Old 03-08-2013, 08:39 AM   #26
WadmalawJoe
WadmalawJoe's Avatar
Re: HEI distributor tuning problem
Originally Posted by Longhorn 70 View Post
This is weird....Usually detonation INCREASES with increased engine temp. Yours seems to be going against that.
Most people install colder heat range plugs in mildly built engines is to alleviate detonation caused by increased head temperatures. I have colder plugs in the Olds engine in my truck and that has helped me get rid of ping.
I have a Skip White 6503 on the Olds. I haven't had pinging problems with it either. That distributor has performed well for me.
Could you be running too lean while cold and when it warms up all is good? Like the heat riser isn't there/working or the choke pulls off too soon?
Please post the solution to the issue when you find it.....I gotta know.
Maybe it is to lean when its cold, but my choke is a manual and I probably tend to leave it on longer than I need to, just to help warm up the motor. In the morning especially, I let it run a few minutes before heading out.
[QUOTE=cdowns;5933044]big difference in quality from something like a shippy chinese and a real quality unit like msd pertronix
I hear ya, I was extremely hesitant about buying it, I asked around on here and no one had a problem with theirs. Maybe, I should swap it out for another just to see if its a bad distributor. I will have to say I was surprised at the actual quality of it. Looking it over carefully, it looks pretty good, metal and plastic parts are all pretty solid, not super thin or cheap feeling.
After bouncing PM's back and forth with CB1987, I'm leaning towards a vacuum issue. I need to research my carb and make sure I'm on the right port or maybe switch to a port on the intake manifold or something.
It's been a busy week and I haven't had time to mess with it unfortunately. I drove it almost everyday for two weeks with it making the noise so I'm scared I might have damaged something or that it is damaging it. So I parked it for a few days until I can mess with it more.
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 03-08-2013, 08:48 PM   #27
WadmalawJoe
Well, I finally had a chance to read up on my carb, the edelbrock 1405, I have 3 ports on the front; a ported vacuum, pcv port and full time vacuum port. Well its plugged into the full time vacuum, that's got to be it. It's supposed to be on the ported vacuum. I should have time to try it out tomorrow, so I will let you all know what happens.
Toys/projects
Old 03-08-2013, 09:21 PM   #28
LONGHAIR
Here we go again with carburetor instructions telling us how to time our engines. Holley instructions do this too, or at least used to.
You can only plug it into the place where the distributor is calibrated to work.
While I am firmly against running ported vacuum, if that's the way the distributor is set up, that's the easiest way.
It's not the best way though, it leaves performance and fuel economy on the table. Setting up your distributor to work with full vacuum will gain you the most.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-08-2013, 10:13 PM   #29
WadmalawJoe
The distributor instructions said to use a ported vacuum.
Could you explain why your firmly against using a ported vacuum?
Toys/projects
Old 03-10-2013, 06:06 PM   #30
WadmalawJoe
Alright I'm ready to give up.
I put a new GM hei dist in and I still have the problem. So its something I'm doing.
With the advance unplugged and port capped I have that intial timing set at 12 degrees ahead. When I plug in the advance it jumps to 30 ahead. So a 18 degree jump.
I have adjusted the advance can all the way in and I'm still getting the detonation sound at 50-55 MPH.
I switched to a ported vacuum and it pings like heck so its back on full vacuum.
I haven't gotten a dial back timing light yet, frankly I can barely use a regular timing light it seems. I do have a timing tape on the balancer.
What am I doing wrong and/or what do I need to do?
Toys/projects
Old 03-10-2013, 10:39 PM   #31
WadmalawJoe
ttt
Toys/projects
Old 03-11-2013, 12:17 AM   #32
tim21391
tim21391's Avatar
did you use the power wire off the other original coil? you should be running it off the fuse panel if you have not i know i had that issue when i converted mine
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-11-2013, 06:24 AM   #33
WadmalawJoe
nope, ran new wire, 12v feed.
Toys/projects
Old 03-11-2013, 09:12 PM   #34
WadmalawJoe
ttt
Toys/projects
Old 03-11-2013, 09:28 PM   #35
LONGHAIR
Yes, but be forewarned, it's heavy reading.
Here's an interesting article on vacuum advance written by a GM engineer:
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
Old 03-11-2013, 09:33 PM   #36
LONGHAIR
Saying "new GM HEI" distributor means nothing. There are many different models, all with different calibrations. The advance comes in at different RPM and at different rates. You really need to know what you have before you can even attempt to modify it.
Old 03-11-2013, 11:29 PM   #37
JOJABOY
My buddy and I went round and round with this a few weeks back. We then incorporated the help of an elderly gentleman. Words of wisdom....never under-estimate the knowledge in our elders.
You have to look at all three aspects of your timing. (initial, centrifugal and vacuum). You need to know what your total timing is at 3000+ rpm (all in) and with and with out a load on the engine. You may be at 12* inital and have 18* vacuum advance. But how much is your weights advancing? You need to check it with vac advance unplugged and capped. Use your timing light and get the timing at 3000 rpm. Then....hook a vacuum pump to the vacuum advance can and pump it up to see where it puts you timing will all of the advance added in.
