Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-14-2009, 09:03 AM   #26
Wild83C10
Wild83C10's Avatar
Re: Suspension 101
Originally Posted by Super73 View Post
Ok.. I think chapter 1 is finished.. I'll try and write up chapter 2 in a few days..
If you haven't gotten to this chapter yet, Hot Rod mag did a nice write up on adjustable shocks. Obviously they said that dbl adj were ideal. I plan to run dbl adj coilovers front and back.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-16-2009, 03:45 AM   #27
Super73
Super73's Avatar
Re: Suspension 101
In my opinion singles are fine for 10 second and slower vehicles.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-16-2009, 04:44 PM   #28
Wild83C10
Wild83C10's Avatar
Re: Suspension 101
I have the single now and I don't think there is any point to single adjustable shocks for drag racing. They would really only be good for street driving.
I believe the dbl adj shocks could benefit someone running slower then 10 sec. cars, especailly trucks. With any vehicle that has close to 60% of it's weight on the front, weight transfer is critical. That is of course if you use it for more then just drag racing.
turbo=
Old 03-16-2009, 08:42 PM   #29
djracer
djracer's Avatar
Re: Suspension 101
I still have singles on my junk.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-16-2009, 09:17 PM   #30
Wild83C10
Wild83C10's Avatar
Re: Suspension 101
How do they work for you? What shocks are you running? Do the rebound and bounce adjust the same?
turbo=
Old 03-16-2009, 09:55 PM   #31
djracer
djracer's Avatar
Re: Suspension 101
I run the longer Qa1 coilover shocks. They adjust rebound and compression at the same time.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-17-2009, 09:34 PM   #32
Wild83C10
Wild83C10's Avatar
Re: Suspension 101
Yes I know it adjust the rebound and compression at the same time. I guess what I ment was that it adjust the comp and rebound the same percent. It's not like its a tyipcal drag shock, 90/10, 50/50, ect.
turbo=
Old 03-17-2009, 11:18 PM   #33
djracer
djracer's Avatar
Re: Suspension 101
it really doesn't say on their site but here is the link to the shocks I run
http://qa1.thomasnet.com/item/proma-...10&plpver=1001
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-02-2009, 12:15 AM   #34
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: Suspension 101
Super 73 you are so Rad
68 C-10 KID is offline   Reply With Quote
Old 11-02-2009, 12:30 AM   #35
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Re: Suspension 101
Originally Posted by Old Yeller 1970 View Post
I'll also be getting some new tires so I'll pull the wheels/tires and weigh them too.
Right now it looks like I won't be needing the drag springs after all. I finished up assembling the bed (for years the bed floor wasn't attached to the sides) which really stiffened up the truck (along with polyurethane body mounts) and put on a set of Firestone Indy 500's and found out their reputation for stickiness is well deserved. I'm able to launch from a dead stop without tire spin for the first time in Old Yeller's history and that's with an additional 150-200hp at peak output.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 11-03-2009, 05:00 PM   #36
Ont67shortbox
Re: Suspension 101
<<<<<<patiently waiting for chapter 2,excellent write up so far.Brian
Ont67shortbox is offline   Reply With Quote
Old 11-03-2009, 07:05 PM   #37
Super73
Super73's Avatar
Re: Suspension 101
Chapter 2 has been done for a while.. It's 3+ that needs some time.. Just haven't had it..
Old 04-03-2010, 09:34 PM   #38
5.7L JWL
Re: Suspension 101
Scribed for future reference. Thanks for the "leg work". It's greatly appreciated.
Jay
'98 C-1500 ECSB 5.7L Edelbrock shorty headers Ceramic, Stage 8 locking header bolts, Magnaflow S/S y-pipe w/converters, Magnaflow S/S
Cat-Back Exhaust (DI 2.5" / SO 3.5" w/ 4" Tip.) Synthetic Fluids throughout. Polished TB with Blade removed, ASP Pullies, Performance Distributors "Vortec Firepower" Ign. Kit, BlackBearPerformance Tuned PCM '84 Kawasaki KX-80 "Mint"
5.7L JWL is offline   Reply With Quote
Old 10-04-2010, 04:40 PM   #39
kpeztruck
kpeztruck's Avatar
Re: Suspension 101
I run single adjustable in the front. The old front shocks were QA1 stocker stars, that bolted in the stock location. Excellent choice, because compression is set full stiff, rebound is the only thing you adjust. However, if you run QA1 coil-overs, they adjust rebound and compression the same amount on the single adjustable. This is what I will be running with the new front suspension. I have never had a problem tuning the front
suspension on any other car with single adjustable.
