Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-14-2013, 10:25 PM   #26
SunSoaked
SunSoaked's Avatar
Re: 1969 k10 lwb to swb, 1 tons, 6.0/4l80e/np205
I like the dog. Nice to have a friend to work with who agrees with everything you do..lol
SunSoaked is offline   Reply With Quote
Old 02-15-2013, 10:23 AM   #27
wade_ab
wade_ab's Avatar
Originally Posted by yfs200p View Post
Sweet looking truck man! Is that tailgate in the background off this truck? I think that looks pretty cool using the 90's style 'CHEVROLET' panel on the old style gate. Sweet progress and keep the pics coming!
Yeah its actually a GMC tailgate lol. The PO told me that the bed and tailgate were from a GMC that he found in better shape. I might clean up the gmc one and sell it so i can get the correct chevrolet one for that moderl or just keep it the way it is.
69 k10 - In pieces
wade_ab is offline   Reply With Quote
Old 02-15-2013, 10:44 AM   #28
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Very nice work. Wish I was close to ya, I would take that 4-speed off your hands.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 02-15-2013, 10:45 AM   #29
wade_ab
wade_ab's Avatar
Ill happily sell it to you for cheap.
69 k10 - In pieces
Old 02-19-2013, 02:05 PM   #30
wade_ab
wade_ab's Avatar
I undercoated my bed this weekend with some Chassis Saver, Ive never used it befor this. I liked it alot. It went on easy and it seems to be just like the master series produts I used on my chassis. This stuff was a little cheaper and they had it in stock at the auto paint store locally. All I did was hit the underneath of the bed with the wire wheel on the grinder and then painted this on with a brush. It leveled out nicely.
69 k10 - In pieces
Old 02-19-2013, 02:07 PM   #31
wade_ab
wade_ab's Avatar
This was the stuff I used.
69 k10 - In pieces
Old 02-19-2013, 02:30 PM   #32
Bishops Trucks
KEEP ON TRUCKIN'
How cheap is cheap?
JIM
Old 02-19-2013, 02:48 PM   #33
wade_ab
wade_ab's Avatar
How cheap is cheap?
Sent PM
69 k10 - In pieces
Old 02-21-2013, 06:19 PM   #34
Zane M
Great truck!
I can't believe how clean that truck is rust wise. We salt the roads heavily here in Utah. I'm guessing it wasn't the PO's daily driver.
Zane M is offline   Reply With Quote
Old 02-23-2013, 02:08 AM   #35
Spicer
Junior Member
Spicer's Avatar
Nice choice of drive train! Great work on the frame and bed! Wish I had a dollar for every unfinished cut frame and body I’ve seen over the years! Great effort!
Also Nice shop... mine is a catch all!
1991 V3500 clone
572GM/400/205
Spicer is offline   Reply With Quote
Old 02-25-2013, 12:02 PM   #36
wade_ab
wade_ab's Avatar
Originally Posted by Zane M View Post
Great truck!
I didnt even think about the salt. I just figured it had less rust because yall had a drier climate, or at least drier than south east texas, we breath water lol.
69 k10 - In pieces
Old 02-25-2013, 12:04 PM   #37
wade_ab
wade_ab's Avatar
Thanks Spicer, mine is becoming more and more of a catch all too
69 k10 - In pieces
Old 02-25-2013, 12:09 PM   #38
wade_ab
wade_ab's Avatar
I did a little sandblasting and painting on the front Dana 60 this weekend. I was going to start putting the carrier and all the internals back in but realized a few things I was missing to do the job correctly. I have a couple questions if anyone has done a carrier swap.
I used POR 15 this time and coated it with the POR 15 chassis top coat. I figured i'd try it out too and see how it compared to the others. I liked it ok. I really like how hard that chassis saver I put under the bed was tho.
69 k10 - In pieces
Old 02-25-2013, 03:42 PM   #39
Spicer
Junior Member
Spicer's Avatar
I do them quite often, mostly from 4.10 carrier and down, to the 4.56 and up carrier...
What ratio are running? Locker? Any up grades while your in there?
This had 3.73's in it from the factory, it has 5.13's and an OX locker in now...
1991 V3500 clone
572GM/400/205
Old 02-25-2013, 03:52 PM   #40
wade_ab
wade_ab's Avatar
WOW thats a lot of beef! Sweet diff cover and axle stands, thats legit.
Im running 4.56s open carrier. When I bought the D60 it had the stock carrier completely welded up so I bought a used open carrier off ebay and thought id just swap it out. Ive since then done a lot of research and found out its not quite as simple as I thought.
Correct me if im wrong, I am going to have to pull the pinion and all the pinion shims and reestablish all the shim depths with the new open carrier along with all my backlash settings?
