Old 03-07-2012, 12:36 AM   #26
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 1964 Impala
20 gallon tank?
Does running 2 compressors require an upgraded alternator?
Did you notice any handling improvements or changes with the tubular arms?
I appreciate the info.
Zoomin is offline   Reply With Quote
Old 03-07-2012, 12:57 AM   #27
bmfm64
bmfm64's Avatar
Re: 1964 Impala
I'll see if I can find the link to the tank. I'm not sure that tubular arms helped as much as the bushings not being worn out! Seems to handle pretty well now. I would think you wouldn't have to do an alternator upgrade, mine is a 100 amp SI if I remember correctly. I'm planning a dual battery setup in the trunk with a regulator to keep all aftermarket electrical seperate from the normal car operations(I.e. starting). But the compressors definately need to be ran off a relay.
bmfm64 is offline   Reply With Quote
Old 03-07-2012, 02:03 PM   #28
nicke
nicke's Avatar
Re: 1964 Impala
Originally Posted by bmfm64 View Post
Thanks! I'm running twin Viair compressors and a single 20 gallon tank. The front bags have hydraulic hoses to them for longevity and the rest is DOT air brake air line.
Nice... Looks like a great setup!
-Nick
1965 Impala SS project Page.
My Wheels
Classic Nation
My classic car videos
nicke is offline   Reply With Quote
Old 03-09-2012, 02:24 AM   #29
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: 1964 Impala
Soooo... finally found a few free minutes to drive the car a couple weeks ago and aired it up and went to pull out and... BANG! luckily I was in the garage when the bag blew. So I found a set of tubular lowers and got to work. The geometry was terrible before and caused the bags to rub on a protrution off the rear end. So I cut the upper mounts to a wedge shape to get them to point more vertical rather than rearward. Cut the protrutions off the rear end, mounted up the new bags and bolted all back together. More better! Don't mind the zip ties... didn't have time to fab the bolt down tab for the e-brake cables.
Very nice job! I like the turn out.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 03-11-2012, 12:50 AM   #30
bmfm64
bmfm64's Avatar
Re: 1964 Impala
Thanks! Can't wait for a day off and no rain to cruise her!
Old 04-09-2012, 10:20 PM   #31
bmfm64
bmfm64's Avatar
Re: 1964 Impala
Got her out and took a couple pics, tried a few of the effects on my phone... Here's what we ended up with.
Old 04-10-2012, 06:39 AM   #32
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Re: 1964 Impala
Good looking ride...that last pic looks like I took my contacts out
Old 04-10-2012, 08:00 AM   #33
Pkh66
Re: 1964 Impala
I like your style.
Can say its not far off from mine.
Pkh66 is offline   Reply With Quote
Old 04-14-2012, 09:30 AM   #34
bmfm64
bmfm64's Avatar
Re: 1964 Impala
Nice collection^^ I've been working on my white one lately and hopefully she'll get some street time this summer too!
Old 04-14-2012, 11:41 AM   #35
Pkh66
Re: 1964 Impala
Thanks. Wish the impala was on air like yours. My c10 rides so much better afterwards.
Old 01-27-2013, 09:51 PM   #36
bmfm64
bmfm64's Avatar
Re: 1964 Impala
Been working on this a bit as of late, Got a valve changed in the air ride and installed a cable shifter conversion for the powerglide to 350 conversion. Now I can actually shift into all the gears where as before I only had P,R,N and D. I'll get some pics up soon.
Old 01-27-2013, 10:33 PM   #37
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 1964 Impala
Well, it's about time! Look forward to the pix.
Old 01-28-2013, 12:22 AM   #38
bmfm64
bmfm64's Avatar
Re: 1964 Impala
So here's the long story... I bought this kit about 15 years ago for my other car, decided to use it on this one so I had all three drive gears instead of just drive. Cable was bad when I opened it, of corse no receipt and the company didn't believe the 15 year story so ordered a new one and a few things that had changed since the original kit. Worked on it for awhile this afternoon until the 60 dollar neutral safety switch broke. no one in town had one on a sunday so I did some tinkering and used some old parts in the new switch and got it all working. Now I have P,R,N,D,L2, and L1 and my reverse lights work. Just need to vacuum the car and put the new A Arms onand she's ready for some sun! Now for the pics....
Old 01-28-2013, 12:23 AM   #39
bmfm64
bmfm64's Avatar
Re: 1964 Impala
And the new A Arms...
Old 02-03-2013, 01:36 PM   #40
Squareforceone
Squareforceone's Avatar
Re: 1964 Impala
Where are the pics of your first car?
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 01-30-2020, 12:49 PM   #41
bmfm64
bmfm64's Avatar
Re: 1964 Impala
Oh man... I forgot about this thread... I've made a few changes to the car!
Painted it, pin striped it, new wheels, skirts, interior... the list goes on and on.
And... the shop is finished, and filled. And now we are over flowing out the doors... good problem to have I suppose! Here's some pics for you guys.
Old 01-30-2020, 12:50 PM   #42
bmfm64
bmfm64's Avatar
Re: 1964 Impala
White car in the pics above is my first Impala. We put it back together last year to make a driver out of it just because.
