Old 12-23-2012, 04:09 PM   #26
cortcomp
cortcomp's Avatar
Re: '66 Longbed 327 w/AC project
I've got everything out of the inside of the truck, except the steering wheel which i haven't figured out how to get out (can't get horn button off) but i didn't really put a lot of effort into it.
Anyway. dash is all but bare, front and rear windows out of the way, welded a few screw holes in the inner roof panel shut and filled them. Have been rehabbing interior parts and am about done with that, so real work is about to begin.
Now to sand the inside with 300ish grit, primer, and paint it the same color gray. Then those tar heat mats, the foil backed adhesive mats, then the jut mat then vinyl floormat. Doing the foil inside doors too, and up to the top of the gas tank, behind it.
Have new radio and modern drop in speaker. Figured out trailer brake controller wiring, and dash is ready to re-install after everything else is in. Really only wiring i need to track down is wire to heater motor, wire to A/C inside from compressor, and amp meter wiring
(i don't think it's hooked up, i think i can find it disconnected under the hood at the horn relay because it's all bypassed for the alternator. Even if it's not an accurate sense of charging, i'd like to have it register. Probably just change those endpoint connections to get a reading at like battery and starter solenoid signal wire or something that will show needle movement when cranking.).
Here's some pics of restoring the air vents, and some of the dash components. I've been sanding with 320 grit, washing, primering with rustoleum auto primer (gray, 2 coats) and painting with rustoleum gloss (grey, 2 coats). Black is kimball midwest gloss black heavy solids pro-line. I will be doing the engine bay with it, because it sticks to everything and lays well.
NP440 is at the tranny shop to be gone through, then i will put it in just to make sure where shifter hole lines up on floor, or if i have to do some quick metal work before doing the floor finishing. Then motor and tranny out to clean and detail the engine bay, and do all new gaskets on the 327. After that, i think i will finish up with lowering it like 3-4" back and 1-2" front, and converting to the newer power steering box with a fast ratio.
cortcomp is offline   Reply With Quote
Old 12-23-2012, 04:10 PM   #27
cortcomp
cortcomp's Avatar
Glovebox. Waiting on bumpers and tube nuts to arrive to have it done. Blasted it in the cabinet and same primer/paint as above.
Old 12-23-2012, 05:12 PM   #28
McMurphy
McMurphy's Avatar
Horn button should pull straight out. It should have a rubber gasket/grommet holding it in there. If it is more than resistant to pull out, you can squirt some form of liquid in there, even if it is just water, and that should help it to slide out.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 12-23-2012, 05:34 PM   #29
Ta2Don
Ta2Don's Avatar
Ditto on Horn Button removal, newly painted parts looking sweet...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 12-23-2012, 11:33 PM   #30
cortcomp
cortcomp's Avatar
thanks for info, i'll give it a try tomorrow. want to yank it to try one of those restoration wheel kits on it, and have it out of the way to paint interior.
Old 12-24-2012, 05:34 PM   #31
cortcomp
cortcomp's Avatar
Horn and steering wheel removed, and rest of rubber and vent windows, time to clean and start sanding, so i can mask and prime inside! can't wait to start putting back together.
Side note: easiest window trim and vent window removal ever. Were the door lock knobs optional? i see them in vendor websites, but i don't have the holes for them on my doors, you lock by pulling handle up (or pushing down or something, i forget...)
Old 12-24-2012, 09:01 PM   #32
64longbed
Nice!!!
64longbed is offline   Reply With Quote
Old 12-24-2012, 09:14 PM   #33
ol_skool_chevy
ol_skool_chevy's Avatar
I would be more concern with weight.........6.073 per gal..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-25-2012, 12:05 AM   #34
cortcomp
cortcomp's Avatar
300 lbs of fuel would be like riding around with a big passenger, or a couple of transmissions in the bed.
Old 12-25-2012, 12:13 AM   #35
cortcomp
cortcomp's Avatar
Also, love that green and white combo ol_skool, nice truck!
Old 12-28-2012, 07:24 PM   #36
cortcomp
cortcomp's Avatar
Been working on painting the last of the interior components, and finished filling and sanding the screw holes someone had in the back of the cab. Decided to pull the roof skin after reading about it here, and pack it full of the insulation i got rolls of (cheaper dynamat style stuff) There is some surface rust, and the start of something worse at the gutter/front windshield panel seams, so i'll clean that up, clean up the inside of the roof panels, port 15 them, insulate, change the dome light fixture, and insulate the C panels behind the inner panel that i couldn't get to before. Put the top back on, weld it, fill it, and prep the white part of the cab for paint. With all the rubber out, it's just to good an opportunity to clean it all, replace all the cracking seam sealer, fill some holes properly by welding and filling, and then paint, then put new rubber back in.
Old 12-28-2012, 09:01 PM   #37
88Lt1wagon
Looking good, the grey and black is slick
-Jason
'66 C10 LWB 2 BBL 283 w/ T-5
'90 V1500 Suburban TBI 350 w/ 700R4
88Lt1wagon is offline   Reply With Quote
Old 12-29-2012, 12:34 PM   #38
cortcomp
cortcomp's Avatar
Thanks! I wasn't 100% sure on the colors at first, but it's really growing on me the more i paint! I can't wait to get the interior done and back together and see how it looks!
Old 12-29-2012, 05:36 PM   #39
cortcomp
cortcomp's Avatar
It has just hit me that, with the roof off, i'm looking right at the correct and easy way to swap that inner panel to convert to a BBW. have a couple leads for just a panel, and i'm on the hunt! I saw the kit that you do welding and everything from inside the cab, but drilling the spotwelds would be easier for me, no one would see them as the rubber and roof hide it all, and i have all the rubber out! I was on the fence converting it, but i have so many options on this truck (OD 4 spd, tach, vacuum gauge, AC, trailer brake controller, glove box light) that it seems a shame not to have the most desirable option (BBW). I know i have a long bed, and a lot of guys prefer the short, but i love the long on this body style. We'll see how those leads come through.
