Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-27-2009, 09:59 PM   #26
Critter
Future TOTM Winner
Critter's Avatar
Re: The Great Critter Revival ‘09
Originally Posted by mudman316 View Post
forgive me please, but, I too will be doing the same thing to mine.
I was going to plan on the top holding everything.
With top on and doors off
do you still need a brace while doing bodysupports coming to A pillar and B pillar
and while doing A pillars and boxes?
I am by no means an expert, but I believe if you are changing you torsion boxes then you FOR SURE need to support things as much as possible. They along with the floor pan itself keeps the middle of the tub (somewhat) stiff. The reason I am not doing more supporting that I am is because the Tboxes and 80% of the floor will remain untouched. Hopefully others will chime in for both our sakes.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 03-02-2009, 12:36 AM   #27
Critter
Future TOTM Winner
Critter's Avatar
I started cutting a couple of spots out of the firewall today. I expected to find “trash” in there and of course I did. The vent door is toast…gonna have to do something about that.
Old 03-02-2009, 12:38 AM   #28
Critter
Future TOTM Winner
Critter's Avatar
I have been thinking about areas like this in my Blazer. Has anyone ever sprayed a rust encapsulator in an area like this that likely won’t get any regular paint? The other area that crossed my mind was inside the rocker boxes before I welded the floor back up. Any thoughts?
Old 03-02-2009, 12:41 AM   #29
72Levi
Active Member
72Levi's Avatar
Keep at it, you can take care of that. I admire the heck out of you for bringing back your K5. I've always liked the dark green Blazers.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum
2004 FORD FX4 SuperCrew
2005 CTS-V 12 sec family car
2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it!
72Levi is offline   Reply With Quote
Old 03-02-2009, 10:45 AM   #30
jaros44sr
jaros44sr's Avatar
Shame it's that bad in the cowl area, but it's to be expected as all the crap falls into it. I would take more metal out back to the seams, then you can really get a handle on it. If you leave the forward edge, where the curve starts, you should be able to fix it with a flat sheet of metal. When mine go bad, I want to put in a piece of stainless and screw it in so I can check it from time to time. Also this will allow you to put a sealer between the seam and metal
Whats the inside area look like(kick panel)
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-06-2009, 02:01 AM   #31
Critter
Future TOTM Winner
Critter's Avatar
Whats the inside area look like (kick panel)
That's what I plan to do this weekend. I was a little scared to it, but then I read this.
http://67-72chevytrucks.com/vboard/s...ad.php?t=72472
It gave me the false sense of confidence I need to start cutting ....pics to follow.
Oh, and my kick panel has some rot along the bottom 1 inch where it meets the floor board, no better or worse than most of the others you see around here.
Old 03-06-2009, 07:00 AM   #32
jaros44sr
jaros44sr's Avatar
Have fun this weekend and take lots of pics for us to look at, I'm a junkie for people's progress
SAFETY FIRST
AS usual, off topic
Jim
Old 03-07-2009, 05:19 PM   #33
Critter
Future TOTM Winner
Critter's Avatar
Day 12…
ordered drivers side patch panels from Tri-Pro yesterday…
found more rust around the firewall today…I’m scared…
starting to freak out…
Old 03-08-2009, 11:33 AM   #34
BLUE THUNDER
BLUE THUNDER's Avatar
Dude, your knee deep in it now. A little more work and the Critter will be on the road in no time. Gimme a shout if you need a hand. Way to go so far though. Later.
BLUE THUNDER is offline   Reply With Quote
Old 03-16-2009, 09:11 AM   #35
Critter
Future TOTM Winner
Critter's Avatar
Well I really don’t have any good progress pics to post so I thought I would at least put up one of the parts I got from Tri-Pro (Thanks Jon!). They arrived Friday and haven’t made it out of my spare bed room since. So far I only purchased the driver's side stuff. Lower A pillar, lower B pillar, outer rocker, outer floor strip, outer floor brace, and lower kick panel.
Me and Jtrux spent the weekend getting the parts truck back to my place and tearing into it a little more so I guess technically I did make a little progress.
Old 06-04-2009, 12:04 AM   #36
1949gmc
awwwww...... what happened next?? I hate it when a good thread comes to an end.
1949gmc is offline   Reply With Quote
Old 06-04-2009, 06:25 AM   #37
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Subscribed...what next?
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 06-04-2009, 10:54 AM   #38
jaros44sr
jaros44sr's Avatar
Yeah, I agree. What happened?
SAFETY FIRST
AS usual, off topic
Jim
Old 06-04-2009, 08:40 PM   #39
BLUE THUNDER
Dude you still working on it? Hopefully mine will be on the road soon. Post more pics of the critter soon. Later.
