#26 |
Re: 71 C10 project "Double Tap"
The chasis will be painted GM victory red and that's just the tip of the iceberg.
Posted via Mobile Device |
#27 | |
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold *** First Ride <> '81 C10 Long Fleet *** Current Project *** ![]() |
#28 |
67cheby
![]() Join Date: Sep 2008
Nice work !
#29 | |
#30 | |
#31 |
It really needs to be done by next Friday, hint hint doomsday
![]() Posted via Mobile Device |
#32 |
Got the front frame horns dropped with a new tube crossmember and got rid of the factory one for radiator hose clearence. The core mounts cleared the gear box by the skin of my teeth. I ran into the issue of the bumper side braces so I had to do a step to keep it in line without messing with the gear box mounts but yet pulling the core support mounts back an inch to account for the lengthened wheelbase. So long story short everything fits, and measurements are back in line. More pics will follow soon, just had to tell everyone about my day.
#33 |
Who knew Arkansas was a Mecca for 67-72 trucks. Looking good. Even if its not a long bed anymore.
#34 |
Looking good! You made the Longbed/shortbed conversion look too easy!
#35 | |
#36 | |
#37 |
Reangled the upper arms to fix ball joint angles and did a notch for my steering shaft. Also cut out the last of the factory crossmembers so their all tube now. Picture update this evening after work.
#38 |
My home made step notches. Had to try my own set.
#39 |
The parallel bars are one piece with the large nut slid over for looks and adjustability since I used right and left hand thread hiems to shorten and lengthen the bars with a simple turn. I cad programmed all the brackets and had them cut out by a local business. The bags were originally going to be inside the frame but the space and body roll were issues so I went outside the frame.
#40 |
The rearend is nearly complete with the front not far behind but I may be getting a little carried away as the front laid flat the rear was less then a half inch off the pavement so I decided to save time and ordered new notches to lay out hard. So as soon as they show up then I can get after it again. Hope everyone likes it so far.
#41 |
Should have more metal by the end of the week. Was looking at the POR 15 products and then top coating it with their hardnose colors. Anyone have any experience with this stuff?
#42 |
Heres the last of the pictures until this weekend. Lots of updates for this weekend.
#43 |
looking good.. now i have to wait for you to post more pics..
post them all already... why do this to us..
my rhd build.. http://67-72chevytrucks.com/vboard/s...d.php?t=468712 1964 CHEVROLET BISCAYNE 350CI/TH-350 1968 CHEVROLET C-10 SWB LS1/4L60E |
#44 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Nice freakin work man, great job so far.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#45 |
Pictures will come soon. Just been busy this weekend so I didn't get as much done as I wanted.
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
#46 |
Notched upper arm to clear stearing shaft, you can also see I pie cut them to fix the ball joint angle. Removed factory core support crossmember for cleaner tube one. This will allow me the necessary space for my radiator hoses. Because I moved the wheel base forward an inch I had to bring the core support body mounts back that much and down 3". So I dropped them 3" and sectioned out the 1" just barely clearing my gear box.
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 Last edited by builtbyKane; 12-29-2012 at 07:18 PM. |
#47 |
Started plating the inside of the frame to tie in the carrier bearing xmember. I've just about got the panhard bar dialed in. And finally got the bag brackets built after I installed the new taller notches.
#48 |
more pics.
#49 |
I've just about got my rear disk brake conversion complete just have to cut out my templates. I could have done a quick weld on bracket but I didn't see the challenge of welding on a caliper bracket so I made a 2 piece bolt on bracket. Stay subscribed because this build is about to pick up speed.
#50 |
Thanks to the resources from this great forum I was able to pick up the caprice rotors and caddi calipers from my local parts store that worked out great.
