Old 11-13-2009, 01:35 PM   #26
Kim57
Kim57's Avatar
Re: Tri5 55 build
Tri5
I like your frame brace. Where did you get it?
Kim
Kim57 is offline   Reply With Quote
Old 11-13-2009, 03:06 PM   #27
50adrod
50adrod's Avatar
Re: Tri5 55 build
Originally Posted by Tri5Nerd View Post
Here's a video of the motor running, that's before I installed new cam, heads, timing chain, oil pump, lifters, injectors, under drive pulley, 3500 stall and FAST 92 millimeter intake and throttle body.
how about a video after the engine mods
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 11-13-2009, 04:19 PM   #28
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: Tri5 55 build
Kim,
I made the frame brace in my welding class, I need to clean up the welds on the frame where I boxed and repaint.
50adrod,
I'll get more vids once I get the frame completed, It need to be retuned but I bought EFILIVE and going teach myself how to tune these motors.
Tri5.
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 11-13-2009, 04:46 PM   #29
Tri5Nerd
Tri5Nerd's Avatar
New gas tank with LS1 intank fuel pump.
I tried using the stock LS1 plastic tank and got it to work but wasn't happy with it. Started searching for something else and came up with this from seeing others do it with 80s style GM tanks. I also use the Vetteworks idea for the rings.
I bought a 1970 Mustang/Cougar 22 gallon tank which is 9.75" deep, the LS1 pump unit is ~10.5" tall and can be compressed. I cut the hole in the tank for the fuel pump, got bucket to sit correctly, made rings out out of 3/16" plates and tack welded one plate to the tank, I was very carefull not to burn holes.
Then set the fuel pump bucket with the rubber o-ring in the tank on top of the plate then sandwiched that with the other plate and bolt it down.
Just a note: I like to do and make things if I think I can, so I'll look for ideas and use them to meet my needs and try to save a few dollars to use elsewhere on the truck, and I do support vendors when necessary.
Old 11-13-2009, 07:38 PM   #30
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Tri5 55 build
Hey Tri5, I noticed you mentioned your welding class and I also noticed you are close to Kabwe and I know he's here in SoCal. I'm thinking of taking welding so where are you going? I'm wondering if you'd recommend the place you're going?
Dan in Pasadena is offline   Reply With Quote
Old 11-13-2009, 09:37 PM   #31
CAL 58 GMC
CAL 58 GMC's Avatar
Re: Tri5 55 build
Very impressive work so far Tri5!! I'm really glade you started a thread so I can follow your build.
CAL 58 GMC is offline   Reply With Quote
Old 11-14-2009, 12:05 AM   #32
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
Dan, the class I was taking is not offered anymore due to cutbacks in California, thanks Arnol.
I really don't know where to find a class now. So I'm trying to better my skill as I work on my truck.
Tri5.
Old 11-14-2009, 12:06 AM   #33
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
Thanks Cal, you are the inspiration for all of us on this forum.
Tri5
Old 11-15-2009, 10:05 PM   #34
Tri5Nerd
Tri5Nerd's Avatar
Narrowed my 9" rear end...
I started the notch and ran into an issue which was that the calipers from the orginal narrowed 9" was hitting the notch when the frame was lowered. So I got a boneyard Bronco 9" with a Trac Loc diff which I later found out was too long, I researched about getting the rear end narrowed to meet my needs, pricing to do it was too much for me at this time. I asked Kabwe how he did his and he provided the necessary info to encourage me to narrow mine. Well here is the result. I took out a total of 7" and centered the pinion.
With axles it will now be 58" wide.
Old 11-15-2009, 11:38 PM   #35
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Tri5 55 build
Looking good, I knew you could to it. Great work man
Kabwe is offline   Reply With Quote
Old 11-16-2009, 01:48 PM   #36
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
Thanks for your words of encouragement!
Tri5
Old 12-12-2009, 04:40 AM   #37
lonelywanderer
Re: Tri5 55 build
what brand are the engine mounts and trans cross member or did you make them yourself?
lonelywanderer is offline   Reply With Quote
Old 12-12-2009, 10:29 AM   #38
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
I made then off the oringinal motor mounts and used a NoLimit trans crossbar with poly bushing. I'm going to replace the bushings in the motor mounts soon to poly.
Tri5
Old 12-12-2009, 04:15 PM   #39
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Re: Tri5 55 build
Cool build, and nice score on two trucks. I don't know if I missed it, but did you sell one of the trucks or are you just building the one for now?
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 12-12-2009, 06:50 PM   #40
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
I sold the other truck and made my orginal purchase $$$$ back.
Tri5
Old 12-12-2009, 08:05 PM   #41
nickp51chevy
Re: Tri5 55 build
That's cool. You pretty much got a free truck.
Had;
Old 12-12-2009, 08:32 PM   #42
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
Not really free, all the parts I had to source, plus getting it titled in California was not easy, I had the CHP do the VIN inspection of the frame which was good and they gave me a stamp where the orginal VIN was. I still have a bunch more dollars to spend on paint, interior and Wheels.
Tri5
Old 12-12-2009, 08:40 PM   #43
laplander
Re: Tri5 55 build
So what's the bike with the old style metal flange Tuff wheels?? LOL
laplander is offline   Reply With Quote
Old 12-12-2009, 08:46 PM   #44
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
That bike is about 22 years old, it was my nephew's then handed down to my son who is 20 now and I still have it in the shed, it's a Mongoose.
Tri5
Old 12-12-2009, 08:59 PM   #45
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
50adrod.
I just found a vid of when I rebuilt the top end and started it up for the first time. It needed to be tuned then and now because I know have a FAST 92mm intake and throttle body. This was taken with my HP digital camera, that's why the crackling is here when the motor is reved.
Old 12-13-2009, 12:27 AM   #46
56ClassicTruck
Re: Tri5 55 build
Hi Tri5 man thats some nice work.....
56ClassicTruck is offline   Reply With Quote
Old 12-13-2009, 11:38 PM   #47
50adrod
50adrod's Avatar
Re: Tri5 55 build
50adrod.
sounds good what are your cam specs?
Old 12-14-2009, 12:06 AM   #48
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
232, 234 duration, 590's lift on a 112 lobe. Sometime after getting it running I'll be adding a Yank of Vigalante stall, I have a Super Streetfighter 3500.
Tri5
Old 03-14-2010, 01:17 AM   #49
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
It's been awhile since I post an update on my build, well I was in a state of depression after ordering my wheels and finding out that my front wheel was not centered in the wheelwell. After talking to Kabwe here and moping he said to me "What you going to do about it? You have to fix it". He offered to come by and help me with fixing the problem cause I've never done something like this before.
So today we got to work. Take a look at the 2 pictures and you will see the difference.
Old 03-14-2010, 01:24 AM   #50
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
Here's how the work was done, we took 1" out of the frame. Once again, a big thanks Kabwe.
