Old 11-01-2008, 07:06 AM   #26
ChaseDale3and8
ChaseDale3and8's Avatar
Re: Lift a 2wd 3/4t ??? *newbie*
Running an 8 inch wide rim versus a 10 inch will help in clearance issues as well. A narrower rim will pull the shoulder of the tire in a bit allowing a bit more clearance.
As the others have stated, your real problem is going to be with the front to have the needed room. You may still have to do some trimming on the stock fenders, especially at the back to make them clear even with both a body and suspension lift.
If it was a 4x4, you could fit 35s with 4 inches of lift easily. Since it's a 2wd you are about 2-3 inches behind in ride heght to start with. Good luck with your project, and be sure to post up pics of your truck, and welcome to the board! ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 09-04-2009, 06:07 AM   #27
John *Sweden*
John *Sweden*'s Avatar
Hi again fellas!
Sorry that I am the slowest f*cker in shoes...
The lift is now done and the 35ers is mounted to the 16inch rims.
Total lift was 5" (only bodylift) had to leghten the steeringshaft and gearselector rod. Yes, as you said the fender needed som cutting...
Remain to do: fix rust, lift rear bumper and new paint...
Would like to say more pics are comming but in this pace its better to shut the f*ck up...
Before pic:
By subitus, shot with KC910 at 2009-09-04
Bed lifted 5":
After pic: Whit 35" and 5" bodylift
John *Sweden* is offline   Reply With Quote
Old 09-04-2009, 08:26 AM   #28
N2TRUX
Happy to be here
N2TRUX's Avatar
John- That looks mean as hell. All it needs now is a brush gaurd and some driving lights....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-04-2009, 12:14 PM   #29
lvschevytrucks
Unfinished Project Club
lvschevytrucks's Avatar
John first Id like to say and to the forum, you wont find a greater bunch of guys and gals, all willing to help you out.
second, Thats one sweet truck you have cant wait to see what else you do to her. good luck , and keep the pictures comming because the guys here love pictures.
Randy
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
1996 Dodge Intreped ES Nice car great on gas
1993 Jeep Cherokee.
Looking for a swb chevy 73-87
lvschevytrucks is offline   Reply With Quote
Old 03-28-2010, 04:09 AM   #30
87 chevy silverado
i need to look at this when i get that far with mine
87 chevy silverado is offline   Reply With Quote
Old 06-30-2010, 06:05 PM   #31
bucannon
Salty Sailor
bucannon's Avatar
Post Re: Lift a 2wd 3/4t ??? *newbie*
a 5 inch body lift!!??? where did you find that?
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 06-30-2010, 08:40 PM   #32
Matt Man
Matt Man's Avatar
probably custom made. hockey puts anyone?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 10-29-2013, 06:21 PM   #33
Jahloha
Jahloha's Avatar
Originally Posted by 78 Chevyrado View Post
The body lift will be where you'll have to get most of the lift from. You can swap in a set of Heavy Duty 3/4 ton coil springs (stock replacements) in the front and put lift blocks in the rear.
Here's a before and after pic of my 78 C20 2wd, after swapping in Heavy duty coil springs up front (aprrox. 2 inch lift) and 1.5 inch lift blocks in the rear.
BEFORE:
AFTER:
I know this post is old, but if you are still active, I have a question for you:
How does your truck currently look?
What engine do you have in there?
Your truck is very much to level, slightly lifted look I want for my 70 c20.
Let me know. Thanks!
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
2wd, 3/4ton, 8lug, lift, prerunner
