#26 |
English Chevy Owner
Re: Rear Sway Bar
I don't think we got Nissan Pathfinders over here back then although they may have been called something else. IIRC we just got the Nissan Patrol and Terrano. The Pathfinder name only started to be used by Nissan here about a year or so ago.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#27 |
"the other guy"
Re: Rear Sway Bar
what size u-bolts do i need to fit the axle tube? thanks
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
#28 |
Re: Rear Sway Bar
Here is a pic of the Pathfinder bar. It takes 3" muffler clamp. You have to elongate the hole in the clamp to get it round the axle tube. I will take some more tommorrow.
#29 |
Re: Rear Sway Bar
hears another pic
#30 |
Re: Rear Sway Bar
And another. Its hard to get the right shot at the right angle. I will try some differen. ones tommorrow.
#31 |
"the other guy"
Re: Rear Sway Bar
so the axle tube is 3"?
#32 |
Old member
Re: Rear Sway Bar
That's right I think 3" tubes. Sorry about the PM I hadn't woke up good. Yea this is right 3".
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#33 |
"the other guy"
Re: Rear Sway Bar
no problem, and thanks. other than drilling holes for the end link brackets, is it a bolt in?
#34 |
Old member
Re: Rear Sway Bar
If you go to the orignal post about my install you have to have some 1" spacers on each frame rail. I had 2" ones cut. I had to cut them in half. I stilll have the other halfs.
#35 |
"the other guy"
Re: Rear Sway Bar
willing to come off the other one? (mods, sorry if this falls under the user WTB?)
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() Last edited by vasquezmrysvll; 03-27-2009 at 09:13 AM. |
#36 |
Re: Rear Sway Bar
Hey big al, I got that same kit but haven't put it on yet. Curious why you didn't but it on top of the trailing arms? That way it wouldn't be hanging as low to catch stuff right?
'67 C-10 Shorty - 454, 5spd, and speed holes! |
#37 |
Car Knocker
Re: Rear Sway Bar
I have one too. Have been wondering if mounting on top of trailing arms matters or not. I think that I would like it on top. But instructions show mounted on bottom. Any suggestions.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
#38 | |
Re: Rear Sway Bar
I would be curious which is better out of the ones that mount to the arms and the ones that mount to the rear end. Anyone?
#39 |
Not a bad nut after all..
Re: Rear Sway Bar
This is perfect for us leaf spring rear suspension guys, but where do the front ends mount to the frame?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
#40 |
Re: Rear Sway Bar
i got the CPP bars for my 72 burb 3/4 ton 2wd factory height. it did not have the factory front bar and installing that 1-1/4 bar (bigger than the stocker) really made a night and day difference when coming to corners (it is stable and predictable now). installing the complimentary 1-1/8 will balance it front to rear, help keep the trailing arm system more aligned (doing poly bushings on the trailing arms and track bar too) and really make a difference when i have a big heavy trailer hitched up. the burb has more weight up high in the back than a pickup and thus more body roll, but any rear bar is better than no rear bar in any vehicle. front bar needs to be stiffer (aka bigger) but closer in size is better.
i put 87-89 lesabre t type sway bars on my 89 lesabre 4 door limited. went from 1-1/16 to 1-1/4 on the front and 1/2 to 3/4 inch on the rear. even though the rear got a bigger percent increase, the car still had too much under steer. a 1 inch bar would have been much better but the factory prefers under steer because it is safer for average joe drivers (you don't spin around backwards). i put the rear bar on first and i liked the balance but it still handled better overall once the bigger front bar was in. |
#41 |
Re: Rear Sway Bar
if my memory serves me right it said to install it the way I did.... now it is long gone as I upgraded my rear trailing arms and I was not going to drill them now the truck handles even better than it did..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#42 | |
Re: Rear Sway Bar
#43 | |
Re: Rear Sway Bar
If I was replacing the trailing arms I would not buy a rear sway bar only the front and if I was just going to rebuild the original arms with new bushings I would add the sway bar. The new arms are a square tubing one piece vs the stock style which is two halves so there is naturally more flexing if this makes sense.
#44 |
Re: Rear Sway Bar
Thanks big al. I am sticking with my stock rear trailing arms (for now), so that gives me a little better piece of mind about having spent the money. Now I need to get them put on!
#45 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Rear Sway Bar
This was just posted by member sigshooter:
(figured the pics would be good in this thread also) Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=482744
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#46 |
Re: Rear Sway Bar
Interested
1969 Chevy c20(Miss Hackjob) |
#47 |
Re: Rear Sway Bar
Here’s a question on this subject.
While members have said the late 80s Camaro/Firebird sway bars fit perfectly, Will one off any of the other “Sport Models fit, width wise? (Like Impalas, Tahoes, Escalades? ) Just curious. I’ve been so busy lately that I haven’t been to a yard since last year, but I’m going to be soon. I’m compiling a list of things I need to look for now. |
#48 |
Re: Rear Sway Bar
Sub’d for future reference
#49 | |
Re: Rear Sway Bar
#50 |
Re: Rear Sway Bar