I tried the single adjustable on the rear, it was not a good choice. There are times when you need more compression to hold the tire to the track, so it won't attempt to bounce and unload. I ran M/T drag radials, so they required a good amount of adjustability to work. I would not run anything less than double adjustables on the rear. These trucks operate much like a ladder bar in that they hit the tire very hard. You have to be able to control the spring with dampening, as well as the added factor of the tires resitance to be controlled. Hope this helps.
kpeztruck is offline   Reply With Quote
Old 01-21-2011, 10:21 AM   #40
cooter472
cooter472's Avatar
Re: Suspension 101
in this statment above what #'s do you use to divide the wheel base (If you have 60% in the front and 40% in the back, then take your wheel base and divide it by that amount. 100” wheel base would put you at 40” from the front axle. The height is a little more difficult.) this thread really has my attention. I was up most of the night in the shop with a copy of this trying to lay it out on the shop floor. I'm getting ready to do some front end work to my truck in the next few weeks and figured i would go ahead and do the drop spindles and custome springs you were discussing. also when i take the truck to be scaled should i manually lock the suspesion a ride level i want to get correct springs. does qa1 make a stocker adjustible for the 71 c10's. Can't wait for the rest of your chapters, i believe i can really start killing the mustangs now with this info, everybody in my county thinks I'm crazy for trying to race this big heavy truck but i like it.
cooter472 is offline   Reply With Quote
Old 02-05-2011, 05:27 PM   #41
leadfoot067
horsepower junkie
Re: Suspension 101
comp engineering makes a bolt on adjustable shock for our trucks...
http://www.summitracing.com/parts/CEE-2615/
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline   Reply With Quote
Old 02-05-2011, 06:07 PM   #42
Old Yeller 1970
DON'T TREAD ON ME
Re: Suspension 101
Cool. That's the first time I've seen that one.
Old Yeller
Old 06-13-2011, 06:08 AM   #43
85_C10_Sleeper
85_C10_Sleeper's Avatar
Re: Suspension 101
will those moroso springs fit our trucks w/o modifying the crossmember and lower control arms?
I searched them on summit and the first ones were for a camaro. Just making sure, Im trying to get my trucks suspension halfway setup before i finish my engine and trans.
85 C10 LWB
305ci - 700r4 - 10 bolt - 3:08 gears
Collecting parts for a 'mild prerunner"
85_C10_Sleeper is offline   Reply With Quote
Old 06-29-2011, 12:53 PM   #44
Derek71784
Re: Suspension 101
Thanks Super 73 for this post. I've been trying to search the internet on things I need to do to get this old beast ('69 SWB) to hook up. djracer put me onto you/this post. I'm new to the forum, and just got my truck about 7mo ago. Having someone help you out like this helps alot when you're trying to build a semi pro street truck on a soldier's budget! Thanks alot!
1969 C/10 SWB- Built 350/TH400/12-Bolt (Under Construction)
-Amateurs practice till they get it right, professionals practice till they get it wrong-
Derek71784 is offline   Reply With Quote
Old 04-05-2012, 08:41 AM   #45
Arekusu
Arekusu's Avatar
Re: Suspension 101
Sooo any update? I'm stil looking to get my truck set up correctly.
Alex
Arekusu is offline   Reply With Quote
Old 04-19-2012, 05:24 AM   #46
1ronnieluv
1ronnieluv's Avatar
Re: Suspension 101
All you need is some Beer and BBQ to make these old trucks run good. Ok here is what I ran on my 65.
-Moroso chevelle front drag springs
-Comp. Engineering 3 way adj. shocks on the front
-Stock rear arms with Rancho shocks
-lowered the front of the rear arms 3" with 3 deg. positive pinion angle
The truck weight was 3065lbs without me in it. I had a 468cid, PG, NOS Big shot plate and the truck ran 5.90s @ 112 mph with 1.29 60'
I then sent the truck off to have ladder bars and coil overs installed. $2,500later it picked up 2 dimes. For what we are doing, all of the checking corner weight, preload on whatever side, instant center, and all of the other b.s. leave that to the prostock guys who are looking for every .001
1ronnieluv is offline   Reply With Quote
Old 04-19-2012, 06:09 PM   #47
65Pickup
65Pickup's Avatar
Re: Suspension 101
Wow amazing, 5.9's wheels up...and you had stock springs and stock replacement shocks before the ladder/coil over mod? Can't wait to get under my truck and look at the 3" raise of the trailing arm mount, any advise on that change, or is it as straight forward as it sounds?
65Pickup is offline   Reply With Quote
Old 04-20-2012, 03:13 AM   #48
1ronnieluv
1ronnieluv's Avatar
Re: Suspension 101
Nice 65. Black looks good on these trucks. I lowered the front of the trailing arms to get rid of anti squat. I used square tubing and welded two pieces in the verticle position on the lower part of the crossmember. I gusseted the tubing, ground off the factory rivets on the trailing arm mounts and moved them down 3". It got rid of the anti squat problem and lifted the front more. Oh I almost forgot the another reason the truck would leave with the wheels up is that the engine was moved back 11". If you would like some more info PM me and I would be glade to give you some more info like what shocks,springs ect.
Old 05-01-2012, 06:40 PM   #49
bigboybodry
bigboybodry's Avatar
Re: Suspension 101
can you get me in the ball park with what front and rear springs I need without having the weights of the front and rear?
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 05-03-2012, 06:23 PM   #50
1ronnieluv
1ronnieluv's Avatar
Re: Suspension 101
Nice truck! Depends on the engine you are running. The moroso drag springs for the 70 chevelle will work fine. If you have a SB, run a SB spring and the same for a BB. I would keep the stock rear springs. If you do not mind me asking, what size rear wheel and tire are you running? I am building a 72 swb and I like how your truck looks.
