Old 01-21-2012, 09:48 PM   #26
iceship
Re: 6/8 drop
245/40/20 here
iceship is offline   Reply With Quote
Old 01-21-2012, 10:11 PM   #27
muthstryker
muthstryker's Avatar
Re: 6/8 drop
You could try the 73-80 fenders, I think they are taller so you have more room.
Matt
muthstryker is offline   Reply With Quote
Old 01-21-2012, 10:51 PM   #28
iceship
Re: 6/8 drop
So ur saying the arch is alittle higher than my 87.... hum ill have to look into that befor I get it painted... thanks
Old 01-21-2012, 11:11 PM   #29
muthstryker
Re: 6/8 drop
I was referring to inner fenders. Not the outer fender itself.
Matt
Old 01-21-2012, 11:12 PM   #30
iceship
Re: 6/8 drop
Ok my inner is gone
Old 01-21-2012, 11:29 PM   #31
muthstryker
Re: 6/8 drop
Ok, want to go lower, turn your wheels lock to lock. Measure how far the fender lip is from the tire and subtract atleast an 1-1.5"s. So with the wheels turned lets say its 4inches from the tire, you could drop the truck 2.5-3 more inches.
Matt
Old 01-25-2012, 10:02 PM   #32
iceship
Re: 6/8 drop
I cut a small peice off my 2"drop springs... so I'm alittle lower, but now my tires rub the fender on light bumps.... how many of u guys cut that part out...
Old 01-26-2012, 12:03 AM   #33
muthstryker
Re: 6/8 drop
Alot of people have cut that out for wheels to clear. Shouldn't be a problem.
Matt
Old 04-21-2012, 08:56 AM   #34
iceship
Re: 6/8 drop
Jonboy what size tires are u running......... I put my rally back on
Old 04-21-2012, 09:45 AM   #35
Jonboy
Slots go on anything!
Re: 6/8 drop
245/60 in front, 255/70 in the rear. The wheels are 15x8.5 all the way around.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-21-2012, 07:05 PM   #36
Square_78
Square_78's Avatar
Re: 6/8 drop
Originally Posted by camshaftgsxr View Post
mine is 5.something in the front and its already scraping the headers and control arms on big bumps... i donno how you guys do it.
I don't have drop spindles so my control arms have about 5" of clearance under them. My truck is about a 5.5/8 drop and i have just as much clearance underneath as a stock sports car. I have never once bottomed out on anything except the bump stops. Thats the one disavantage of drop spindles. Instantly puts the control arm 2-3" closer to the pavement. As long as you can align it afterwards then you are ok... I am only going to install drop spindles when I bag the front. I'll be able to raise the front way up to drive it anyways so clearance wont be an issue. I'll try to take a pic this week of the clearance under my front end. Im not saying this is the way anyone else should do it, Im just saying spindles cause ground clearance issues when you start running big drops and small tires.
Square_78 is offline   Reply With Quote
Old 04-08-2021, 04:07 PM   #37
HotRod C/10
HotRod C/10's Avatar
Re: 6/8 drop
Originally Posted by CLASSIC87' View Post
Here's about as close as a 6/8 I was able to go:
very nice job.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 04-09-2021, 09:59 AM   #38
photo-tom
Re: 6/8 drop
15x7
215/70r15 front
235/75r15 rear
215/70r15 all around
I've hit some pretty big manholes and road imperfections and haven't had any clearance or rubbing issues in the front with a smaller tire.
photo-tom is offline   Reply With Quote
Old 06-16-2021, 02:48 PM   #39
Richard D
Richard D's Avatar
Re: 6/8 drop
Is that a "redneck rear drop kit"?
Richard D is offline   Reply With Quote
