05-24-2012, 12:00 PM | #26 |
Re: My New Fuel Tank Conversion
That's pretty nice set-up. I s'pose the Nova tank would work the same, right?
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
05-24-2012, 05:47 PM | #27 |
Im glad you mentioned the slow fill issue------------ (I didnt want to bring it up)
If I see what I think I see (?), that could be your fill issue--------------In one of the pics, looking into the filler neck, it appears that your extension is slipped over the existing (on the tank) cap flange. I was wondering if the flange aprox. 6 inches down would cause backsplash when filling. Sounds like it might , if indeed the original neck flange is still there. Ive talked to several guys at car shows who have done this type of tank install---and havent heard of filling issues (with the camaro tank and neck). Anyway, its a thought----------- |
05-30-2012, 01:47 PM | #28 |
I'm tempted to do a similar conversion myself. I just got a '72 GMC 1500 and would like to get the tank out of the cabin.
What size is the camaro tank? So did you end up just leave the original tank filler on the driver side cab? Also how close to the exhaust to the tank? I can't quite tell from the pics you provided? I have dual exhaust that may interfere with this type of conversion. |
05-30-2012, 04:50 PM | #29 |
Need to find you a gas station that you can Park down hill at
1970 c-10 lwb named "heavy metal therapy" |
08-04-2012, 03:00 PM | #30 |
Location: North Cal and no Sac or Bay area is not NORTH
Tag for the genius speaker idea
Never argue with an idiot, they will bring you to their level and beat you with experience.. |
12-07-2012, 03:18 AM | #31 |
Sub'd
Posted via Mobile Device |
12-07-2012, 06:02 AM | #32 | |
HTH, sam |
02-01-2014, 12:08 AM | #33 |
Wow! That is amazing, kudos to you. I am also planning on moving my tank out of the cab. I appreciate the documentation of your process as it will make my install go smoothly. Cool idea on the gas tank!
02-01-2014, 06:23 AM | #34 |
Old member
Just wondering since I saw this last year on the Power Tour. Have you ever noticed gas coming out of the cap on hard acceleration? I was following a guy last June on the tour and everytime he nailed it he would loose a bunch of gas. It would just pour out of the tank. I finally cought up to him and told him. He was like what! His buddy stood behind the car and when he took off it left a nice puddle in the parking lot.
Just something to check on.
02-01-2014, 01:27 PM | #35 | |
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
02-01-2014, 02:27 PM | #36 |
Nice project MAC. Nice use of the stock tank too. I have one thought/ concern about your tank mounting. In the 4th pic that you originally posted (the one with the washer stack) you have the strap ending with an angle then going over to the bolt. I would think that after a time that the strap would straighten out an allow the tank to loosen. Two choices that might help would be to loop the end of the strap using a bolt with a tee end to bolt it in or to use a piece of angle iron to reinforce the end of the strap. Keep up the cool work!!
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
02-01-2014, 04:11 PM | #37 |
Did you just use the camaro sending unit? And if so does the gauge read right?
1970 SWB "old flame" 1967 SWB c10 sold 1972 Elcamino 496 2012 Denali HD dmax |
07-05-2018, 01:22 PM | #38 |
Wow! You guys have some great ideas in action here! I love the rear fill under the license plates like the cars have.
07-05-2018, 07:03 PM | #39 |
I love it. Subscribed.
