Old 05-23-2009, 09:23 PM   #26
mobileortho
mobileortho's Avatar
Re: Bartman's Build Thread
Bartman I used the IFS from a '79 and had it narrowed about an inch & a half. I cut off about a coil & a half from the springs. I also put some 2" drop spindles I'm pleased with the results. I had 16 x 7 & 17 x 8 Torq Thrust II' but I just purchased 17 x 11 for the rear and looking for some 17 x 7's for the front. That front end will work with some tweeking.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 05-23-2009, 10:54 PM   #27
av8tr33337
av8tr33337's Avatar
Thanks Mobilortho.
I appreciate the information.
I looked your project over several times before I decided to jump into this with both feet. I really like the way it turned out.
I now have the old suspension gone. I'm using a 1980 IFS up front and on the rear I'm going to use Dodge Caravan leaf springs.
They are about twice as wide as the original and I can just bolt them on after boxing the mounting areas. (Just got them stripped off the sister-in-law's recently deceased Mini Van today) I also got the bucket seats(in great shape), seatbelts, emergency break system (hope it will be close enough in length), gastank (not sure if it will work). I'm tuckered out, did all that in one day!!!
I've been getting some "funny looks" here on the forum, but for good reason I suppose. Most guys don't like the wider stance and issues with wheel well clearence you have with this kind of and IFS swap. If I was financially able, I would definatley take the high road with a Mustang II set up, but like I said it's not in the cards for now and I NEED MY TRUCK ASAP. So I'm moving forward.
I've been working on this project every free day I can, over the last 2 or 3 weeks. Pretty much got all the major parts gathered and the truck stripped down to the frame. I took a few pics of my most recent progress, but haven't uploaded them to photobucket yet, but I will try to get them posted soon.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 05-28-2009, 07:45 AM   #28
av8tr33337
av8tr33337's Avatar
I've made a little progress getting the frame ready. Stripped off everything I needed to. Welded in a rear cross member. Got some rear leaf springs mouted.
http://i668.photobucket.com/albums/v...7/100_1502.jpg
http://i668.photobucket.com/albums/v...7/100_1507.jpg
http://i668.photobucket.com/albums/v...7/100_1509.jpg
http://i668.photobucket.com/albums/v...7/100_1508.jpg
http://i668.photobucket.com/albums/v...7/100_1513.jpg
Because of the shape of the rear spring Shackle mount I decided to "pie cut" it to make it look better and fit the frame rail better
http://i668.photobucket.com/albums/v...7/100_1514.jpg
http://i668.photobucket.com/albums/v...7/100_1515.jpg
Not bad for my first time ever attempting this.
http://i668.photobucket.com/albums/v...7/100_1516.jpg
I'm a novice welder but I think it turned out ok.
http://i668.photobucket.com/albums/v...7/100_1517.jpg
http://i668.photobucket.com/albums/v...7/100_1521.jpg
I even got some help from my father in law!!! He worked for JT Transport here in Wichita back in the 50's and has a wealth of knowledge on modifying these old truck frames. Back then they had to adapt stock trucks for many uses. One of which was hauling aircraft parts for Boeing and others.
http://i668.photobucket.com/albums/v...7/100_1526.jpg
av8tr33337
1951 3100 Pickup
Old 05-28-2009, 08:41 AM   #29
av8tr33337
av8tr33337's Avatar
Sorry about the last post. I posted eveything as links instead of images. Oh well. Here are a few more pics of the leaf spring install
These spings are off of a 1994 Dodge Caravan. They are about twice as wide as original. I lined eveything up with the out side edge of the frame rails so as you can see, the front shackle mount hangs over the inside of the frame rail about and inch. I may add some gussets later for support.
After "pie cutting" the rear shacle mounts (see links to pics in previous post), they are the same size as the front shackle mouts but because the frame is wider toward the back, they fit fine with no over hang.
Since these springs are from a front wheel drive vehicle they were only designed for support, not for the torque they will see from the rear differetial under acceleration. In this case the main leaf is not as stout due this fact. I may have to build some tractions bars to keep them from "wrapping" under acceleration.
I found a good article and some measure drawings of these type of traction bars on the internet. I'll post the link and a couple pics.
This is what is likely to happen with out the traction bars
Here is the link to the article.
http://www.hotrodsandhemis.com/Traction.html
av8tr33337
1951 3100 Pickup
Old 05-28-2009, 10:10 AM   #30
4DSEVEN
4DSEVEN's Avatar
You may want to consider putting your rear bracket on the inside of your frame and cutting a hole in the side frame. You would then be able to make a shorter shackle.
In the end it would likely give you a lower ride if that might be of interest.
4DSEVEN is offline   Reply With Quote
Old 06-04-2009, 08:01 AM   #31
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Or you could flip the mount over, put it on top and then section the bottom of the frame. This is done a lot on 55-57 Chevy cars when the leafs are moved under the frame.
ChuckDriver is offline   Reply With Quote
Old 06-04-2009, 10:45 PM   #32
av8tr33337
av8tr33337's Avatar
Lots of good ideas guys thanks
av8tr33337
1951 3100 Pickup
Old 06-05-2009, 08:43 AM   #33
Houston54
In case you have not learned this, the 700R4 units made prior to 87 are considered pretty weak. GM made signicant changes in the internal hard parts for the 87 and up years to resolve the problem.
Also the 84 camaro rear axle is a 7.5 inch ring gear which is also considered rather weak. The width will work well with suitable back spacing but the bolt pattern for the rims will be different than that IFS you plan to use. You probably already realize all this.
In my experience it is better to get the correct parts to do a project even if you have to wait longer for them. Your end result will be much more satisfying and you will only have to do the work once. It appears in your case you have plenty of cancer to fix first. It is not too late to trash that truck IFS and find a better solution.
Houston54 is offline   Reply With Quote
Old 06-05-2009, 06:46 PM   #34
av8tr33337
av8tr33337's Avatar
Yes I was already aware of those issues. Thanks for the info though!
av8tr33337
1951 3100 Pickup
Old 06-05-2009, 08:05 PM   #35
Kabwe
Certified Car Nut
Kabwe's Avatar
This is correct it is done a lot on tri-5 cars. I have inboarded leafs on my 55 Sedan.
Kabwe is offline   Reply With Quote
Old 07-16-2010, 11:38 AM   #36
99 to Life
99 to Life's Avatar
I am liking the build. I would leave it Patina for sure. Why because no other truck will have the same look, just like fingerprints. It makes it unique and I love the fact that it symbolizes it's age of almost 60 years. Just bag it and scrap the leafs!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-16-2010, 03:11 PM   #37
53GMC
53GMC's Avatar
awesome build bartman....wanna see some more in the near future!
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
