Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-26-2012, 02:12 AM   #26
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Low Beam Relay Not Functioning
Put a jumper between 30 and 87 on the low beam relay and see if the outside lights come on the low beams. If they don't come on then the 30 terminal is not getting power, The wire to the outside lights on low beam is bad or the low beam filaments are blown.
If they do come on then the relay is not working.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-26-2012, 10:32 PM   #27
fixit-p
fixit-p's Avatar
Since you have a multimeter you can do a lot of troubleshooting right at the relays. Ground the multimeter to the battery and probe terminal 30 for power, if that's OK move to next step.
Next with the lights on and dimmer switch switched to relay being tested probe terminal 85 for power if you have power on terminal 85 then move the probe to terminal 86. Any reading over .2 volts on terminal 86 is an indicator of a poor ground no reading would indicate a possible open relay coil. If the reading on terminal 86 is high fix the relay ground if it is <.2 volts check terminal 87 for power.
I personally recommend using terminal 85 on the relay for ground and terminal 86 for switched power because some relays have diodes across the coil and reversing the polarity can kill the relay. I always check the diagrams on the relays I use.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-27-2012, 01:48 PM   #28
utee05
Thanks I'll check this out tonight. Hopefully I can determine the root cause. I'll also take some pics of the relays I have to make sure I am wiring those up correctly.
'72 GMC Super Custom 1500 350 V8 w/AC
utee05 is offline   Reply With Quote
Old 08-27-2012, 12:27 PM   #29
utee05
Well finally got everything fixed. Turns out my bulb connectors were bad. I noticed this when I started to wiggle the bulbs a bit and they turned on. I replaced those and now I have nice bright H4 low beam headlights. Don't think I'll really need the high beams since my low beams are bright by themselves.
Thanks all for the help.
headlight relay, headlight relay harness, headlights, relay