Old 12-30-2012, 03:21 PM   #40
duallyjams
duallyjams's Avatar
Hope you find a BBW panel.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-30-2012, 03:26 PM   #41
cortcomp
cortcomp's Avatar
Thanks! I've been looking. I have one lead (if the guy doesn't sell it today, or if the guy who buys his pile of parts will sell it.) After i find one and switch it out, i'll finish por-15 the inside of both the inner roof panels and the outer roof panel. Put insulation in, and button up.
I've been fixing random holes people put in the doors to mount things, and found one door beat pretty bad. I may just get a new shell, it has 8 lbs of bondo on it. Passenger door seems good. I was going to just repaint the white on the outside of the truck, but i may just move the bed back, and do red also. I'm glad i'm taking care of all this rotten seam sealer in the doors and around windshield, etc, because it looks like it was and would have let some water in. Things should be very quiet after all the insulation and new rubber, and this should set the clock back on this truck a long time. It's clean now, but it was a couple years from the sad sight of paint bubbling in seams and places.
I'm out of space with parts EVERYWHERE, so opposite of common procedure, i'll probably finish the interior first, then mask and paint the outside. Will give me room to work with, and completion of the interior will give me further motivation.
Old 12-30-2012, 10:10 PM   #42
cortcomp
cortcomp's Avatar
Got the inner roof/rear window panel out, welded and first coat of filler on the two vertical seams where the upper windshield panel meets the front a pillars. Fixed 2 holes in the passenger door where someone had something mounted (welded and then filled and sanded) and a hole in the upper roof where there was a cb antenna (welded, filler, sanded)
Old 12-30-2012, 11:46 PM   #43
Bomp
Bomp's Avatar
Will you be able to post some pics of the bbw conversion?
Sounds like you are really tearing into this thing.
I took the roof shin off of my cab and used por15(awesome stuff). I have a lead on a small window cab and would like to convert it over if I get it.
Great Build
Bomp is offline   Reply With Quote
Old 12-31-2012, 11:11 AM   #44
cortcomp
cortcomp's Avatar
Sure, i'll grab some later. Once you take the roof skin off it's plain as day. Remove spotwelds on that edge, do both door jamb seams (seam is under weatherstripping), then do bottom seam behind gas tank (there's like 3-5 welds per vertical "bump" on the back wall).
Only thing holding it in at that point is the welds around the window. rather than mess with spotweld cutter there, i just used a side cut off tool to cut the welded together seam there out (since you'll be cutting more than that on the outer skin for the BBW anyways) and the panel came right out. I can see why guys do the kits or mess with the upper seam with glue on trucks that are more complete or already finished. But, it took me about an hour -hour and a half to get the roof skin off, same to remove that panel. Plus, you're able to redo those gutter seam panels, i'm glad i did because they were starting to rust. Plus, with the roof off and that panel out, you can insulate the entire roof, and the entire back wall easily. What a difference that should make on noise, and retaining A/C temp, vs doing just the floor!
Old 01-01-2013, 03:24 PM   #45
cortcomp
cortcomp's Avatar
Here are some pics of the panel removed (bondo is skim coat over the screw holes i filled.) also, close up of the first coat on the upper windshield seams i welded and filled. Sanded, needs another coat and sanding again. because of the inner roof brace, that area isn't a smooth corner anyways from the factory, kind of a bump there.
In the windshield under the rubber area of those seams, i will use seam sealer as per the factory.
Sorry some pics are blurry.
Old 01-01-2013, 03:25 PM   #46
cortcomp
cortcomp's Avatar
last pic
Old 01-01-2013, 05:03 PM   #47
padresag
you must have gotten lucky on the fuel senders as 66 is usually 90ohms whils the earlier one are 30ohms
ron
padresag is offline   Reply With Quote
Old 01-01-2013, 05:24 PM   #48
cortcomp
cortcomp's Avatar
I checked my in cab one before ordering as i saw them both ways stock. I've read some guys seeing only 30ohms in the 66's they've come across, while others swear they've only seen 90ohms. They weren't too pricey that i couldn't have switched if i was wrong, but hate to throw good money away. I do notice that i set them up so that empty is really empty and full is really full. On the stock, empty means like 3-4 gallons left or something, because it doesn't reach the bottom of the tank.
Old 01-01-2013, 06:04 PM   #49
McMurphy
McMurphy's Avatar
I would rather have mine set up like that too, the false assurance of "It is on E but I am Ok..." does not sit well with me.
In the 80s I had a 1963 Crysler 300 and when that bad boy said E, it meant it!
I literally ran out of gas 200 feet from the gas station. Because of that car I will never own a MOPAR again, and now 1/4 tank means gas up NOW !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 01-01-2013, 06:31 PM   #50
cortcomp
cortcomp's Avatar
what sucks on these trucks (well, mine because the carb leaks so bad, and so did the pump, lines, etc) i was getting 12mpg highway on the way home. That 3-4 gallons, out west, meant stop now, or we can go another 45 min before gassing up. Around home, it means i can skip gassing up tonight and do it next time, or not. Having the extra tanks gives me all that back, but if i didn't have them, i'd feel like i was gassing up all the time because it'd be like a 7 gallon tank from full to E. Hoping fixing the carb (last leak) and tune ups will get me to 15 mpg, and that overdrive will get me to 17-20. (driving easily of course, and not over 70-75 with OD, 60-65 w/o, seems to be the thriftiest ranges)
