Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 02-05-2012, 11:08 PM   #26
oklahomaduner
oklahomaduner's Avatar
Re: Our "What are we going to do?" 66 Suburban Build
You would copy my diff cover..
1966 GMC Extended cab 1 1/4 ton 4x4
My build thread
1958 Chevy 1 ton dually flatbed
My Dad's build thread
1966 GMC Custom Trim Big Back Window W/351e
My Time-Killing Project Truck
1966 (Not So) All Original Chevy Custom Trim Suburban
My Dad's Time-Killing Project Truck
oklahomaduner is offline   Reply With Quote
Old 02-05-2012, 11:26 PM   #27
Jeff La
Standing by waiting to see the progress. Nice burb
Jeff La is offline   Reply With Quote
Old 02-05-2012, 11:34 PM   #28
RockTonka
RockTonka's Avatar
Shouldn't you be studying bout now...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 02-05-2012, 11:47 PM   #29
protrash64
Resistance is Futile
protrash64's Avatar
Holy crap!! Those hubcaps look great!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-06-2012, 12:36 AM   #30
RockTonka
RockTonka's Avatar
They've got some dents, dings, and rash but are going to clean up alright!
My build thread
Old 02-10-2012, 08:45 AM   #31
duallyjams
duallyjams's Avatar
Sweet find.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-10-2012, 08:29 PM   #32
McMurphy
McMurphy's Avatar
Nice score!
Hope you keep us posted on your project.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 02-11-2012, 05:02 AM   #33
C@rnut001
Wow, that is an awesome looking suburban... I can see why you couldn't turn it down. Yep, I would get it running well and stop the rust and then just drive it. Great find and great that you guys are bringing it back to the streets.
C@rnut001 is offline   Reply With Quote
Old 02-11-2012, 06:15 AM   #34
RockTonka
RockTonka's Avatar
Thanks yall', we're enjoying the feedback! We're pretty psyched about the burb
We've got a good used tank coming our way from gostranger here on the board...thanks Steve!!
My son came in for the weekend from school and started fixing the wiring mess left from the original owner, i.e. pulling out an old CB/antenna, an ancient inverter, multiple switches/relays, air horns, a siren (that still works) and some crap we may never fiqure out. He also got the old, but not original, AM radio working.
While he got that done I managed to clean up the other hub cap.
My build thread
Old 02-11-2012, 07:54 AM   #35
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Looking good!!!
"Dave"
gostranger is offline   Reply With Quote
Old 02-11-2012, 08:26 AM   #36
northern 85
northern 85's Avatar
Wow luv the burb! Great find and you guys are doing it right
northern 85 is offline   Reply With Quote
Old 02-13-2012, 01:35 AM   #37
RockTonka
RockTonka's Avatar
It runs!!
My son and I spent most of this weekend chasing our tails trying to get this burb to fire and just, finally, got it purring like a fat and happy cat about an hour ago
We started sat. morning by draining/refilling old fluids, replacing filters, plugs, wires and cleaning up the obvious loose ends. Everything looked like it was supposed to and we thought we were ready to try to fire it off...wasn't happening.
No fuel tank so we were squirting fuel down the carb, backing off, and cranking away...nothing. Not a burp, fart, hiccup, cough...nothing. WTH.
Power to the coil but nothing out. No spark, alright then...new coil it is.
Drop a new coil on and try again...nothing. WTFH.
New points, condenser, cap, rotor, and new coil...everything seems right but no fire. We feed the coil directly from the battery, crank away and...backfires out the carb!! Well, good we guess...getting fuel and spark...kinda. Thinking maybe bad resistor wire or starter solenoid feeding the coil. Fool around with that for a while but can't pinpoint anything. We go back to feeding the coil from the resistor wire/starter and now have semi-consistent backfires out of the carb and nothing else. (gotta imagine me jumping back and forth with my squirter bottle of gas feeding the fire) WTMFH. Got to be timing...but now its 3 a.m. and we're beat.
Jumped back into this afternoon thinking we're missing the obvious. We knew the short term SIL owner had mentioned fooling with the timing and we ASSumed that he had it somewhat right, but...maybe not...so back to the basics.
We brought #1 up to TDC and low and behold...the dizzy was 180 out.
It's always good to find a problem though, now we had a direction.
Pull all the wires, roll about 10 degrees of advance into it, hook everything up correctly, and...woo hoo...smoke out the exhaust. Getting closer.
