Old 05-07-2012, 10:46 PM   #26
clinebarger
Re: Ls alt wiring
Originally Posted by ls1nova71 View Post
According to that table, 13.8 is 60%???
So is 100%
"When there is loss of class 2 communication with the powertrain control module (PCM), the module will send 100% duty cycle, 13.8 volts"
"Between 0-5 percent and 100 percent are for diagnostic purposes"
"the generator battery control module is limited between 36-90%"
clinebarger is offline   Reply With Quote
Old 05-08-2012, 11:50 PM   #27
Daaaanz67
Re: Ls alt wiring
Sorry for the late response. My truck is not on the road yet but hopefully by the end of this month or early part of next month. I will try to give full report as soon as I can. Yes I used 2004 because lt1swap said the pinouts are similar for 2003-2007 with blue green connector. Also 2006 may have fewer wires. This I found true as I started to strip my harness of unneeded wires. My computer was not flashed for this. Might have to look into the flash later when the truck is on the road. Doesn't the gbcm also get information from the bcm so it can control the field duty cycle?
Daaaanz67 is offline   Reply With Quote
Old 05-09-2012, 12:36 AM   #28
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Ls alt wiring
Interesting thread.
y5mgisi is offline   Reply With Quote
Old 05-29-2012, 09:09 PM   #29
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Ls alt wiring
And this is why I just sent my computer and harness to Speartech to get modified and rewired per my application. Definatly interesting thread though.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 05-30-2012, 12:57 AM   #30
awhite4557
awhite4557's Avatar
Re: Ls alt wiring
I also used speartech, plugged it in and it has worked like a charm every since. Definately worth the money.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2002 Winnebego Class A MH Ford E-550 Chassis V-10
2005 Dodge Ram 2500 5.9 Cummins
2008 GMC Denali
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 06-25-2012, 01:27 AM   #31
chevyman70
Re: Ls alt wiring
I am doing a similar build. My alternator has two wires coming out, gray and brown. They are going to the pcm. So I guess I have the same question, where do I attach my (70 truck brown wire) so that I can use the original gauge? I was thinking of splicing into the alt's brown wire. Any ideas?
chevyman70 is offline   Reply With Quote
Old 06-25-2012, 07:42 PM   #32
clinebarger
Re: Ls alt wiring
A '70 pick-up has a ammeter, If it worked before, It will work when your done. Leave the "LS" alternator regulator wiring alone.
Old 06-25-2012, 07:50 PM   #33
chevyman70
Re: Ls alt wiring
It did work before I did this swap. Alright, I'll leave it alone. Hopefully it works. I haven't fired it up yet.
Thanks!
Old 05-07-2013, 05:59 PM   #34
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Ls alt wiring
Old thread, but didn't want to start a new one...
I want to make sure I have this right, or it's ok to run mine this way...
5.3 LS swap
I want to have a distribution block, with battery in. Then the other three ports will have starter, alternator, and then an open port for now. 4ga wire all around
This safe/ok?
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 05-08-2013, 10:30 PM   #35
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Ls alt wiring
5.3 LS swap
This safe/ok?
You should be fine running it like that. I would still put a fusible link in the output of the alternator, though.
Old 05-09-2013, 12:23 AM   #36
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Ls alt wiring
Thanks Chevydog!
77' Chevy SB
5.3/4l60e combo
Old 06-20-2013, 11:49 PM   #37
Roostboy102
Roostboy102's Avatar
Re: Ls alt wiring
I've been searching and reading for the last hour and can't really find a clear answer! What happens with the original three alt wires when doing an ls swap? Theyre not used? I'm having wiring problems (voltage reg making noises, truck goes dead...) but I have 2 of the old alt wires hooked to positive off the alt. I'm just so confused and can't find an answer!!!
With the new style alt how does the truck get power to operate lights and things? If I understand correctly I don't need a voltage reg anymore?
Appreciate any help guys
72 C10 - Multicolor, 4.8 ls, NV3500. Sold
72 K5 - Under Construction
Roostboy102 is offline   Reply With Quote
Old 06-21-2013, 12:11 AM   #38
ls1nova71
ls1nova71's Avatar
Re: Ls alt wiring
You don't need your old voltage regulator or the wires going to it. The lights and stuff get power from the small junction block mounted on the fender by the battery, the red wire going to the big plug on the firewall (that the fuse box plugs into), that wire splits off and one part went to the voltage regulator. Just remove it, your alternator will be controlled by the PCM.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-21-2013, 06:22 AM   #39
Roostboy102
Re: Ls alt wiring
Ok so it is just that simple. I was reading like resistors and dummy lights and splicing wires off the regulator... And I was just confused! Thank you!
Old 06-21-2013, 09:23 AM   #40
ls1nova71
ls1nova71's Avatar
Re: Ls alt wiring
You only need the resistors if you're going carbureted and don't have a PCM.
Old 06-22-2013, 06:55 AM   #41
Roostboy102
Re: Ls alt wiring
Ok thanks!
Old 06-22-2013, 11:25 PM   #42
solidaxel
solidaxel's Avatar
Re: Ls alt wiring
Following this future hook ups
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-23-2013, 11:17 AM   #43
themb2g
Re: Ls alt wiring
So i have an single wire alternator on an 07 LQ4 with a 2002 wiring harness and PCM. The red goes to the battery, the black grounds to the engine. Where do I hook in the brown wire from the gauge cluster? if there is soemthign that goes back to the PCM, where does it plug into?
here is a pic of the alternator
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
Old 06-23-2013, 01:19 PM   #44
ls1nova71
ls1nova71's Avatar
Re: Ls alt wiring
You have an old "one wire" alternator, they're self exciting and don't have any other wires. You should be fine with just the battery wire. Personally I don't like them, but they became popular since they're cleaner looking with out the field wires. You generally have to rev the engine a certain ammount to get the alternator to kick on, but isn't really that big of a deal.
Old 06-23-2013, 04:34 PM   #45
themb2g
Re: Ls alt wiring
Thanks for that info. Im still wondering where the brown wire to the cluster gauge goes now as well as do i have to hook anything up to the pcm?
Old 06-23-2013, 06:37 PM   #46
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Ls alt wiring
Brown goes to generator lamp.
Old 06-23-2013, 09:26 PM   #47
Daaaanz67
Re: Ls alt wiring
I don't think you can use that ammeter as a voltage guage. It's been explained before in another thread actually by ls1 nova maybe it was this thread since I started it. I'm not using my ammeter.
Old 06-23-2013, 10:06 PM   #48
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Ls alt wiring
True. But originally the brown wire went to the generator lamp.
Old 06-23-2013, 10:53 PM   #49
themb2g
Re: Ls alt wiring
so the brown wire goes no where in my case?
Old 06-23-2013, 10:58 PM   #50
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Ls alt wiring
Right. Don't even need to hook it up. Just run a volt meter.
