#26 |
Re: Can anyone help me?
Of course. Rubber, plastic, clamps, they can break. Just be as carefull as you can, if it breaks it was probably weak anyway.
John 82 Chevy Silverado 350ci/TH350 ![]() |
#27 |
I mean inside the gas tank! I dont know if theres anything in there that can break! and im about to upload my second video!
#28 |
#29 |
No inside the tank will be fine.
#30 |
okay, so my problem WILL have to be either the lines or this switch that im fixing! and should i cap off the switch where i pulled these hoses off ?
#31 |
Just connect the 2 lines from the right tank to the 2 lines from the motor, once you do that you dont have to cap anything. The valve and left tank will be rendered usles at that point.
#32 |
If your truck starts, your selector valve is bad or the switch in the cab is bad.
Selector valve is$99 at LMC and cab switch is $15.
#33 |
okay, thanks alot for all of your help man, im going to go to sleep now, but I will connect these tto after I buy some hose tomorrow and let you know how it turns out.
#34 |
haha, & if it doesn't start ?
#35 |
Sorry if im bothering you ! I don't have anyone to ask but people on this sight, I have a single parent( mom) dad wasnt EVER around!
#36 |
OK man good luck.
#37 |
No way bro, Im glad to help. I hate to see somone struggle. Let me know how it turns out.
#38 |
Hey man..
![]() Posted via Mobile Device
#39 |
No problem, just get a new selector valve and get a new cab switch for good measure, then you can use both tanks again.
#40 |
Well done guys!
#41 |
Tags |
dead battery, fuel pump, gas line, help me please, truck won't start |