I was getting pretty leary of squirting gas at the carb by then and we knew it needed more fuel so we fiqured that it was time for a fenderwell tank. Drop a line to the fuel pump and...crank, crank, crank, crank, crank, crank. Sigh.
Pump was sucking it from the fenderwell but wasn't pushing any fuel to the carb...back to AutoZone...again.
New pump, check. Timing set, check. Fire to the plugs, check. Dash of gas down the carb, check. Fire extinguisher, check.
Crank, crank, crank, Vroooom!! And it RUNS!!! and stays RUNNING!!
Roll the dist. back and forth a bit and get it close by ear...smoooootth!
Kill it and start it a few times (just because we can). Smoke out the neighborhood for a few minutes.
Can't do much else right now but we do drop it into drive...creeps forward. Drop it into reverse, eases on back...cool.
It's starting to snow now and the kids have an hour drive back to school so time to shut it down.
The master is leaking a bit at the booster...will probably pick up a new master/booster combo tomorrow. Tank should be here soon...can't wait now.
Got it titled, tagged, and insured Fri but the boy made me promise not to test drive it until he gets back next weekend...gonna be a long week.
My build thread
Old 02-13-2012, 02:46 AM   #38
RockTonka
RockTonka's Avatar
Only pic I got from this weekend, wish I had one of all the smoke when we got it running
My build thread
Old 02-13-2012, 07:26 AM   #39
gostranger
gostranger's Avatar
Awesome great times!
Old 02-13-2012, 08:05 AM   #40
67swb72klb
67swb72klb's Avatar
thats a nice one congrats on the fire up
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-13-2012, 10:17 PM   #41
RockTonka
RockTonka's Avatar
Big, brown, box from the big, brown, van...full of weather strip kits for both the burb and my son's GMC...doors, windows, vent windows, windshields, everything except the side windows on the burb (backordered). I'm not really looking forward to all that.
My build thread
Old 02-18-2012, 09:44 AM   #42
gostranger
gostranger's Avatar
did you get the other box from the brown truck on wed i called you to follow up how did it fair on its trip? let em know thanks!
Old 02-18-2012, 10:01 AM   #43
darkhorse970
darkhorse970's Avatar
Very cool 'Burb...those hub caps look amazing!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-18-2012, 11:05 AM   #44
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Subscribed! I love your builds!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-18-2012, 03:04 PM   #45
Delmo
Delmo's Avatar
Looooove it. Nice score man and great job cleaning her up.
Delmo is offline   Reply With Quote
Old 02-19-2012, 01:16 AM   #46
RockTonka
RockTonka's Avatar
Thanks yall', we're having fun with this burb and appreciate the positive feedback.
My build thread
Old 02-19-2012, 01:43 AM   #47
protrash64
protrash64's Avatar
Just got my window seals from Classic Chevy in Kansas. Fixed were in stock; dont know about the sliders.
Old 02-19-2012, 01:44 AM   #48
RockTonka
RockTonka's Avatar
The tank made it in on Wed., no problems at all Steve...Thanks. That was a hell of a packing job , UPS could of thrown it off the plane as they passed overhead and it would have been fine!
I ran it to a radiator shop Thurs. to have it boiled out and the overflow tube resoldered on before sanding, cleaning, and painting it. The sending unit you sent tested alright, but we still dropped a new one in just to be safe. While we were chasing parts this morning, we ran by a carb shop and picked up a rebuilt unit to replace the leaking stocker. That and new rubber lines throughout had the fuel system in good working order.
I can put the fire extinquisher away now.
My build thread
Old 02-19-2012, 01:49 AM   #49
RockTonka
RockTonka's Avatar
Truck and Car Shop out of Orange,CA has my money for all fourslider weatherstrip kits and is sending one complete kit my way now...haven't gotten word on the other three yet...hurry up and wait. At least I can jump into one and try to figure it all out.
My build thread
Old 02-19-2012, 02:03 AM   #50
RockTonka
RockTonka's Avatar
While we were under the burb...well alright, as my son was under the burb, we discovered that the carrier bearing was shot. Another trip to O'Reilly's later and we had a new carrier and ujoint to rebuild the driveshaft (joint at the axle was good).
So with a mix of lead additive, marvel mystery oil, and 10 gallons of gas in the tank, my son fired her up and eased out of the garage for the first time under its own power (with us at least).
My build thread
