Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 03-31-2012, 07:12 PM   #26
Dub_X
Professional Crow Bar Tosser
Dub_X's Avatar
Re: 94 Suburban to Crew Build: The 50/50 Turban
Thanks, Chris. It's getting there.
Did some patchwork today on the driver's side.
Here's a couple after cutting out some more of the body
And here's a few shots of the patchwork on the driver's side
First set of patch panels: Lower body and cab corner
Second patch panel: The gap between the two cabs, where part of the Suburban back glass was.
It's definitely getting there. Slowly, but surely!
Dub_X is offline   Reply With Quote
Old 03-31-2012, 07:33 PM   #27
benoit454
Chris
benoit454's Avatar
nice work!!
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 03-31-2012, 09:45 PM   #28
TowwDogg
TowwDogg's Avatar
Sorry Son, But I am not as good as most of the guys on here when it comes to welding the body panels, I am used to heavy steel not paper thin sheet metal.
I have to give credit to the guys that do body work. Some of the builds on this site display a real talent for welding body panels. This truck has been a learning experience for me as far as body work goes. It is not easy welding panels without distortion when your used to burning in thick welds on heavy steel. Its a new kind of welding for me and I can see why I need a good mig with gas, Its Very easy to mess up a panel with a Mig burning .035 flux core wire. I will have to use my share of filler on this build. We need to start looking for a new Mig welder...
TowwDogg is offline   Reply With Quote
Old 04-01-2012, 09:55 PM   #29
TowwDogg
TowwDogg's Avatar
I switched to 030 wire and it welds much better without burning through. I still need a good mig with gas... but this will get the job done
Old 04-01-2012, 11:17 PM   #30
rocking chevy
rocking chevy's Avatar
looks good
rocking chevy is offline   Reply With Quote
Old 04-02-2012, 12:40 PM   #31
Dub_X
Dub_X's Avatar
Got work started on the passenger side, working on patching that up.
First patch was the window gap. Then started on cutting out the lower body to put in a patch.
Here's the first set of lower body patches
The lower bodyline didn't line up right, so we put in a bodyline patch in place.
Nice shot from the back
Old 04-02-2012, 04:09 PM   #32
Rimshot1911
Rimshot1911's Avatar
That looks a lot like a dodge ram mega cab now! HaHa! Lookin good! Keep up the good work!
"Live free or die" LaRue Tactical
"Just think. Someone worked hard to make it look that bad." 1badgmc
1997 C1500 V6 Reg Cab Short Bed
Rimshot1911 is offline   Reply With Quote
Old 04-02-2012, 04:16 PM   #33
Dub_X
Dub_X's Avatar
Lol, the mega cab piece is a little longer than Dodge's. I think Dodge has 8 inches of cab behind the back doors. We've got exactly 16.
Old 04-02-2012, 04:23 PM   #34
Dub_X
Dub_X's Avatar
I could be wrong on Dodge's mega cab, because I've never gone up to a random Dodge and measured the length behind the back doors LOL, but I think I'm pretty close.
Old 04-02-2012, 04:54 PM   #35
TowwDogg
TowwDogg's Avatar
Finally feels like we are getting somewhere now.
Old 04-02-2012, 10:52 PM   #36
loudnlifted88
loudnlifted88's Avatar
now whats going be be behind the cab? are you going to use a full size truck bed or?
IM ONLY 18 AND LOVIN IT
IF MUD AINT FLYIN YOU AINT TRYIN!
1badgmc- Just think. Someone worked hard to make it look that bad.
1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383945
1994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438873
1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build
1998 GMC K-1500 ECSB 305 auto partd truck
1999 GMC K2500 suburban 350 4x4 Dads project
1981 Corvette 350 auto Also Dads project
1989 Corvette 350 auto ^^
1998 GMC K1500 ecsb 305 auto Brothers project
loudnlifted88 is offline   Reply With Quote
Old 04-03-2012, 12:06 AM   #37
Dub_X
Dub_X's Avatar
We're going to extend the frame and put a shortbed on it. But we're still a ways from that. Still have to get the cab finished. 'Cause it's not done yet lol.
