Re: the 71 "break up" build
got my engine done! ready to go in today and excited to hear it run. i powerwashed and cleaned up the front end and painted the frame a little
1969 chevelle 350 numbers matching 1971 chevy lifted 4x4 (the break up build) http://67-72chevytrucks.com/vboard/s...d.php?t=423605 1993 subaru impreza 1969 blazer cst 8" lift |
where do i bolt the negative battery cable to? it used to be bolted to my intake but it looked tacky
#3 | |
If you run the neg batt lead to the engine mount do so to the engine side of the mount. And there should also be at least 1 if not 2 ground straps that connect from the rear valve cover bolt to the firewall.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I believe they were bolted to the head in an accessory hole from the factory. If you want to hide it a little I would think one of the motor mount to block bolts would work.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
thanks for the help!
got it running two days ago and had to chase an intake leak down to the carb base gasket now my truck hauls i found out i have high compression pistons and its pushing about 400 hp
finally put on my warn bumper and a few body parts i had lying around.
your making great progress on building this truck, looks good so far.
Keep it up!
72 Chevy C20 Longhorn 72 Chevy, K20 Custom Camper 67 Chevy, LWB, C20, 350/350, PS, PB, 65 Jag MKII |
Yep, i am still enjoying this thread myself.
Back when i bought my truck i went to a national Truck Parts store, i asked the guy about a warn wench bumper, it was in the 90's and warn had stopped production on them, the store parts guy called and there was only 1 left in stock and it was i beleve $150, well i was thinking about how and where i was gonna carry my spare tire if i lost the front bumper tire carrier, so i ended up passing on it and have been kicking myself in the butt every since!
#10 | |
nice truck man, i have the same set up
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
i like to get a little crazy while driving in my truck and want to put shoulder seat belts in i see the bolt holes in the cab already. any suggestions of what belts will work best in my truck?
#13 |
I have heard that S-10 belts work, i just bought a brand new set of belts thru classic heartbeat a year or so ago, almost all the vendors that sell parts can get sholder belts. The only complaints i have with mine is i would like to have a plastic tube/sleeve holding the inner belt so it can be a 1 handed operation to buckle, the other is ya have to pull real slow or it latches on ya, but then again so does my dakota..
#14 |
i redid alot of my wiring and cleaned it all up but i found three wires im not sure where they go? my truck factory had saddle tanks factory so not sure if they are for those
![]() ![]() here are the wires im not sure about they were just bundled up behind the engine not hooked to any thing ![]()
#15 |
I'll take a look at mine tomorrow and see if i can spot them for ya.
#16 | |
The wire with the little clamp feet on it i have not been in that area of my truck for 15 years but i do recall there was a wire that was bolted to the bellhousing of the tranny that looks like its probably it, but i will have to search further to figure out the plug. The other greasy wire is leading me to think it may be the transmission TCS switch, it switches off the IGN advance when your in high gear, look at the side of the tranny and see if you can find a electrical connector that is missing a wire. I still have not had the time or good weather to go crawl under my truck, i have also been trying to attach a schematic but for some reason it won't attach to this post..
#17 |
i have a bad u-joint on the front drive and tried to unbolt the driveline and cant get a wrench or ratchet in there to unbolt it from the transfer case. are there any tricks?
#18 |
Might need to grind the thickness of a boxed end wrench down a little to get it to fit?
I totally spaced on the wire checking, do you still need me to do that? Sorry!
#19 |
ya if you get time im still wondering where the wires go but no rush
#20 | |
#21 | |
#22 |
i removed my drive line to find out that the knuckle that mounts to the transfercase is ruined. where do i get another one and how much should i look to spend?
#23 |
#24 |
Currently Blazerless
Usually these are easily repairable with just a kit that contains seals, washers, spring and a new ball socket.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 11-25-2010 at 09:40 PM. |
#25 |
Here ya go, try this company if you cant find them locally.....I've dealt with them before and they ship fast. http://www.dennysdriveshaft.com/p729...epair_kit.html
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 11-25-2010 at 09:43 PM. |
