mine!! Nice work, keep the updates coming.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#39 | |
Re: 56 Cameo build
http://carolinacameoconversions.com/ K8O
1958 3100 w/55 frontend and 55 Cameo Bed (in progress) ![]() |
#40 |
Certified Car Nut
Re: 56 Cameo build
You got to love the Cameo. My buddy has one, I've always wanted one.
#41 |
Re: 56 Cameo build
I need some info on the Ls engine adapter plates. I installed the plates with a set of the origional style rubber sbc mounts and I'm about a bolt hole width off on the engine stands. I just saw an add in CC trucks for Welder Series for adapter plates and they mention urethane insulators. Whats the difference and where can I get them? Everything I read says the plates fit the origional mounts. Anybody else have this problem?
#42 |
Re: 56 Cameo build
you will need to check the clearance for your tie rods when turned all the way to one side before hooking up your mounts if you use the truck pan you might have clearance problems
#43 |
Re: 56 Cameo build
I have a spare cab I'm using for parts Be glad to cut these off for you. Let me know if you still need them and how to get them to you. I'm in Ariz.
#44 | |
![]() Join Date: Nov 2008
Re: 56 Cameo build
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
#45 |
Re: 56 Cameo build
Thanks for the offer on the cab parts Rons 55. I made what I needed, so the cab is pretty well done.
Also thanks for the headsup on the oil pan JML55. I think we'll do as you did and pull the engine out and put the mounts where they need to be. Lots to be done yet, but I'll be glad to get back to turning wrenches instead of filling and sanding. Working on the bed right now, pictures are past due. |
#46 |
Re: 56 Cameo build
I have the 5.3 also and i think i am going to be able to get away with the truck oil pan. i made my own motor mounts out of a few peices of flat stock. I raised the motor up enough to where the oil pan is a touch higher than the bottom of the crossmember. If i scrub the bottom of the crossmember, theres a good chance i will take the oil pan out. So ya just better take it real easy over the speed bumps hahaha.
In all serious-ness, this truck will have about the same clearance my '38 does. and i have yet to have a problem with anything bottoming out on it. Just watch where you drive
#47 |
Re: 56 Cameo build
Thanks for the headsup Blackdeisel. Every little bit of info helps. I don't know what I would do without this site.
#48 |
Re: 56 Cameo build
Any Updates?
#49 |
56 - autocross
Re: 56 Cameo build
Subscribe!
#50 |
Re: 56 Cameo build
nice build so far. I have to watch this one