JOJABOY is offline   Reply With Quote
Old 03-12-2013, 08:18 AM   #38
WadmalawJoe
Thanks Longhair and JoJaboy.
It's taking a minute for all the timing info to get through my thick skull.
I also really need a tach so I can get a better handle on what rpm's I'm at and so forth. It's been on my list since I bought the truck.
I don't have a vacuum pump either. They can't be to much, I will look into getting one, but I think I can get some readings anyway with out it, just by unplugging the advance vs plugged in advance.
Anyway, I will do my best to figure out where its at and when (timing/rpm) and post my findings.
Thanks again!
Joe
Toys/projects
Old 03-12-2013, 10:36 AM   #39
JOJABOY
It's not exactly the same. When you rev your engine in park, the engine isn't under any load. So the vacuum is different. Short of hiding under your hood with a timing light while your wife takes the truck for a drive.....You can get a cheap $5 vacuum pump and pull the vac advance can in. This will simulate the intake creating different vacuum till all in.
Sure beats hanging on to the headers while straddling the fan and wife at the wheel.
Old 03-12-2013, 05:14 PM   #40
WadmalawJoe
Bo wha'cha talking about?! its under load, the bed is slap full!!
The vacuum pump; just give it a couple pumps? that small advance can can't require to much vacuum?
Toys/projects
Old 03-12-2013, 06:37 PM   #41
JOJABOY
Ha Ha Ha Been watchin too much Lizard Lick! Just pump it till it retracts. You can put your mouth on the end of the tube and suck if you don't have a pump. But you will need two people. One to suck and one to use timing light. My wife prefers to suck. LOL
Old 03-14-2013, 07:09 PM   #42
WadmalawJoe
Alright I have an update, I bought a vacuum pump and a multi-meter that had the tachometer feature as well.
So here are my findings;
With advance unplugged and port capped
RPM's drop to 650 and timing is 12 degrees ahead
Rev up to 3,000 RPM's and timing goes to 32 degrees ahead
With vacuum pump, I pumped it to 10 and checked everything, then pumped to 20 and nothing changed so I left it at 20 for testing.
Idle is 820 RPM's and timing 30 degrees ahead
Rev to 3,000 RPM's and timing goes to 50 degrees
So what's my next step?
Toys/projects
Old 03-14-2013, 07:17 PM   #43
JOJABOY
Those numbers sound good. So now you just have to figure out what is finicky about your particular engine. Keeping in mind that different cams, plugs etc. will cause your engine to differ from the standard curve. I would try backing my initial timing from 12* down to 9* or so.
50* is your "all in" and that seems to be causing predetonation and causing the noise. But before you adjust the timing. Try this first.
Unplug your vac advance from the carb port and cap it. Then plug it into the intake vacuum. (the port on the very bottom of your carb) Take it for a drive then revisit your timing curve. Worth the try. Only take 30 seconds to switch it to the other port and the drive time.
Old 03-14-2013, 07:17 PM   #44
Longhorn 70
Longhorn 70's Avatar
IMHO that is a bit too much total advance. I don't go above 36° degrees on my V8s.
Racers on here may have different specs.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-14-2013, 07:19 PM   #45
JOJABOY
He's at 32*. The 50* is with vacuum advance. Yours will probably register 52* or so with vacuum pump hooked up if your total timing is 36*
Old 03-14-2013, 07:38 PM   #46
WadmalawJoe
I tried that the other day and it pinged like a son of a gun
Toys/projects
Old 03-14-2013, 07:40 PM   #47
JOJABOY
you said you dialed vacuum advance can as far back as it would go right? if so, try moving your initial timing back to 9*. you may have to turn your idle up a little to get it where you want it in the end but try 9* and go for a drive.
you need to get your "all in" timing back just a little to stop the pinging
Old 03-14-2013, 08:10 PM   #48
WadmalawJoe
So you think I should try the other port again and adjust the timing for that port?
That's the ported one and its going to piss Longhair off.....lol
I wonder if that ported one even has any vacuum since it started pinging as soon as I gave it gas. That tells us that its not advanced enough correct? That port maybe stopped inside since it hasn't been used in a few years. I will check that out and let you know.
Toys/projects
Old 03-14-2013, 08:58 PM   #49
JOJABOY
ported vs. non-ported is depending on what your engine like best (in my opinion) put it where is runs best then adjust that 12* initial timing down below 10. i would start about 8*. it's simple addition. base timing plus centrifugal timing equals total timing. total timing doesn't factor in vacuum advance timing. most sbc engines like total timing around 32* and another 15* of vacuum for a grand total or (all -in) around 47*
you are at 50. so back the initial timing back to 8* or so. adjust your idle screw to get your idle where you want it and go driving.
Old 03-14-2013, 09:25 PM   #50
WadmalawJoe
Thanks, I will give that a try in the next couple of days and let you know. On one hand I hope its that easy on the other hand it will piss me off that I just didn't try backing the timing down more in the first place.
However, it does have some kind of performance cam in it and that is most likely effecting how the timing needs to be set.
Toys/projects
hei, tapping