Initially I thought I could just pull carrier, replace it, and set the backlash but the more I've read, it seems that Ill have to pull pinion and reset everything in order to get a correct pattern between the pinion and the ring gear?
69 k10 - In pieces
Old 02-25-2013, 03:57 PM   #41
Spicer
Junior Member
Spicer's Avatar
Well you should be able to start with the pinion depth you have now, and just set the new Carrier up with the same ring, but at times when you cant get the right pattern then you go from there, I would say the factory pinion depth is the closest your going to get with out setting up the carrier, when I set up used gears and I have the old shims, I use them as a starting point, so you are already half way there, and like you said carrier bearing backlash and so on, the main thing is to make sure you have the right series carrier, you can see the difference when you put them side by side with out the carrier bearings installed.
If you know or have checked then you are good to go…
1991 V3500 clone
572GM/400/205
Old 02-25-2013, 04:05 PM   #42
wade_ab
wade_ab's Avatar
Also should I buy a master rebuild kit or just source out the parts I need?
69 k10 - In pieces
Old 02-25-2013, 04:26 PM   #43
Spicer
Junior Member
Spicer's Avatar
I would say if the bearings (carrier) are good, I would swap the shims on the carrier as well, and do a test installing the carrier to see where you are, check the pattern and go from there, If you are replacing a factory open carrier to another factory open carrier you will be surprised how close they will be, and if then you need to move the carrier back or closer buy a Mini shim kit it will have (should) a seal, pinion & carrier shims with making compound. When the axle housing is out I use the spreader on the Dana models, but looks as though you already have the gears out so you have a good bead on how to do it.
1991 V3500 clone
572GM/400/205
Old 02-25-2013, 04:32 PM   #44
wade_ab
wade_ab's Avatar
The new carrier did not come with bearings attached, but my original ones look good, should I get a new set anyway and use the original as set up bearings? I think I read that this was suggested because taking the carrier in and out and pulling bearings and adjusting shims multiple times can damage a set of bearings real quick.
69 k10 - In pieces
Old 02-25-2013, 04:45 PM   #45
Spicer
Junior Member
Spicer's Avatar
It’s always best to install as many things as you can New while your in there so yes that’s a great way to do it, I have a set of bearing slugs that are the same size as the bearing with races and also a nice bearing remover, and it makes what your doing very easy, once you have this kind of stuff it’s hard to remember how I ever did it without them, so yes your on the right track… They also sell set up bearings, and they save a bunch of time and money as well, the last set I bought was many years ago and back then they were around 40.00 for the set, no races, good investment even if you only use them once.
1991 V3500 clone
572GM/400/205
Old 02-25-2013, 04:51 PM   #46
wade_ab
wade_ab's Avatar
Ok good to know, Ill look for a pair of set up bearings.
So if you were me, you would go ahead and put the carrier and everything back in before messing with the pinion depth?
Maybe ill get lucky and not have to jack with the pinion depth and all the little things that go along with that.
69 k10 - In pieces
Old 02-25-2013, 05:14 PM   #47
Spicer
Junior Member
Spicer's Avatar
About the only thing you can do at this point different, is reset the pinion depth to the center point, and start over, when I do the exact same thing I go with the factory set up until it proves to be wrong, and considering all the pinion bearings and races are in good shape and so on. If you have a or have access to one you can check the pinion depth with a pinion depth gage, the pinion should have a + or – number on the head of it that will give the number that the factory recommends to start at when setting up the pinion, but IMO it’s just extra steps (if) the ring and pinion had no issues before you pulled them out… Yes I would do a test and go from there...
1991 V3500 clone
572GM/400/205
Old 02-25-2013, 05:17 PM   #48
wade_ab
wade_ab's Avatar
Ok good deal, thanks for letting me pick your brain. What part of Texas are you located in? If I cant get this thing figured out I might have to pay you a visit lol
69 k10 - In pieces
Old 02-25-2013, 07:39 PM   #49
Spicer
Junior Member
Spicer's Avatar
Anytime, with your carrier swap, you are very close IMO, and you have the confidence that’s needed to do what you are doing. I’m north of you about 150 miles, in the Tyler area. What Lockouts are you going to run?
Please feel free to stop by and visit anytime! When you get the 4L80E in there, you should have decent fuel mileage…
1991 V3500 clone
572GM/400/205
Old 03-27-2013, 09:54 AM   #50
wade_ab
wade_ab's Avatar
I got the Dana all put back together. It wasnt as bad as I thought it was going to be. It took some time and patience but I finally got the backlash into spec and ran a pattern. Its probable not perfect but it seems acceptable. I think the pinion could be moved out a hair but im happy with it.
69 k10 - In pieces
