Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-19-2012, 09:47 AM   #26
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Re: 72 Dropmember Suburban
Gonna look sweet once it's a roller!
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 06-21-2012, 07:53 AM   #27
blfuller123
blfuller123's Avatar
Stopped by the shop yesterday and the front clip has the body work done and there is primer on it and the firewall. I ordered some porterbuilt hood hinges the other day and will hold off painting the firewall until I get them fitted.
blfuller123 is offline   Reply With Quote
Old 06-25-2012, 02:11 PM   #28
blfuller123
Today, got the front suspension done. I am supposed to have the rear notch Wednesday and with any luck, I will have a rolling chassis by the end of the week.
Old 06-25-2012, 02:18 PM   #29
kev2809
low n' slo
kev2809's Avatar
looks good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 06-27-2012, 01:39 PM   #30
zellway
zellway's Avatar
I have been thinking of doing a dropmember on my other Burb now that I have a nice driver. Your sub it going to be sick! How are you going to do the floor out back?
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 06-27-2012, 01:48 PM   #31
blfuller123
Originally Posted by zellway View Post
I have been thinking of doing a dropmember on my out of my other sub now that I have a nice driver. Your sub it going to be sick! How are you going to do the floor out back?
Thanks! The floor....Im not that far along yet. I actually started taking the inner fenders out today. A lot more than meets the eye. Looks like I will end up cutting the factory ones out and putting new taller ones in. The center has to be cut out and I will probably just make up some kind of cover to go over it.
Old 06-27-2012, 03:35 PM   #32
blfuller123
I have to give it to Nate at Porterbuilt. I know that his build time right now is running about 2-3 weeks. I called him last week asking how quick I could get a notch kit and he told he could get it out on Friday. I said perfect and I went ahead and ordered the hood hinges at the same time. I didnt expect to get the hinges for a while but everything showed up today.
If it wasnt already 105 degrees today, I would be starting on the notches. Guess I will get started early in the morning.
Old 06-27-2012, 04:10 PM   #33
kev2809
low n' slo
kev2809's Avatar
nice!
sure wouldn't mind havin a set of those hinges ..
-_--_--_ _________
Old 06-28-2012, 08:55 PM   #34
blfuller123
Spent the better part of the day getting the notches welded in. They are done and if tomorrow goes like I want, I will have a rolling chassis.
Old 06-29-2012, 12:40 PM   #35
blfuller123
I have a roller now, well add front wheels and tires and I will. Got the back all finished up.
I think I might to ditch the drop spindles and go back to the factory ones unless I want to use 22s in the front.
Next will be getting the hood hinges fitted and getting the back floor cut out.
Old 06-30-2012, 04:27 PM   #36
blfuller123
Got this idea to convert the back hatch to struts from Coboyle04.
Old 07-02-2012, 02:54 PM   #37
blfuller123
The body is now at home on the chassis.
The floor and fenders are cut out. Going to have to cut a little more on the inner fenders, they are sitting on top of the tires.
Old 07-02-2012, 08:12 PM   #38
Burb 71
Burb 71's Avatar
Wow, that looks really good. It sure is turning out nice.
Burb 71 is offline   Reply With Quote
Old 07-04-2012, 07:36 AM   #39
bruin_d
bruin_d's Avatar
Originally Posted by blfuller123 View Post
Got a little time in the garage and got the notchs made up for the rack and pinion. My rear notches are supposed to be shipped on Friday so I will be busy next week. With any luck I will get the chassis together and get the body set back on it.
I need to figure out how I am going to do the back floor. Obviously I need to cut out a section of the floor and move the inner fenders up just dont know how I am going to do it yet.
If you check out my build thread you can maybe get some ideas from what I did. Mine is the same build as yours (Porterbuilt front and rear).
bruin_d is offline   Reply With Quote
Old 07-04-2012, 12:44 PM   #40
zellway
zellway's Avatar
Great progress! Looking good
Erik
Old 07-04-2012, 02:26 PM   #41
502ms
502ms's Avatar
Love, love, love this!
I want this.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 07-04-2012, 02:36 PM   #42
blfuller123
Thanks!
I got some fenders that I am going to make work. They are about 3 inches higher than the factory ones. I may try and use the bottom of the factory fenders combined with these and bring them up as far as I can to the brace under the window, and then I will just have to make up some kind of cover for the notch and bridge.
Thanks!
I want this.
Thanks!
Old 07-04-2012, 09:34 PM   #43
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Looking good!... What are your plans for wheels and tires?
Old 07-04-2012, 11:32 PM   #44
bruin_d
bruin_d's Avatar
[QUOTE=blfuller123;5468774]Thanks!
QUOTE]
My tires went all of the way up and actually touched the brace under the window. I'm not sure what size wheels/tires you're going to run but just something to think about. Good work by the way!!
Old 07-05-2012, 12:32 AM   #45
blfuller123
Thanks, I think I am going to do 20s in the front and 22s in the back, havent decided on a wheel yet.
Yea, I think using these fenders mated up with the factory ones will make it tall enough. What size tires are you running in the back?
Old 07-12-2012, 08:12 PM   #46
blfuller123
My kids are in town this week and next week so I havent really had a chance to do any work. I went by the shop today and dad got the firewall painted.
Old 07-18-2012, 05:00 PM   #47
blfuller123
I was originally thinking of doing the paint like this:
But after seeing this, I think this may be it.
Old 07-18-2012, 06:09 PM   #48
kev2809
low n' slo
kev2809's Avatar
I like the second one, but without the white below the trim. Truck is lookin good! What blue is that?
-_--_--_ _________
Old 07-18-2012, 10:19 PM   #49
blfuller123
Well, my wife likes the first one so I guess that is the winner. Think I will run the blue up to the bottom of the windows though.
Old 07-18-2012, 11:11 PM   #50
nt30
What about blue up to the body line then white the rest of the way?
nt30 is offline   Reply With Quote