Old 04-03-2012, 10:08 AM   #38
loudnlifted88
i want to do the same thing but with my dads 3/4 ton burb but i want to make a regular crewcab with a full size short bed
Old 04-03-2012, 10:21 AM   #39
TowwDogg
TowwDogg's Avatar
One of the reasons we went 16 inches long on the cab from the pillar to the back of the cab is because of the location of the third set of body mounts. If you cut it off behind the doors you will end up using the rear cab mounts from the doner cab since the third set of mounts will be removed from the burb. We may still add them to our build. We will only need about a 26 inch extention for the short bed to fit.
Old 04-03-2012, 12:25 PM   #40
loudnlifted88
i was going to get half of a ext cab shortbed frame and weld it to the burb frame and use the ext cab rear cab mounts for the rear cab mounts on the crew cab
Old 04-03-2012, 06:33 PM   #41
TowwDogg
TowwDogg's Avatar
That will workout nice. we are going to build a second truck when this one is finished and that one will be a complete frame off build with a truck frame and the burb frame.
Old 04-04-2012, 09:22 PM   #42
rocking chevy
a dodge maga cab has 20 more inches of cab added to it, about 10 in the back of the cab and about 10 in the rear doors.
Old 04-04-2012, 09:38 PM   #43
Dub_X
Dub_X's Avatar
I'm just meaning in the back space behind the doors itself.
Old 04-04-2012, 10:54 PM   #44
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
that looks good!!
can't wait to see it with a bed
tommie is offline   Reply With Quote
Old 04-05-2012, 12:05 AM   #45
Dub_X
Dub_X's Avatar
Well, here's a few frame pics for all you truck build junkies. Lol
Started stripping the Burb frame
Cut the frame out from under the '98
Set the '98 frame on top of the Burb frame, and started stripping it.
'98 frame is now just the frame rails
Old 04-05-2012, 10:40 AM   #46
loudnlifted88
looking good
Old 04-05-2012, 12:46 PM   #47
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
Will you be boxing the frame in? Or welding it in like you'd do if you were converting a long bed to a short bed?
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 04-05-2012, 05:30 PM   #48
TowwDogg
TowwDogg's Avatar
Hi Im Norm, will's (DUB X) dad, We did a Z notch to stretch the frame. Yes the same way it would be done to make a short bed frame from a long bed frame. He will have pics up by friday of that. We still have to replace cross members but we need to decide which tank we are going to use, The Burb or the Truck tank. That will determine which cross members we put back in.
Old 04-05-2012, 10:01 PM   #49
chris@bigjranch.com
KIDHLR
chris@bigjranch.com's Avatar
Looks like your project is comeing along nicely!
Don't know if it makes a difference to you guys, but, when I got done useing the truck tank for my kidhlr, the gas gauge reads half a tank when it's empty.
also it is kinda nice to have the bed empty and not worry about where to put a spare tire.
Sometimes I wish the tank was bigger and I didn't have to stop at the gas station every 200 miles, but at least it doesn't hurt as bad when I do. LOL
Christopher Johnson
Project - Grafted In AKA the "KIDHLR"
Conversion - KIDHLR Meets LPG
KIDHLR 2.0 Rise of the diesel(a 6.5 powered 6 Door pickup)
Romans 11:17-22
"Branches were broken off so that I could be grafted in"
chris@bigjranch.com is offline   Reply With Quote
Old 04-06-2012, 06:36 PM   #50
Dub_X
Dub_X's Avatar
Here's a BIG update
Marking down measurements for the z-notches
Z-Notching the frame
'98 framerails sitting in place
All welded up with the bumper in place
Tires back on, and the back of the springs re-hung
Woo hoo! It's coming along nice.
