10-24-2009, 09:56 AM | #26 | |
Redefining LowBudget
Re: air bags hitting the bump stops!!!!!
as for bump stops get a rubber freeze plug ( the temp kind that have a nut you tighen) then take the bolt out of your upper plate and use the freeze plug as a bump stop/plate bolt..I saw a pic of a guy running it and it worked well as for me I have no bump stops and cupped LCA so my LCA lays flat against the X member..my X is about 1.5" off the ground with stock spindles
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
10-24-2009, 11:12 AM | #27 |
Happy to be here
I suggest you build a stop. Even the best engineered system "can" fail. If your system fails and you can't roll at all, you are at the mercy of being stuck where ever you are. That's not always a good thing.
I had an exhaust system failure the in turn melted an air line. I pulled over immediately. I got out and surveyed the landscape to discover I had broke down in the middle of nowhere. To compound matters I had almost zero cell phone reception. Wow, how lucky can one guy get to break down between two towns right in the middle of a dead cell zone. Fortunately my system allowed me to roll sitting on the bumpstops. I rolled down the shoulder for almost 5 miles to a rest stop. I was able to pull safely off of the Interstate and wait for a rollback. Bumpstops are a good thing.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-24-2009 at 11:13 AM. |
10-24-2009, 11:42 AM | #28 |
One day...
Yeah i am going to make some stops on mine too just for the same reason N2TRUX said about being able to get the thing off the road if something stupid happens.
N2TRUX- yeah that makes for a bad day and to boot with no cell phone reception been there before.. |
10-24-2009, 01:35 PM | #29 |
if you have an air failure and it drags you have scrub line issues not air......I would have jacked it up put a piece of wood in there and drove it home..but thats me....
with cupped LCA and a c notch I just clear the ground with my long headers the x member is 1" off
10-24-2009, 02:29 PM | #30 | |
Happy to be here
First off, I don't have scrub line concerns. In most cases when the system doesn't have a bump stop your tires are going to make contact with the fender liners, assuming you still have them. Next problem is you are assuming this involved only one corner. In this scenario, I blew the supply line going to the valve block so I lost all four corners. And last but not least, I carry extra line and fittings but this was in an area that was not readily accessible. I did have a small jack, but I did not trust it to lay under my truck while fighting a hot exhaust trying to patch the line up.
10-24-2009, 08:56 PM | #31 |
if it was a supply line and it got broken and the bags where aired up it shouldn't matter..reason # 2 to keep your vavles close to your bags reason #1 would be the amount of air to charge a long line in more than a short one.....longer hoses off your tank means more storage...back in the day we would run fuel lines in a zig zag just to carry an extra gallon of fuel..sometimes thats the dif between winning and runing out
10-24-2009, 09:13 PM | #32 |
most solenoid-style spool valves do NOT work without back pressure ... regardless of where they are mounted
10-24-2009, 09:55 PM | #33 |
Happy to be here
Kinda hard to keep your valves near your bags when your running a manifold.
You can make up all the scenarios that you wish. The bottom line is a properly designed system should be able to roll if the system fails.
10-24-2009, 11:01 PM | #34 |
low n' slo
I think it all depends on what kind of truck ur building. daily driver - like n2trux said, u gotta have something there. u have more of a chance of something going wrong if u drive it everyday. on a project or weekend driver, most people probably wouldn't put one in because it looks all cluttered up in there. just my .02 cents on a bumpstump
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-25-2009, 09:44 AM | #35 | |
I agree there are alot of factors to consider when building I never gave a manifold a thought all my bags have there own lines
10-25-2009, 08:30 PM | #36 |
GM ONLY BABY!!!
Cut mine completely off also.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
10-26-2009, 07:30 AM | #37 |
Mine will be a daily driver so I will need to fab a bumb stop.
Those of you running lower bag cups in the front, how tall are your's or howm uch did you cut them? mine are from SD and i would like to take off at least an inch. |
10-26-2009, 09:51 AM | #38 |
low n' slo
I believe I read for the 67-72 1.75" tall is the lowest, for the 73-87 1.25" tall is the lowest. I was gonna cut mine down but decided I want to get 8.5" cups and recess them into the lca to get a few more inches of drop
10-26-2009, 10:41 AM | #39 |
kev, you mean 1.75" over all height of the cup?
10-26-2009, 10:41 AM | #40 | |
1967custom |
10-26-2009, 01:02 PM | #41 |
Epoxy Primer Friendly
This is a simple way to do it. Looks natural and not cluttered.
I had my bumpstop setup this way originally before I went all out on my frontend. |
10-26-2009, 06:06 PM | #42 | |
low n' slo
yes, overall height of cup. i think the sd cups come like 3" tall if im not mistaken
10-27-2009, 02:56 PM | #43 |
You can purchase them at Oreilly or Autozone made by Energy Suspension.
10-31-2009, 02:37 PM | #44 |
low n' slo
ok cool, thanks
11-02-2009, 07:35 PM | #45 |
looks like Im doing another parts run to o reilleys!!! thanks for the tip on those bumpstops
1967custom |
11-02-2009, 08:30 PM | #46 |
thats what i got for the front and backs. i ended up cutting a step off the backs.
07-19-2015, 03:29 PM | #47 |
I know this is an old thread, but it doesn't look like there's any way that bumpstop would ever actually hit. Correct me if I'm wrong!
1968 LWB C20 / AC / Wood Bed |
07-20-2015, 12:48 PM | #48 |
My first old thread to be resurrected!! at full deflation, these stop would actually hit the
LCA. this is an oldie though. I sold this truck in 2011! it was a fun ride but i found a 67 short stepper that needed refreshing.
1967custom |
08-12-2015, 01:22 AM | #49 |
The D2600 are 2.8" deflated and you have a plate on top, so there must have been at least 2.8" between the crossmember and LCA fully aired out, right?
