Old 02-09-2013, 01:39 PM   #26
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
Re: Project orange 468 bigblock 1970 gmc to 1972 chevy
another pic of the passengers side door, rust repaired and speaker hole fixed.
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
Old 02-09-2013, 01:41 PM   #27
468BIGBLOCK
getting ready to pull the bed and cab.
Old 02-13-2013, 03:39 PM   #28
468BIGBLOCK
I got the cab pulled of of it now.
Old 02-13-2013, 03:40 PM   #29
468BIGBLOCK
the clear was peeling on the roof, i am stripping the clear off here and getting ready to prime it.
Old 02-13-2013, 03:44 PM   #30
82chevylsx
82chevylsx's Avatar
nice work bro.......
82chevylsx is offline   Reply With Quote
Old 02-13-2013, 03:57 PM   #31
468BIGBLOCK
welding up a small crack on the drivers side cab post.
Old 02-13-2013, 04:00 PM   #32
468BIGBLOCK
got the bed off and i have to fill a few holes on the top where it had rails screwed on it.
Old 02-13-2013, 04:02 PM   #33
468BIGBLOCK
the firewall is ready for the last primer coat before the paint.
Old 02-13-2013, 04:04 PM   #34
468BIGBLOCK
and a pic of the frame.
Old 02-13-2013, 06:27 PM   #35
trent_44
trent_44's Avatar
Looking good, making quick work of it.
trent_44 is offline   Reply With Quote
Old 02-13-2013, 06:30 PM   #36
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
this build should have been called Speedy Gonzales!
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 02-14-2013, 02:33 PM   #37
468BIGBLOCK
Talking Re: Project orange 468 bigblock 1970 gmc to 1972 chevy
I have had it for 4 years it is time to work now. i work on it almost every night and every saturday.
Old 02-14-2013, 02:36 PM   #38
468BIGBLOCK
I have been working really hard on this one trying to get some work done before this summer it will be to hot to work on it.
Old 02-14-2013, 02:39 PM   #39
468BIGBLOCK
this is a before pic. the clear peely in spots, and needing some work.
Old 02-17-2013, 06:05 PM   #40
468BIGBLOCK
final coat of primer then i used rock guard on the top of the firewall and down low. it looks alot like the factory sound deadener down low.
Old 02-17-2013, 06:07 PM   #41
468BIGBLOCK
now then time to use non sanding sealer and ready for base coat.
Old 02-17-2013, 06:10 PM   #42
468BIGBLOCK
now 3 coats of 514 orange red base coat.and 3 coats of clear.
Old 02-17-2013, 09:10 PM   #43
cable666guy
cable666guy's Avatar
Nice work...and I really like that shop...roomy!!
cable666guy is offline   Reply With Quote
Old 02-23-2013, 12:42 PM   #44
468BIGBLOCK
[QUOTE=cable666guy;5895223]Nice work...and I really like that shop...roomy!![/QUO it helps to have room when you pull the body off.
Old 02-23-2013, 12:58 PM   #45
468BIGBLOCK
welding in the cpp rear frame notch.
Old 02-25-2013, 04:26 PM   #46
468BIGBLOCK
the roof has been stripped of the peeling clear and in the prime now.
Old 03-10-2013, 03:15 PM   #47
468BIGBLOCK
i put on some body filler on the frame notch.
Old 03-10-2013, 03:19 PM   #48
468BIGBLOCK
and i used a some driveshaft tubing from a 1995 model international 4900 series bob truck for a exhaust pass thru the crossmember. it is 4 inches in diameter.
Old 03-10-2013, 03:20 PM   #49
468BIGBLOCK
and some 2k primer for the frame.
Old 03-10-2013, 06:42 PM   #50
trashmanryan
trashmanryan is offline   Reply With Quote
1970 gmc, 468 bigblock, project.
