Old 08-08-2012, 06:54 PM   #26
Bomp
Bomp's Avatar
Re: Donz '65 SWB Stepper Budget Build...
Fast,,,,Fast,,,,,,,,Down right BLAZIN FAST. Watching the build and getting motivated.
subscribed
Bomp is offline   Reply With Quote
Old 08-08-2012, 10:12 PM   #27
Ta2Don
Ta2Don's Avatar
Thanks for the comments, very encouraging... enlisting some help from a friend soon to help with some bodywork. He's re-shooting his 70 Nova this weekend, I'll be installing 2" Lowering blocks in the rear and grabbing A/C parts from a '97 donor truck.
Ta2Don is offline   Reply With Quote
Old 08-13-2012, 09:41 PM   #28
Ta2Don
Ta2Don's Avatar
Thanks Coulter, getting the motor buttoned up, got the oil pump installed and the oil pan painted and bolted on... had original manifold bolts, so when I tried to bolt up Edelbrock performer intake, couldn't get torque wrench on right side center bolts due to clearance issues, off to O'Riely's in the morning to get correct bolts.
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Old 08-13-2012, 09:49 PM   #29
Ta2Don
Ta2Don's Avatar
Installed the rear lowering blocks, here's the blocks installed and a pic of the stance before mocking up with bed and front sheet metal. Gotta get on the body work...
DON
Proverbs 27:17
Old 08-21-2012, 09:14 AM   #30
Ta2Don
Ta2Don's Avatar
Been focusing on some of the small stuff recently, got my adjustable track bar in, painted it and installed... ordered my peep mirrors... waiting on an exhaust manifold... still need to start some body work... been thinking about and researching wiring harness...
will post pics soon...
DON
Proverbs 27:17
Old 08-21-2012, 10:55 AM   #31
chad64chevy
chad64chevy's Avatar
looking good, keep it up! that motor is going to really stand out with that blue firewall!!
chad64chevy is offline   Reply With Quote
Old 08-21-2012, 10:23 PM   #32
Bomp
Bomp's Avatar
Can't wait for the pics.
Trying to devote an hour a day to getting out to the shop.
Old 08-26-2012, 09:52 PM   #33
Ta2Don
Ta2Don's Avatar
Got the Ram Horns blasted and painted today...
DON
Proverbs 27:17
Old 08-27-2012, 06:51 PM   #34
Ta2Don
Ta2Don's Avatar
Bolted on the ram horns and mocked up the carb and thermostat housing...
DON
Proverbs 27:17
Old 09-09-2012, 10:44 PM   #35
Ta2Don
Ta2Don's Avatar
Started painting the old beat-up aluminum wheels...
DON
Proverbs 27:17
Old 09-23-2012, 04:07 PM   #36
Ta2Don
Ta2Don's Avatar
Didn't get alot done,worked on cleaning and painting sway bar for frontend and adjusting the brake lines to work with the dropped spindles... Here's a pic of Kate hanging out while I play around with the '65
DON
Proverbs 27:17
Old 09-24-2012, 03:18 PM   #37
Ta2Don
Ta2Don's Avatar
Got the front sway bar installed... little by little...
DON
Proverbs 27:17
Old 09-24-2012, 06:46 PM   #38
Ta2Don
Ta2Don's Avatar
This is as High-Tech as I plan on getting with this project...
The 65 Plate that came with the truck the day it arrived...
DON
Proverbs 27:17
Old 10-15-2012, 10:35 PM   #39
Ta2Don
Ta2Don's Avatar
Pulled the Vent Windows and Window glass, ordered new seals and rivets. Getting ready to tackle Vent window rebuilds. Alan's write-up in the FAQ section is awesome. Thanks to all who document their experiences, gives me the motivation to venture into areas into which I have no prior experience.
DON
Proverbs 27:17
Old 10-16-2012, 10:18 PM   #40
Ta2Don
Ta2Don's Avatar
Received my Booster bracket from Captainfab, Thank You Sir! Mounted it, Painted the booster and prop valve bracket, extended the booster pushrod (using the original pushrod as the donor) then mounted the booster and master cylinder. Time to plumb the brake lines...
DON
Proverbs 27:17
Old 10-16-2012, 10:36 PM   #41
Bomp
Bomp's Avatar
That is Clean. I like it.
Old 10-16-2012, 10:39 PM   #42
McMurphy
McMurphy's Avatar
I just did all my brake lines too.
I bought a tube bender tool, but really all I needed was the little disk with the different sized grooves for the tubing and my vice.
All in all it was like a puzzle and actually kind of relaxing !!
Have fun with yours, your build is coming along very nicely !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 10-16-2012, 11:03 PM   #43
CRGRS 66
CRGRS 66's Avatar
looks really good, I really like that blue btw
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-16-2012, 11:09 PM   #44
Ta2Don
Ta2Don's Avatar
Thanks Guys... Staying motivated by cruising the threads out here.
DON
Proverbs 27:17
Old 10-21-2012, 09:29 AM   #45
Ta2Don
Ta2Don's Avatar
Thanks Rick (Icewater Carter) for the clutch pedal. Thank You TR65 for the awesome write up on adding a Clutch Master Cylinder to our trucks.
Thank You Leadfoot Lambert for Posting pics of your NV3500 installed.
Like many of us, when looking for a way to squeeze out a few more mpg my plan is to run a NV3500 5 Speed. The 3:73 gears in the back will not have to work so hard with the extra gears.
DON
Proverbs 27:17
Old 10-21-2012, 08:20 PM   #46
Ta2Don
Ta2Don's Avatar
Cleaned and painted the Clutch Pedal from Rick... pulled the brake pedal and E Brake Handle, Cleaned and painted those as well, all with the help of Alex, my 4 yr old Grandson... Starting him out right.
DON
Proverbs 27:17
Old 10-21-2012, 08:38 PM   #47
markeb01
Senior Enthusiast
markeb01's Avatar
Coming along nicely. I sure like the looks of that engine!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-21-2012, 09:06 PM   #48
Ta2Don
Ta2Don's Avatar
Thanks Mark!
DON
Proverbs 27:17
Old 10-22-2012, 10:56 AM   #49
CRGRS 66
CRGRS 66's Avatar
You have made GREAT progress in a short period of time, I enjoy and appreciate all of the updates, helps me a lot!
Craigerrr
Old 10-22-2012, 01:45 PM   #50
Ta2Don
Ta2Don's Avatar
Thanks Craigerr... I sure enjoy the encouragement. Your truck is sweet, hope to have mine roadworthy in the spring...
DON
Proverbs 27:17
65 swb, c10, step side, tattoo