Old 06-05-2009, 09:01 AM   #40
Jtrux
I'm a poor spectator
Jtrux's Avatar
It's probably rusted to pieces by now.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 06-05-2009, 12:47 PM   #41
71jimmy
71jimmy's Avatar
Critter, sent you a PM! Thanks
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 06-06-2009, 08:30 PM   #42
Critter
Future TOTM Winner
Critter's Avatar
Alright, alright, alright. Sorry, I haven’t been on the board much lately. I got laid off from my job a few months ago like a lot of others have. I haven’t had any money to dump into the Blazer pit and to be honest getting on here just kind of depressed me. I’m kidding a little. Sometimes it’s hard to see others finished projects when I can’t make progress on mine. (I’m a little childish, I know ) Not to mention I was also in the process of building a little shop when all this happened so that got put on hold as well. ALSO, an uninsured motorist rear ended my DD Dodge back in April so I had to come up with a deductible for that. Anyway, I’m NOT trying to throw a sob story on anyone, but y'all asked for it just letting you know what the deal is. Luckily my wife has a decent job and after making some adjustments we are keeping our heads above water while I go on interviews/look for work, so all is good.
Back to the Blazer. I really haven’t done a lot lately other than a little tinkering on things here and there. Also, I have been pulling a few things off the parts truck as I get around to it. One of the things I am working on is getting the inner kick panel out of the parts truck and grafting it into the Blazer. You might ask yourself, “Self, why would this guy pull a kick panel out of a parts truck when he could just buy an aftermarket patch panel from a vendor?” Well, I pulled the dash and windshield out of the Critter and it had a little rust in the lower driver’s corner of the windshield frame. That along with the rust that you have seen around the kick panel vent door made me want to graft a whole new piece in there. So I have been busy chopping things up to get at the desired pieces. Here are a couple pics showing the area to help “tame the beast” that loves pics.
By the way, don’t think for a minute that this project is dead. It is VERY much on my mind. I am just taking a break for a little bit. Thanks for the interest guys.
71Jimmy, PM sent back.
Old 06-06-2009, 08:41 PM   #43
BLUE THUNDER
Keep your head up dude. Things will start looking up soon. Let me know if you need any help. Later.
Old 06-06-2009, 10:22 PM   #44
swyfor5
swyfor5's Avatar
Right on Bro! Keep on pushing on! You got a great thread going here, and if it has to take a little "pause" so be it! K5 to to stay alive!
swyfor5 is offline   Reply With Quote
Old 06-07-2009, 12:21 AM   #45
jaros44sr
jaros44sr's Avatar
Sorry to hear about the lay off, bin there many times thru my career. It really puts a hold on projects. Good luck to you on your search for a job. Good thing about projects, they don't care how long they take...but, they help keep your mind off of problems
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2009, 12:03 PM   #46
Critter
Future TOTM Winner
Critter's Avatar
Yeah I agree, to be honest me and my coworkers kinda saw it coming, but it happened a little sooner than expected.
Anyway, thanks for the kind words guys. Reading all this again has definitly motivated me to get back into the swing of things. There are pleanty of things I can do that don't cost money so I will get back to tackling them.
Old 06-07-2009, 12:09 PM   #47
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Critter sorry to hear about the recent job loss. Here's to an opening in the near futuer.
The build was really taking shape, it will be quite nice when complete. Best of lucK!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-09-2009, 03:59 PM   #48
Critter
Future TOTM Winner
Critter's Avatar
I felt the need to update with something. I told myself I wasn't going to spend any more cash on the Blazer till I got my shop/garage...but we all know how that goes I verbally purchased a single wall top from Teeitup a few months back and I finally got around to picking it up a couple weeks ago. I snapped some pics for the heck of it. I took one of the Kansas border sign also, but it was too blurry to make out. Anyway, the top is in great shape, and had a decent hatch with it. I don't know why I am obsessed with having a single wall top (I have a nice double) I just couldn't stand it. Plus my K5 is a 72 and already has both sets of holes in the bedsides. I think the main reason I wanted one was because I plan to have a decent interior one day and don't like the idea of taking the inner panels off every time i want to remove the top. Oh yeah, and I like interior lights.
The top itself is in better shape than it looks. No cracks to speak of, just some resealing to do around the seam areas. It looks like it has been sanded some in the past and has some old white paint on it. I would eventually like to do a full top restoration ala BobbyK...but there is a lot of other things to be done to the Critter before she needs a top. Anyway, thanks for checking in.
Old 08-09-2009, 05:35 PM   #49
1956cameo
1956cameo's Avatar
Thanks for letting us know how things are going with the blazer! Hopefully your job condition is improving.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 08-09-2009, 06:32 PM   #50
Critter
Future TOTM Winner
Critter's Avatar
I actually had a pretty good interview the other day. It sounded promising but I don't wan't to get my hopes up just yet.
