Old 06-04-2012, 09:44 AM   #26
98layinframe
98layinframe's Avatar
Re: 1947 S10 4x4 Blazer swap
Wow love this build so far! Im also planning to use a 4x4 s10 suspension under my truck so this build is very interesting to me. Also like the s10 bed floor section.. was it a fleet side or stepside bed floor?
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 06-04-2012, 09:57 AM   #27
98layinframe
Also can i ask how far from the front fenders do the wheels sit in with the 4x4 wheels? Im planning to use 2wd standard offset (4.5" backspacing) wheels and wondering how close to the fenders they'd sit.
Old 06-04-2012, 11:52 PM   #28
msaintg
msaintg's Avatar
thanks. I used a short bed fleet side. I wish I could have found a long bed, but it was cheep. I am not sure how the wheels sit in the fender... I have not measured that. If I had to guess, I would say 4". I will measure that the next time I have the fenders on.
msaintg is offline   Reply With Quote
Old 06-04-2012, 11:55 PM   #29
msaintg
msaintg's Avatar
Spent some time today working on the drivers side cab corner, but mostly I modified the transmission hump from the Blazer to fit in the truck. I found a lot more rust in the floor once I ground all of the dirt off. Oh well. Not done, but you get the idea.
Old 06-05-2012, 04:07 PM   #30
49ZR2
49ZR2's Avatar
Looks like your having fun! I like the fact your on a budget and keeping the costs down keeps the creative juices flowing!
I've been enjoying mine.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=372267
49 4x4 build
51 Willys frame off beer getter.
49ZR2 is offline   Reply With Quote
Old 06-06-2012, 07:53 AM   #31
msaintg
msaintg's Avatar
ya, I'm bummed that I can't use the Blazer AC unit or tail lights. I am still eyeballing the Blazer doors and tailgate trying to decide if I am going to cut them up for sheet metal, door latches, power window stuff, etc. I am running out of flat sheet metal to make patches from.
Old 06-06-2012, 09:24 AM   #32
1952ssr
1952ssr's Avatar
Nice project, sometimes the only way to learn is just to do it and if you mess up figure out why and do it again. Can't wait to see it finished.
1952ssr is offline   Reply With Quote
Old 06-07-2012, 10:12 PM   #33
jed971959
nice work you are not alone on this one. I'm working on a 1949 chev 5window p/u on a 1997 jimmy 4x4 frame
jed971959 is offline   Reply With Quote
Old 06-08-2012, 12:00 AM   #34
msaintg
msaintg's Avatar
Are you going to lengthen the frame or shorten the bed? Are you keeping it 4 wheel drive?
Old 06-08-2012, 10:14 AM   #35
jed971959
will only be a 2wd don't want the 4wd.
going to make a flat bed to get it on the road then take the back frame from a 2nd blazer to make the right wheel base
have you gone your wipers working . i used the rear wiper off a 2002 blazer
Old 06-08-2012, 10:35 AM   #36
jed971959
if you need any info on the wiring let me know Ihave the wiring diagrams or anything I can help with.I rewired everything from the computer to inside of the cab . have the fuse box ,relays(used from blazer) under drivers seat
Old 06-08-2012, 03:31 PM   #37
waybad
waybad's Avatar
I would like more info on this wiper motor swap?? looks killer!!
waybad is offline   Reply With Quote
Old 06-09-2012, 07:50 AM   #38
msaintg
msaintg's Avatar
Is there any reason why guys use the REAR wiper motor instead of the FRONT one? I have both. just wondering.
Old 06-09-2012, 09:45 AM   #39
jed971959
the front goes completely around and the rear only goes about 120degress
it's more like the vac wipers that were on the trucks
i have more pic of how I did my wipers if you want to see them
Old 06-09-2012, 01:59 PM   #40
Larry Lindley
Very good on this project.great ideal on the front axle,the new two wheel dr. frames are set to be used both ways.your work looks good,no matter how long you work on these,you always learn something new.
Larry Lindley is offline   Reply With Quote
Old 06-10-2012, 03:24 PM   #41
msaintg
msaintg's Avatar
Wow, I would have never given that any thought till I got there and then I would have been stuck if I had sold the rear wiper motor. thanks.
ya, I would like to see the linkage if you got pics of that.
Old 06-10-2012, 03:34 PM   #42
msaintg
msaintg's Avatar
Put in a lot of time this week patching the battery box hole, passenger side corner rust and filling the four holes for the old pedals. I ran out of gas for my welder so I shifted my focus to body filler. Wow, this is hard. I don't know how you guys do it. I have a lot more work to do to get everything flat and smooth, but I got it to a point where I could put on some primer on it to see where my problem areas are.
Old 06-17-2012, 02:40 PM   #43
msaintg
msaintg's Avatar
Weekly update (I think this is week 18 of the build). I used the seat mounts from the Blazer and mounted my new seat frame to the floor of the cab. I then put the cab back onto the chassis to get the running board brackets set up and put on. I also spent a little time placing stuff like the ECU and cruise control on the fire wall to see where all the wiring is going to end up.
I really like how its sitting so far... the running board (and frame) is about 7" off the ground at the front fender.
Old 06-23-2012, 07:13 PM   #44
msaintg
msaintg's Avatar
Week 19 - Didn't do much this week... getting real hot out there in AZ. I lengthened the steering shaft and installed it. I also spent some time rerouting and connecting the brake lines to the master cylinder because I had to remove the anti-lock braking module (because it was too big to fit)
Old 06-30-2012, 07:00 PM   #45
brianthelion02
Overdrive club
brianthelion02's Avatar
Looks great!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 07-01-2012, 04:11 AM   #46
55dude
55dude's Avatar
great swap! anyone near La Quinta Ca. doing a swap? I would like to check your project out.
55dude is offline   Reply With Quote
Old 07-01-2012, 07:17 AM   #47
Johnny49
If you're a total amateur with very limited tools, I hate to think what I am! Can you come do my truck when yours is done?
Great looking project. I'll look forward to following your progress!
Johnny49 is offline   Reply With Quote
Old 07-11-2012, 12:30 AM   #48
msaintg
msaintg's Avatar
week 20. I took a week off because of the heat, then last week I hauled all of my scrap steel... over 1100 pounds ... to the recycle place and got a wapping $87 for my troubles. I also got a screwed up back in the process... sheeeesh! After taking a week off for that, I was back at it this week... even though it is still getting up to 112 deg. here.
I don't like how the side posts on the bed just come down and end like they do, so I decided to drill out the spot welds and remove them. The front one will get moved forward (towards the front corner) more to close the ugly gap at the cab. All four supports are now rounded at the bottom. Not done, but you get the idea......
Old 07-11-2012, 07:47 AM   #49
Larry Lindley
looking good
Old 07-11-2012, 06:02 PM   #50
Don Johnston
your doing a good job I'll be doing the 4x4 next year so i'am taking notes. have you done anything with the bed yet? I know the frame rails are going to be some what of a problem. thanks for your ideas.
Don Johnston is offline   Reply With Quote
