11-29-2012, 01:27 AM | #26 |
Re: HEI wire
I would not cut anything and just cap off the wires not used/needed and run a wire from the fuse block for the HEI,,ya never know when you might need the wire you cut off??
11-29-2012, 01:42 AM | #27 |
1970 Daily Driver
Re: HEI wire
I am not cutting off any wires. I am replacing (Re-pinning) a wire that is outdated for my HEI with and updated correct wire for my application. I dont belive that this risistor wire will come in handy for any thing in the future as I will never go back to points just like I will never go back to drum brakes or an in-cab gas tank. I would rather have an extra ign unfused terminal available and no additional wires going through the fire wall.
If you plan on doing a stock restoration I agree with you but I dont plan on going that route.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
11-29-2012, 11:22 PM | #28 |
1970 Daily Driver
Re: HEI wire
I got both connectors and the pink 12 gauge wire from napa. I borrowed the special crimper from a mechanic friend. I soldered the connections as well. Now to put it all back together again.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 11-29-2012 at 11:38 PM. |
10-13-2015, 09:06 PM | #29 |
Re: HEI wire
I had this same issue a few months ago, the engine side of the fuse block looked like nuclear meltdown.
Sam 1970 GMC Long Bed/ Small Block 350 |
