Old 10-14-2013, 11:29 PM   #26
jtp67-72
jtp67-72's Avatar
Re: Mounting and Plumbing AccuAir Elevel ideas
Originally Posted by knomadd View Post
Anyone got more pics of the porterbuilt piece? I'm curious where this is installed.
Here's where i just mounted mine in last 2 pics
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 10-15-2013, 09:28 AM   #27
knomadd
knomadd's Avatar
Sweet, Thanks! So I looked at Old Aux yesterday and I'm guessing that the bracket is intended to be used on raised bed floors. Is that correct? You both have them mounted in a similar location below your raised floor.
I'm not sure how you'd mount this under a stock height floor?
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-15-2013, 11:54 AM   #28
jtp67-72
jtp67-72's Avatar
Basically have to determine where u want the controls and then find the best place for your setup....none of mine was "set-in stone" ...I do a lot of experimenting to get what I think is best bang for buck....some like ...some dont.....That's the fun though.....jim
Old 10-16-2013, 08:26 PM   #29
STPrider
STPrider's Avatar
I have my tank in a similar spot as dznucks' on the first page, and my compressor, manifold, and wiring mounted on the inside of the frame in front of that. It keeps it fairly tucked up. I have my compressor intake filter in the cab to keep it clean and dry. I can grab a pic next time I'm under the truck if you want, though I must warn, it's not pretty!
'71 GMC pickup; "Ashley,"
STPrider is offline   Reply With Quote
Old 10-18-2013, 10:59 AM   #30
knomadd
knomadd's Avatar
Thanks guys. I don't have the parts yet. I'm still saving $$$, but it's lower on my priority list so it will be a while. I'm just trying to get some ideas. I may change my mind by the time I actually do my air management install.
Right now I'm leaning toward the PB tank/compressor mounts with dual compressors and 3 gal tanks on either side in front of the rear tires. I'm thinking the best place for the valve and control box will be in the middle somewhere, but I'm not set on that yet.
jtp67-72, I love how you dressed up your bed mounts. That's pretty slick.
-Duane
Old 10-18-2013, 06:34 PM   #31
jtp67-72
jtp67-72's Avatar
More coming..inc. mounting p.b. tanks....jim
Old 12-12-2013, 12:09 AM   #32
aclew62
aclew62's Avatar
Gofast68c20. Nice Hard line set up. im doing something similar.
aclew62 is offline   Reply With Quote
Old 12-12-2013, 12:14 AM   #33
aclew62
aclew62's Avatar
Superflystieny, that is Sick!!
Old 12-13-2013, 09:27 PM   #34
slowcpe
slowcpe's Avatar
Subscribing as I'm trying to plan out my new build.
Is there any option to mount the tank(s) under the bed of a stepside?
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-18-2013, 11:43 PM   #35
mac808
mac808's Avatar
Originally Posted by Envy View Post
I need pictures and ideas of how people have been mounting and plumbing their eLevel systems on a 64-72 chassis. Im running dual compressors and dual tanks, one on each side.
I'm sure there are a million and two ways to mount the eLevel system, including the ride height sensors. There are some really trick set ups all over this forum.
Not sure if you're asking to see options for mounting the manifold/tank/eLevel or how the sensors can be installed(or both), and if you will be doing a raised bed floor or keeping it the bed floor stock. If you are looking for a basic, non-raised floor, stock frame, non dropmember installation of the AccuAir system on the C10, here is how I have mine set up with the space I have available under the bed and between the frame without any modifications. I have a few pics of the sensor mounted as well if you need to see how I ran mine.
Hope that helps.
mac808 is offline   Reply With Quote
Old 12-27-2013, 02:07 PM   #36
stevencvn72
Kill Bill...et
stevencvn72's Avatar
I got lazy and used a pre-made compressor mount. Leaves plenty of room for e-level if I ever go that route. The bed is installed and raised a couple of inches leaving plenty of room for maintenance.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 12-27-2013, 09:22 PM   #37
cubber
Steve, I really like your truck!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
