Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 06-01-2011, 11:56 AM   #26
DesertCat
DesertCat's Avatar
Re: Rattle Can or Primer before body work...
Sam,
Found this, check it out... fantastic results!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=447159
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 06-01-2011, 03:27 PM   #27
SulphuriousSam
SulphuriousSam's Avatar
Originally Posted by DesertCat View Post
Sam,
I tried to post a reply a minute ago and then it didn't show up so if this double posts I don't know what happened!
Anyway, WOW! I'm sold on using the CLR. I had planned on doing that anyway but up till now hadn't seen any pictures that showed the type of results you can get...very impressed. Thanks for the link
I'll post up before and after pics once i can get it done. Hopefully as early as this weekend!
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348
2001 Suburban daily driver
2008 HHR (wife's ride)
SulphuriousSam is offline   Reply With Quote
Old 06-03-2011, 04:47 PM   #28
dgreen
cant you sand the bad spots and do the prep work and hit it with a can of primer like spot primer and then when it comes to painting sand the primer down and hit it with a spray primer ?
dgreen is offline   Reply With Quote
Old 06-03-2011, 04:55 PM   #29
ol_skool_chevy
ol_skool_chevy's Avatar
Here's an idea for you. But you have to promise to NEVER tell a single soul Ever...Its top secret.
ADD PAINT TO YOUR PRIMER...........I have done it many a times.
one qaurt per gallon.
It's not rocket science.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 06-03-2011, 10:03 PM   #30
SulphuriousSam
That sounds suspiciously like work
Nah j/k others left me thinking the primer would still soak up moisture. Painting (a real nice paint job) is years away so it's either paint her on the cheap, dents and all, or just wax after cleaning up with clr. I will probably do the later while this whole "patina" fad lasts!
Old 06-03-2011, 10:08 PM   #31
SulphuriousSam
Mum's the word Sir! Um, after decoding your secret message I'm left with the impression that mixing the paint with the primer will act as a sealer keeping out the moisture. Is that correct?
Please burm your monitor after reading so as to keep proper OPSEC Sir!
body work, paint schemes, rattle can paintjob
