Old 12-25-2007, 05:23 AM   #26
Slmd92DIME
Slmd92DIME's Avatar
Re: Project: 65 C-10
I am abot half an hour from Morgantown.. just got back from the girlfriends house..
yes the door was completely skimmed in filler.. I ground it all out and I saw no reason for the filler LOL
there is a dent at the bottom but other than that... THE GUY WENT PUTTY CRAZY
Slmd92DIME is offline   Reply With Quote
Old 12-30-2007, 09:15 PM   #27
Slmd92DIME
Slmd92DIME's Avatar
Have been workin on it pretty hard these last few days.... Finally cut the tranny tunnel out.. Raised, SeamSealed, and primed and painted... Let me know what you think about it... Startin on steering next, Then some body work, then the brakes....
Old 12-31-2007, 04:06 AM   #28
jlaird
jlaird's Avatar
nice job on the floor!
jlaird is offline   Reply With Quote
Old 12-31-2007, 04:38 AM   #29
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice job what kinda of seam sealer did you use? I used some 3m stuff and did not really like it.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-31-2007, 04:12 PM   #30
Slmd92DIME
Slmd92DIME's Avatar
I got my sealer from Napa... I am pretty sure it is Napa brand also.. It was my first time using it but I really liked it...
Old 12-31-2007, 05:34 PM   #31
NEVERENOUGH
NEVERENOUGH's Avatar
Man I love the way that truck is layed out. That is one killer looking project I can't wait to see more updates.
NEVERENOUGH is offline   Reply With Quote
Old 12-31-2007, 05:58 PM   #32
Dinos63
chevy only
Dinos63's Avatar
Lookin Good, And A Big Back Window Nice
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 01-01-2008, 04:54 PM   #33
higgiec10
higgiec10's Avatar
clean truck nice work
higgiec10 is offline   Reply With Quote
Old 01-02-2008, 09:22 AM   #34
Slmd92DIME
Slmd92DIME's Avatar
Hey guys... started the steering... if my control arm is just barely rubbin that shaft can I put a u joint right above that piece of the control arm? Would puttin a joint there move the steering enough to not rub?
Old 01-03-2008, 04:18 AM   #35
FRENCHBLUE72
PROJECT 7DEUCE
Thanks for the heads up on the sealer. Heres a pic of what you can do. And yes I stole this pic from xxl
MEMBER #6377
Project "7DEUCE"
Old 01-03-2008, 06:54 AM   #36
Slmd92DIME
Slmd92DIME's Avatar
Thanks man... Those little universals are a killer like 60 bucks a piece.... It was just barely rubbun so I cut my control arm and put a piece of round tubing in there to get my strength back... I will have some pics up today....
Old 01-11-2008, 07:01 PM   #37
Slmd92DIME
Slmd92DIME's Avatar
Have been workin on it while it has been warm here. Finally primed the cab, finished the steering, and started workin on gettin the doors straight.
Hopefully have the doors primed at the end of the week. I made some brackets for the column to get held since the firewall has none.
Arm Notched for steering
Bracket made to hold steering down on the inside of the firewall
Firewall.. There is not filler in it yet
Old 01-13-2008, 04:29 AM   #38
HotRodYJ
HotRodYJ's Avatar
Looks like a fun project! I've basically done very similar as for as a front end layout except I've sunken the crossmember 5" up over the frame rails instead of Z-ing the frame just to be a little bit different. If I recall correctly, you've Z'd 4" plus dropped the cab 1" so in essence you'll end up raising the motor about 5" in relation to the body. Same thing I am doing, my motor will raise approx 5" due to the new crossmember location alone. I'm curious if you've fitted the motor yet and have any pics of how the motor to hood clearance and distributor to firewall clearnace will work out for you? I hope to be fitting my motor this weekend so I was very curious what you've run into and how you've worked around it.
Thanks!
HotRodYJ is offline   Reply With Quote
Old 01-13-2008, 02:15 PM   #39
Slmd92DIME
Slmd92DIME's Avatar
No the motor has not been in recently.. just to make the tranny crossmember.. I hope to put it back in soon though. My firewall will def. need cutting around for the dist. I also do not know about the hood. I dont think it will have a problem honestly. It may look a little goofy that high though.
Old 01-13-2008, 03:46 PM   #40
HotRodYJ
HotRodYJ's Avatar
Here's how mine is looking 5" higher (you may have seen it already). I cut for the dist today. When it's done I'll show it in my thread. Looks like hood clearance will be good and doesn't look goofy at all like I thought it would being up so high.
Old 01-14-2008, 02:08 PM   #41
Slmd92DIME
Slmd92DIME's Avatar
Looks good man.. I just actually found a small block for mine yesterday. have to get some money round up for it though
Old 01-14-2008, 07:45 PM   #42
Dinos63
chevy only
Dinos63's Avatar
looks good bro
Old 01-17-2008, 07:42 PM   #43
BigSky71
LAIDOUT
BigSky71's Avatar
Looking good man, love that body style all laid out... Wait I love them all laid out and yours is going be cool!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 01-18-2008, 08:00 AM   #44
Slmd92DIME
Slmd92DIME's Avatar
Thanks for the comments guys.. it is keepin me motivated even though it is cold out now...
Old 02-08-2008, 12:04 PM   #45
1LoC10
Insert Title Here
1LoC10's Avatar
dont know how i missed this one... but looking great
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 02-15-2008, 01:25 PM   #46
joe231
joe231's Avatar
very sweet!!
what is the story on that grill hanging in the background?
Old 02-27-2008, 09:00 AM   #47
Slmd92DIME
Slmd92DIME's Avatar
JOE- I have probably 3-4 steel grilles Let me know if you need one
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Old 02-27-2008, 09:05 AM   #48
Slmd92DIME
Slmd92DIME's Avatar
I replaced the frame from the notch back since it was a little rotten and it would look nicer anyway ........gonna put the fuel cell there
I also started on my watts link.. I will get pics up when it gets finished.. Shouldnt be too much longer.
That is just a temporary crossmember until I put another in after I get my cell made.
My Build Thread
Old 02-27-2008, 09:08 AM   #49
Slmd92DIME
Slmd92DIME's Avatar
Also.... I drilled the 6 lug rear axles to a 5x5 bolt pattern to match the front. The front crossmember is from a 87 chevy so it now has disc brakes Axles took forever but it was def. worth keeping the 12 bolt rearend and the same stock width of the rear...
My Build Thread
Old 02-27-2008, 10:49 AM   #50
joe231
joe231's Avatar
I was curious about the grill hanging up, looks like it has some added material on it.
CHEVY ONLY
